I hope that I will manage to explain my question.
I try to recover the structure of my worksheet by working on XMLElements.
Sometimes, I have in the XMLElements that I recover a XMLElements linked to "Font" and {"encoding" -> "UTF-8"}
Why for one section defined as "text" and "headling1" I can have a change in "Font"? Is there a possibility to detect this changement for line of text.
In other words, how can I recognize a layout "Font" in a line of a worksheet and how can I change a layout "Font" into a layout "TexttField" ?
Trying to get this function to work in Maple 18
CharacteristicPolynomial(M,x)
I am trying to creat a way to solve matrix differential equations step by step.
Hello Forum:
In the Programming Guide, section 14.3 (Programming Guide: Advanced Connectivity), the subsection `Runtime Environment Prerequisites' a sample script is given in order to set up the environment varibales MAPLE and LD_LIBRARY_PATH:
--8><--------------------------------------------------------------------------
#!/bin/sh
export MAPLE="/usr/local/maple"
. $MAPLE/bin/maple -norun
myapp $*
-----------------------------------------------------------------><8-----------
For testing, `my app $*' can be replaced by `printenv': it seems not to work with Maple 2015.
Any hint ?
Thanks in advance,
Jerome
hi.please help me .why rule ''''Det'''' dose not work properly?
this program attached DET.mwblow.thanks alot
Here is the function I want to find the inverse of
 U(x):=-(s^2/(s^2+1)+1/(s^2+1)-1)*exp(sqrt(s)*x/sqrt(phi))/(s^2+1)+exp(-sqrt(s)*x/sqrt(phi))/(s^2+1);
where phi>0
Now taking the inverselaplace of U(x)
 u:=invlaplace(U(x),s,t);
which give me an unevaluated integral.
Any idea, how to get the complete inverse, maybe interms of erf?
Is it possible to have an input box, where the student can give an input (integer) and this is then used in the following questions in an assignment?
e.g. in the first question the student is asked to give his student number, in the second question this number is used to create random parameters.
When solving a simple assignment problem in Maple 2015.1 the bug occurs:
In Maple 2012 there are no problems:
A := Matrix([[1, 7, 1, 3], [1, 6, 4, 6], [17, 1, 5, 1], [1, 6, 10, 4]]):
n:=4:
z:=add(add(A[i,j]*x[i,j], j=1..n), i=1..n):
restr:={seq(add(x[i,j], i=1..n)=1, j=1..n),seq(add(x[i,j], j=1..n)=1, i=1..n)};
sol:=Optimization[LPSolve](z, restr, assume=binary);
I have the following transition rate matrix. Upto m the matrix follows a patern and after that the patern changes but repetative structure is there upto n. In this problem m=4, n=9. How to write these entries using for loop in maple?
Matrix.pdf
why the the software can't solve the integral like ∫xdlnx?
Thanks in advance for your help.
I want to plot curves with Japanese title and labels. I want to plot through an external java program. Is it possible?
When I tried, I am getting control character unexpected error.
Hi, I am learning GR and new to maple. I played with maple's DifferentialGeometry package.
While duplicated the maple GR example, in DGsetup([t, r, theta, phi], M1, verbose),
I got the error,
The following coordinates have been protected:
[t, r, theta, phi]
The following vector fields have been defined and protected:
Error, (in Typeset:-Tdisplay[true]) `alias` does not evaluate to a module
 I don't know how to fix it. Can anyone kindly help?
I have the following integral equation to solve numerically:
v(x,t)=1 - h*\int_0^t JacobiTheta0(1/2x , \pi i s) v^4(1,t-s)ds
where h is a numerical parameter, and v(1,t) = 1-h*\int_0^t \theta_3(r)v^4(1,t-r)dr (theta3 is Jacobi theta3 function).
So I want to use an iteration method that will converge numerically to the solution, where v(1,0)=1.
How to use maple for this?
I want also to find the rate of convergence to the numerical solution.
 edit: I should note that v(x,0)=1, even though it's implied from v(x,t) above.
I have started to use Maple 18 and I have found that my scale starts at 2.*10^16 for all functions I graph no matter if its 3D or 2D. Is there a way to change this scale?
Dear, my attached file take alot time to exicute the result, Please solve this problem. I am waiting your kind response.
Hirota_Bilinear_Method-3.mw
With my best regards and sincerely.
Muhammad Usman
PhD (Scholar) Mathematics
HITEC University, Taxila
Lecturer of Mathematics
Govt. Degree College Taxila Pakistan.
Visiting Lecturer of Mathematics
University of Wah, Pakistan.
Email: mughal1103@gmail.com
Mob #: +923152329276
1.
similar gap system, which function can output coset table ?
if find example below,
f := FreeGroup( "a", "b" );
g := f / [f.1^2, f.2^3, (f.1*f.2)^5];
tab := CosetTable(g, Subgroup(g, [g.1, g.2*g.1*g.2*g.1*g.2^-1]));
2.
if quotient group is for equivalence relations, what do relations [g.1, g.2*g.1*g.2*g.1*g.2^-1] for? which kind of relations is for input to subgroup parameter which is like relations?
3. equalivance relations in wiki mentioned is to partition cells, how do they satisfy symmetric, reflexive and transitive after partition? how to test these partition?
First 231 232 233 234 235 236 237 Last Page 233 of 371
