PS,
PiFast43 is freely available at,
http://numbers.computation.free.fr/Constants/PiProgram/pifast.html
i dont know what`s wrong with it help me guys
hi,
I am trying to implement some data-intensive algorithms like: comuting similarity scores, clustering etc. How efficient Maple is in doing these operations? I mean is it comparable to MATLAB in these operations? What toolboxes are useful in these? I am trying to build a recommender system.
I am using Maple18 and not sure if Maple has any advantage in implementing these type of algorithms over MATALB??
siba
Hi all.
I am using Maple2015.
I typed in as input y=x/sqrt(1-x^2).
I hit enter.  The output is:
 y=x/sqrt(1-x^2)
I know the 2 answers are equivalent.
My question is why did Maple swap 1-x^2 to -x^2+1???
Any advice to swap it back would be greatly appreciated.
How to find asymptotic behaviour of a function.
For example at infinity
sinh(x) behaves as 1/2*exp(x)
1/sinh(x)  behaves as 2*exp(-x)
exp(-x)*(exp(-x)+1) behaves as exp(-x)
so that it works with a more complex expression.
I'm very interested by this function so as to export my code Maple as MATHML thanks to the function ExportContent.
However, this function can be applied only to a expression.
I would like to apply to all the code of my worksheet.
Do you have some ides to apply ExportContent or equivalent to obtain the MATHML transformation of a whole worksheet ?
Thanks a lot for your help.
Best regards,
I need to prepare for a final exam for a introdutory computer science course in Maple.
My professor gives us mutliple choice questions, short answer questions and wiritng some codes.
what is the most efficient way to study for my final exam? or how should i study for an computer science exam. I am not really use to preparing for such a course.
Are there any websites that i can practice multiple choice questions?
I would appreciate any advice.
Thank you very much.
Hi. I am having trouble with maples command "Cross product", i don't know why it doesn't work. Can anybody help me? This is a screenshot of the problem:
This question is 99% similiar to an previously posted question, but this one has a little twist(s).
http://www.mapleprimes.com/questions/200101-Solving-For-Coefficients-Of-Polynomial-Equations
Here is the sample problem. Let's say I have the following equations
e1:=(a+b+1)x^2 + (a+1)*x^4 = 0;
e2:=(a-b)*x+ (a^2 - 1)*x^3 = 0;
One can immediately tell the system is inconsistent because on x^3, we have a = -1,1 but on x and x^2 we have a = -1/2
This is precisely the problem I am facing, my e1 and e2 will eventually get bigger (bigger as in the order of the polynomial will increase) and I keep facing inconsistencies.
However if I could find a way to code it so that I can ask Maple to solve only up to a certain degree it would be great. This will eliminate any inconsistency
For example, using the system I have here, the system is consistent up to order 2 (it will always start from constants and up to a certain power). So I will ask Maple to solve the above system up to order 2.
Here is a pseudocode I have been working on.
For i = 1..2 //this might be increased, but it will of course be finite and probably won't go past 10.
For j = 0..N
//N is the degree of polynomial
f[i]:= coeff(e[i],x,j);
end
end
//the above generates the equations, below will solve it
solve( { f[i], i=1..?} ,{a,b})
Note that the pseudocode assumes e[i] are expressions and not equations set to 0 (which is what I have). Is there an "un"unapply on maple?
edit1: have to sleep  (late where I am! Will check for responses tomorrow) thank you
In a local coordivates frame {B}, an arc whith center "coc" ,radius "radius" and angle between “alpha1” and “alpha2” can be plotted in XY plane of {B}. The coord {B} is in a Ref frame {O}. The homogeneous transformation matrix is “H”. How can I plot this arc in coordinate {O}?
solve 30a+75b+110c+85d+255e+160f+15g+12h+120i=800000 over the positive integers
g:=Groebner:-Basis([a-2.0*b,b-2], plex);
Groebner:-Reduce(a, g, plex);
Error, (in content/polynom) general case of floats not handled
How to solve this problem simply?
now the equation is
d2u/dt2-(2*d2u/x2)+d2u/dxdt=0
initial condition: u(x,0)=1-(xsign(x)), abslute x<1,0 otherwise. Assume sign(x)=-1 for x<0, 1for x>0
 Ut(x,0)=cos(pix), bslute x<1, 0 otherwise , he didnt give any B.Cs
so I would like to know the analytical and numerical sols, and plots for the wave at t=2,4
for Numerical:   delta x=0.1, delta t=0.025, range 0..4
Good day,
How can this be corrected ''Error, (in dsolve/numeric/bvp) initial Newton iteration is not converging'' see the worksheet here VT.mw
can you help in that please?
How can I use this small procedure (root_of_cheb) as a sub-procedure in  the next procedure (EvalInt) ?
is it possible?
root_of_cheb:=proc(n)
   local xk,b,k:
   xk:=(k,n)->cos((2*k-1)*Pi/(2*n));
   sort([seq(evalf(xk(k,n)),k=1..n)]):
end:
EvalInt:=proc(f,n)
   local xk:
   evalf((Pi/n)*add(f(xk(i,n)),i=1..n)):
end:
First 236 237 238 239 240 241 242 Last Page 238 of 371
