I want to solve numerically the nonlinear pde:
u_x+u_t - (u_{xt})^2 = u(x,t)
which method do you propose me to use with maple? (I don't mine about which boundary conditions to be used here).
I have a function fitted and found the coeffiecients, the coeffiecient values are found with data from maple
the function is: a*(x+b/c)
my result is 5x+15
How do I get the values of a, b and c? The value of a is 5 that I know, but how does I get that maple gives me all the values of a,b  and c? The problem is that I get one value while i need the values of a, b and c.
I recently got myself a 64 bit computer and have noticed that I cannot use the option compile=true in dsolve/numeric. Take the following simple example:
dsolve({diff(x(t),t)=x(t),x(0)=1},numeric,compile=true);
Error, (in dsolve/numeric/SC/preproc) unable to compile (rc=1), please try again, and if that fails verify your Windows compiler installation
I'm using Windows 10, but had the same problem with Windows 8.1 on the same machine.
The Compiler:-Compile examples in the help page all work.
What do I have to do to make the option compile=true work in dsolve/numeric?
You may safely assume that I don't know any technicalities about these things.
How to change the font style, globally, the inputs and outputs of computations in Maple 2015? That is, every time a new document is started, the chosen style is automatically applied.
Oliveira.
Hello there..I tried to plot this program n somehow it didnt work.. I dont know how to fix it (I'm a beginner user)..Can anyone help me?? Please..
Thanks a lot
hmin := .2;
tclose := 150;
topen := 120;
B0 := 0; B1 := 800; dB := (B1-B0)*(1/100);
B := dB*i+B0;
xcoor := [seq(B, i = 0 .. 99)];
ycoor := [seq(fsolve(tclose*ln((1-(1-hmin)*exp((-B+APD)/topen))/hmin) = APD), i = 0 .. 99)];
with(plots);
P := plot(xcoor, ycoor);
display(P)
Hello everyone!
Do you have any idea to solve and plot a 2-time logistic map:
x(t+ 1_\alpha)= r*x(t)*(1-x(t))  ,t=(t^1,t^2)  ?
There are no examples for ModuleDeconstruct either on its help page or in the Programming Guide. Of course, I can figure out its basic and primarily intended purpose: to render the module/object in a one-dimensional plaintext printed form, which would be useful for debugging. But I am most interested in this use described in the second sentence of this, the second paragraph of Description at ?ModuleDeconstruct [italics added]:
When the value returned by ModuleDeconstruct is printed, the output could be capable of being parsed to the original module. When used with an object, ModuleDeconstruct can return an unevaluated call to a constructor to achieve this.
That seems very powerful. Is there any example of it being used in Maple library code? in user code? Can anyone here come up with a practical use for this? A Google search turns up nothing.
  I have the following input in order to obtain the dimension of an array, by means of the values has been assigned
with(ArrayTools):
f[1]:=1:
f[2]:=2:
nops(f);
Size(f);
Dimension(f);
  The result is
[ 1 1 ]
Error, invalid input: LinearAlgebra:-Dimension expects its 1st argument, A, to be of type {Matrix, Vector} or coercible via `~Simplify`, but received f
I cannot get number "2", which is expected. Is there any way to obtain that? I looked for help and mapleprime, without any simple solution ......
Thank you very much!
I want to compute the following solve:
C:=A, B, F, H(It has 4 unknowns):
V:=R,Y,E,I (It has 4 equations):
solve({V},{C});
By hand calculations I just found that the solve result is real ,but in maple there is no solution and no error (the maple ignores to solve this equation !!!)
can anybody help me to find the solve soltuion ?
H. Kabir
The font size in the output pane of the standard interface, interactive debugger is really, really small and I can't figure out how to increase it. (Other than drop my screen resolution from its native 2560x1440, which makes it bigger but "fuzzier" - not a huge improvement for tired eyes!!)
Hi dear friends
How do I improve my ability to manipulate code?
_________________________________________________________________________________________
Digits := 30: m := 20: p0 := 8.: g := -0.3: nu := 0.3: a := 1:
w := sum(b[n]*r^(1.02*n), n = 1 .. m):
ODE := r^3*(g*r+a)^3*(diff(w, r, r, r, r))+2*(diff(w, r, r, r))*r^2*(4*g*r+a)*(g*r+a)^2+(diff(w, r, r))*r*(3*g^3*nu*r^3+P*a^3*r^2+6*a*g^2*nu*r^2+11*g^3*r^3+3*a^2*g*nu*r+15*a*g^2*r^2+3*a^2*g*r-a^3)+(diff(w, r))*(6*g^3*nu*r^3+P*a^3*r^2+6*a*g^2*nu*r^2-2*g^3*r^3-3*a*g^2*r^2+a^3):
for P from p0 by 0.1e-1 to p0+1 do
W := simplify(subs(solve({seq(evalf(subs(r = j/(m+2), ODE)), j = 2 .. m-1), subs(r = 1, diff(w, r))}, {seq(b[j], j = 1 .. m)}), w/b[m])):
F := (int(((diff(W, `$`(r, 2))+(diff(W, r))/r)^2-(2*(1-nu))*(diff(W, `$`(r, 2)))*(diff(W, r))/r)*r*(1+g*r/a)^3, r = 0 .. a))/(int((diff(W, r))^2*r, r = 0 .. a)):
delta[trunc(100*(P-p0))] := abs(F-P) end do:
plot(W, r = 0 .. a);
Min := min(seq(delta[j], j = 0 .. 100)):
for j from 0 to 100 do if delta[j] = Min then print(p0+j/(100.)) else  end if end do;
I have this matrix for example:
A := <<1,2>|<3,4>>;
How to determine: 2^A
plz help me, how do i solve singular ODEs of lane Emden type equation for homotopy analysis method in maple? there is arising an arror, invalid fraction
To begin with my code is:
with(Statistics);
N:=RandomVariable(Normal(5,2))
for i from 1 by 1 to 100 do
OS[i]:=Sample(N,50)
end do
 print(i)
  from j from 1 by 1 to 1000 do
    BS[i,j]:=Bootstrap('Mean',OS[i],replications=1)
  end do
end do
My goal is to produce as an output in the software's screen the values of 1000 bootstrap means for each of 100 original samples in order to export the results to Excel. Based on my basic knowledge of programming I thought that I can do that through the use of the vectors. Unfortunately though when I trigger the operation the software seems to be evaluating (with the homonymous indication in the bottom left corner of the screen) it for an indefinite period of time, obliging me to stop it at some point. However, let me point out that when I do the same process for i and j 4 and 10 for example then I have results, therefore presumably my code is correct. I know that I can do the same operation in Excel and I have already created a respective macro, however I wanted to use Maple in order to take advantage of its fast operation of calculations, which is pointless in case that I have to wait more time for the results than I have already waited to be eventually produced.
Any thought and idea would be appreciated, thank you very much in advance!
First 229 230 231 232 233 234 235 Last Page 231 of 371
