I have a great problem with the evaluation of following definite integral
> restart;
> int((t-x)^2)/(1+2t+(1/2)t^2-ln(t^2+2t+2)t-ln(t^2+2t+2)+arctan(1+t)t^2+2arctan(1+t)t+ln(2)t+ln(2)-(pi/4)t^2-(pi/2)t)^2,t=0..x)
I have tried different classical commands but Maple doesn't give an answer. Probably, it's just a silly fault.
Does anyone knows how to solve it?
I'm using Java OpenMaple interface to call Maple functions from Java on Ubuntu Linux. I'm following the examples provided on Maple website. My Java code:
import com.maplesoft.openmaple.*;
import com.maplesoft.externalcall.MapleException;
class test {
    public static void main( String args[] ) throws Exception {
        String[] a = {"java"};
        Engine  t = new Engine( a, new EngineCallBacksDefault(), null, null );
        try {
            t.evaluate( "factor(-8*((16*I)*g**4*(-4*mc**2+u)**(-2)*(4*mb**2-u)**(-2)*u**(-1)*(12*mb**2-u)*(-4*s*mb**2+16*mb**4-4*u*mb**2+t*u-4*t*mb**2)*s*(4*s*mb**2+4*mc**2*s+16*mc**2*mb**2-s**2-4*t*mc**2+t**2-4*t*mb**2)*(12*mc**2-u)+(16*I)*(4*s*mb**2+4*mc**2*s+u**2-4*mc**2*u+16*mc**2*mb**2-4*u*mb**2-s**2)*(12*mc**2-t)*g**4*(t-4*mb**2)**(-2)*(4*mc**2-t)**(-2)*(-t+12*mb**2)*(-4*s*mb**2+16*mb**4-4*u*mb**2+t*u-4*t*mb**2)*s*t**(-1))**2);" );
        catch ( MapleException e ) {
            System.out.println(e);
Maple throws exception:
com.maplesoft.externalcall.MapleException: Error, (in evala/Factors) input must be polynomials over the integers
The input polynoial is valid (when coping and pasting `factor(...)` directly into Maple interface, all works). When trying to factor simple polynomials like "x**2 - I*x" all goes fine too. Tried both Maple 17 and 18 (Linux).
PS. There is no problem when running this code on OS X (I tried Maple 16, 17, 18),  but I need to be able to run Maple with Java on my Linux cluster.
How can unknown values in boundary conditions of system ODEs be determine by using shooting technique. See the work sheet here Sht.mw
Hello;
I wish to express a tensorial equation or expression a simplified vector form.
In the worksheet attached, I was trying to express Maxwell Equations in the familiar vector form from the tensorial form, using the F[mu,nu] tensor.
But I cannot achieve the familiar tensor form. If someone can give a hand, it would help me a lot.
HowtoExpressCompactForm.mw
Does anyone know how to achieve the state transition of a prismatic joint between active and passive in MapleSim? Recently, I want to realize such a state transition of a prismatic joint. Specifically, during a simulation, the joint can either be motion-actuated or passive according to some conditions. Actually, I tried to use SimMecahnics, but I failed. Hope anyone can give me some constructive suggestions. Many thanks!
I have a question about "EliminationIdeal" command. When I call EliminationIdeal(<x>,{a,b,c}) appears error. I know that the output of this computation must be []. What I have to do?
I would like to plot a solution of differentiel equation in its three ranges [-10,-6^(2/3)/4[,[-6^(2/3)/4,6^(2/3)/4], ]6^(2/3)/4,10] .
When plotting using unapply(piecewise) I got an error like
Error, (in plot) offset to _Inert_LOCAL outside of range
See below my code.
Thanks for hellp.
HYP.mw
Hi, I know this has been asked ( and answered before) but when I installed this package and pressed ?globalsearch the help page is void.how do I get it?
Why does my Maple 2015 constantly pause to redraw symbols in pinned palettes?  Really seems to slow down my use of the program.  Had this problem in previous versions also.  Using OSX Yosemite latest version.
How to solve delay differential equations with Maple?
Example:
diff(x(t),t) = 3*x(t)^2 + 0.3*x(x-0.03)
y'(t)=1-y'(t-y(t)^2 /4),      t>=0
with initial function
y(t)=1+t,   0<=t<=1
please solve
Sorry for making such a rude, big question. I have to solve these equations, but it's impossible ofcourse with my bad mathematics and even maple skills. Somebody help me pleaseㅠ_ㅠ
Differential equations
Is there a way to export all of the equations (from MapleSim) including the casual equations? I used Multibody Analysis template and Equations template but it only exports the acausal equations.
Your help is really appreciated.
Hey there!
I uploaded a solid drawing from a CAD software (like solidworks, inventor, stl files, etc) into Maple using plottools:-importplot("drawing.stl").
Also, I know Maple can give me the normal vector (and point of intersection) using line and intersection commands, for example.
Now, is it possible to find a point of intersection (and the normal vector at that point) of a line that crosses the uploaded CAD solid?
I guess that to accomplish that, it would be necessary to somehow "map" the solid and that's the part that I am lost.
Many thanks!
First 234 235 236 237 238 239 240 Last Page 236 of 371
