I am tryong to use the density plot for the first time.
Following maple instructions in maplsoft, I type
densityplot(xex2y2,x=2..2,y=2..2,colorscheme=["𝙱𝚕𝚞𝚎","𝙶𝚛𝚎𝚎𝚗","𝙾𝚛𝚊𝚗𝚐𝚎"])
but I get the error below:
Error, (in plot/options2d) unexpected option: colorscheme =["𝙱𝚕𝚞𝚎","𝙶𝚛𝚎𝚎𝚗","𝙾𝚛𝚊𝚗𝚐𝚎"])
It actually works with one color, but not with colorscheme!
http://www.mapleprimes.com/posts/38019-Calling-Out-To-C-From-Maple#
if i can use maple to call c# function such as AForge.QLearning
how to set some tasks for it to guess some system of polynomials to fit hibert series criteria?
how to set a game for it to run itself to discover itself?
I have a worksheet that makes 38 Mo. I find it a bit huge because my code is only composed by 20 code lines. I guess that Maple has saved a important volume of data which makes the file very heavy.
I would like to reduce the size of my worksheet so as to be able to send it to colleagues.
How can I remove all the data save in a file?
I find how to display only the inputs but the data in term of size seems to be still present.
Thanks a lot for your help
Need help in plotting the function in the attached file. m, h and k are parameters.
Bessel_Function.mw
Hello guys and gals!
I'm not strong enough with maple to get what the result I want.
It seems that it's because I'm asking for two lenths, and not a lenth and an angle, but I have no Idea how to tackle it diferently.
If you know a trick, please share it!
Here's an image:
http://imgur.com/xavAUoB
And here's the maple file attached (I think)
 complex_problem_from_the_internet.mw
Happy new year!
  I think similar question has been asked by several people, but I did not find a suitable thread. My question is, suppose I have a probablity distirubtion function like
  p(x,y) = exp(-alpha (x+y) ) x^2 y^2 / |x-y|  , alpha>0
 x,y goes from - \infty to + \infty. This function is normalizable but unbounded, which makes the rejection algorithm a bit difficult(?).
  How to generate samping points from this type of probability distribution function?
Thank you very much!
I would like to plot gait diagrams (the lines you can see on the picture belowà from the solutions obtained with a NL oscillator (composed with 8 coupled odes). Here the result that I would like to obtain.
Initial plot:
Desired plot
I would like to obtain 4 lines corresponding to the 4 elliptic trajectories obtained with the NL oscillator. The four lines should be done like this. When the trajectory is above 0, the line should be colored in green. When the trajectory is below 0, the line should be colored in black.
May you help me to define this kind of graph called gait diagrams from the solution of the NL oscillator ?
Here you can find my maple code:
K:=Matrix([<0, -1, 1, -1>,<-1, 0, -1, 1>,<-1, 1, 0,-1>,<1, -1, -1,0>]);
for i to 4
do
r[i]:=sqrt((u[i](t))^2+(v[i](t))^2):
omega[i]:=omega[sw]/(1+exp(b*v[i](t)))+omega[st]/(1+exp(-b*v[i](t))):
Equ[i]:=diff(u[i](t),t)=Au*(1-r[i]^2)*u[i](t)-omega[i]*v[i](t):
Eqv[i]:=diff(v[i](t),t)=Av*(1-r[i]^2)*v[i](t)+omega[i]*u[i](t)+MatrixVectorMultiply(K,<seq(v[i](t),i=1..4)>)[i]:
EqSys[i]:=[Equ[i],Eqv[i]]:
paramsCycle:=omega[st]=4*2*Pi,omega[sw]=2*Pi,Au=5,Av=50,b=100;
params:=paramsCycle;
Differential system
sys:=map(op,eval([seq(EqSys[i],i=1..4)],[params]));
ic:=[u[1](0)=0, v[1](0)=0,u[2](0)=0, v[2](0)=-0.1,u[3](0)=0, v[3](0)=0.1,u[4](0)=0, v[4](0)=0.1];
Résolution1
res:=dsolve([sys[],ic[]],numeric):
Initial boundaries
tcalc:=4;
ic2:=[seq(u[i](0)=eval(u[i](t), res(tcalc)),i=1..4),seq(v[i](0)=eval(v[i](t), res(tcalc)),i=1..4)];
Résolution2
res:=dsolve([sys[],ic2[]],numeric):
tmax:= 40:
numpts:=100*tmax:
plots:-odeplot(res,[t,v[1](t)],0..tmax,thickness=2, view=[0..5, -1.5..1.5],numpoints = numpts);
plots:-odeplot(res,[t,v[2](t)],0..tmax,thickness=2, view=[0..5, -1.5..1.5],numpoints = numpts);
plots:-odeplot(res,[t,v[3](t)],0..tmax,thickness=2, view=[0..5, -1.5..1.5],numpoints = numpts);
plots:-odeplot(res,[t,v[4](t)],0..tmax,thickness=2, view=[0..5, -1.5..1.5],numpoints = numpts);
plots:-odeplot(res,[seq([t,v[i](t)+i*5],i=1..4)],0..tmax,thickness=2,view=[0..5,0..25], numpoints = numpts);
HI, I am trying to solve two PDEs but in boundry conditions there is arising an error plz help.
Nazi.mw
I have many tests to conduct on a MapleSim model. At each test simulations, I would like to change slightly some parameters.
As I have many tests to do (with different parameters), I would like to use a script so as to do like this :
Parameters test1
Launch MapleSim simulation
Store results of test 1
And so on ...
How can I do this kind of script ?
Is it possible to store the 3D animation results ?
I recently noticed that Maple 2015 has become irresponsive on mac (macbook pro) with the latest java release (Java 8 update 66). Did anywone experience the same problem ?
I have a first order differential eq. for some variable say $r(x)$, where $x$ is the independent variable.
After solving this differential equation numerically, I want to use its solution in other expression for $r(x)$ and plot the expession with $x$.
Please let me know how to do it.
hi.for linear coupling equation
dsys3 := {-72.49829200*(diff(f1(x), x, x))+0.8377580411e-2*(diff(f2(x), x))-8.873545400*10^9*(diff(f3(x), x))+2.114533515*10^18*f1(x), -878.8477313*(diff(f2(x), x, x))+1.590065471*10^20*f2(x)-7.353421206*10^(-26)*(diff(f3(x), x, x))+4.891459762*10^10*f3(x), 4.027667395*10^(-20)*(diff(f3(x), x, x, x, x))-0.6274394007e-2*(diff(f3(x), x, x))+8.873545401*10^9*(diff(f1(x), x))-7.352113720*10^(-26)*(diff(f2(x), x, x))+4.904509456*10^10*f2(x)+1.208381068*10^19*f3(x)-2.499990383*10^26*omega*(diff(f3(x), x, x))}
by assuming and to expand these functions(f1-f2-f3) in polynomial form(e.g. Chebyshev, power polynomials, Legendre and etc).:
f1(x):=(&sum;)H[i] *(e)^(lambda[i] *x); f2(x):=(&sum;)alpha[i]*H[i] *(e)^(lambda[i] *x);f3(x):=(&sum;)GAMMA[i]*H[i] *(e)^(lambda[i] *x)
how i detemine lambda[i] which are roots of the  characteristic equations?in other word how i can build characteristic relation for coupling equation?
2)how i can gain value for alpha[i] and GAMMA[i]
by using equation
Q1 := subs(x = 0, sum(H[i]*exp(lambda[i]*x), i = 1 .. 8)); Q2 := subs(x = L, sum(H[i]*exp(lambda[i]*x), i = 1 .. 8)); Q3 := subs(x = 0, sum(alpha[i]*H[i]*exp(lambda[i]*x), i = 1 .. 8)); Q4 := subs(x = L, sum(alpha[i]*H[i]*exp(lambda[i]*x), i = 1 .. 8)); Q5 := subs(x = 0, sum(GAMMA[i]*H[i]*exp(lambda[i]*x), i = 1 .. 8)); Q6 := subs(x = L, sum(GAMMA[i]*H[i]*exp(lambda[i]*x), i = 1 .. 8)); M := diff(sum(GAMMA[i]*H[i]*exp(lambda[i]*x), i = 1 .. 8), x); Q7 := subs(x = 0, M); Q8 := subs(x = L, M)
thanks...
chebyshev.mw
I downloaded Maple Player, and I don't know how can I use it resolve Maths problems. Kindly, could you explain to me the procedure I shall follow for the reason to use it?
Qu_in_maple.mw
How to compute the  n component of U[i] even to reach the exact solution?
k := proc (t) options operator, arrow; t end proc:
U[0] := f(x):
for i to N do U1[i-1] := subs(x = t, U[i-1]); U[i] := (1/2)*x^2*(int(t*U1[i-1], t = a .. b)) end do:
Parse:-ConvertTo1D, "first argument to _Inert_ASSIGN must be assignable"
cos(x)+x^2+(1/2)*x^2*(-2+(1/4)*Pi^4)+(1/8)*x^2*(-1+(1/8)*Pi^4)*Pi^4+(1/64)*x^2*(-1+(1/8)*Pi^4)*Pi^8
cos(x)+(1/512)*x^2*Pi^12
Exact := proc (x) options operator, arrow; cos(x) end proc
Download Qu_in_maple.mwQu_in_maple.mw
How to find the  n component of U[i] even to reach the Exact solution cos(x)
I am trying to solve 4 nonlinear equations for four variables using fsolve  and the output that i am getting is basically the same equations repeated after some time.  I even tried reducing one of the equations using assumptions from my side but it results in same behaviour..  Quite new to maple, would like some advice as to this behaviour. Thanks
 Here's the file
fsolve_1.mw
PS- using do loop is part of the solving so i cannot remove that
First 213 214 215 216 217 218 219 Last Page 215 of 371
