with(PDEtools);
Es := 0.117108e12;
Ef := 0.78125e11;
l := 0.150e-6;
s := 0.500000e-3;
f := 0.5898334197e-6;
o := 0.9e-5;
d := 0.10e-17;
cb := 0.1e7/(19.9);
R := 8.3144621;
T := 298;
PDE := diff(u(x, t), t)-(diff(u(x, t)+o^2*Es*cb*u(x, t)^2/(9*R*T), x, x)) = 0;
IBC := {u(1, t) = 1, u(x, 0) = 0, (D[1](u))(1, t) = l*f/(d*cb)};
S := pdsolve(PDE, IBC, numeric, time = t, range = 0 .. 1, timestep = 0.1e-4, spacestep = 0.1e-6);
p1 := S:-plot(t = .1, numpoints = 100);
Error, (in pdsolve/numeric/plot) unable to compute solution for t>HFloat(0.0):
matrix is singular
p2 := S:-plot(t = .2, numpoints = 50, color = green);
matrix is singular
p3 := S:-plot(t = .3, numpoints = 50, color = blue);
matrix is singular
plots[display]({p1, p2, p3});
Error, (in plots:-display) expecting plot structures but received: {p1, p2, p3}
I want to increase the stack limit. but i can not raise it above the hard limit....
so i wonder whether there is a way to increase the hard limit, or at least tell me how much is it?
I tried to use java to call maple command, but end up jvm crash. after some digging, i found the command i issued returned a rather huge string (around 40KB...).
Is this the reason why jvm crash? should i constrant the length of a command result when calling it from Java code?
Derive the orbit of the Moon around the Earth by doing a Verlet algorith of Molecular Dynamics simulation. Use one hour for your step τ. Place the stationary Earth at the origin of the Cartesian system. For initial conditions, use the position and the speed of the Moon when it is at its apogee (furthest from Earth). Plot the orbit.
(a) Show that if {an} ∞ n=1 is Cauchy then {a 2 n} ∞ n=1 is also Cauchy. (b) Give an example of a Cauchy sequence {a 2 n} ∞ n=1 such that {an} ∞ n=1 is not Cauchy
Hi, I'm trying to solve a system of equation and I keep getting this error. Could anyone help me figure out what I'm doing wrong?
My problem is:
> alpha := .3; G := 3.5; L := 6; f := 1.1;
for i to 50 do
I0 := x(z)+y[i](z); ICon := x(0) = 1, y[i](0) = 0;
for j to 50 do
i <> j;
d1 := diff(x(z), z) = -G*x(z)*y[i](z)/IC-alpha*x(z);
d2 := diff(y[i](z), z) = G*y[i](z)*y[j](z)/IC-alpha*y[i](z);
dsys := {d1, d2};
F := dsolve({ICon, op(dsys)}, [x(z), y[i](z)], numeric);
Error, (in dsolve/numeric/process_input) unknown y[2] present in ODE system is not a specified dependent variable or evaluatable procedure
I am running Maple in a windows virtual machine, on a mac computer.
I have a number of worksheets on its disk
Windows advised me to run its error checking utility (chkdsk)
when I try and open them it gives me a number of options:
maple text
plain text
and maple input
None of these are the same as the original files. What has happened? and how can i fix it?
can anybody help me? i want to check the consistency of my scheme. My equation is too long if i check manually, so i used maple 13 to simplify my equation. But it cannot simplify it because of length of output exceed limit 1000000
eqn1 := u+(1-exp(-m))*u[t]+(1-exp(-m))^2*u[tt]/factorial(2)+(u-(1-exp(-m))*u[t]+(1-exp(-m))^2*u[tt]/factorial(2))-u-(1-exp(-m))*u[x]-(1-exp(-m))^2*u[xx]/factorial(2)-u+(1-exp(-m))*u[x]-(1-exp(-m))^2*u[xx]/factorial(2)+(1-exp(-m))^2*u+(1-exp(-m))^2*u^3-(1-exp(-m))^2*(4*(((x+1-exp(-m))^2-2)*cosh(x+1-exp(-m)+(t+1-exp(-m)))-(4*(x+1-exp(-m)))*sinh(x+1-exp(-m)+(t+1-exp(-m)))+(x+1-exp(-m))^6*cosh(x+1-exp(-m)+(t+1-exp(-m)))^3))*((x^2-2)*cosh(x+t)-4*x*sinh(x+t)+x^6*cosh(x+t)^3)*(((x+1-exp(-m))^2-2)*cosh(x+1-exp(-m)+t)-(4*(x+1-exp(-m)))*sinh(x+1-exp(-m)+t)+x^6*cosh(x+1-exp(-m)+t)^3)*((x^2-2)*cosh(x+1-exp(-m)+t)-4*x*sinh(x+1-exp(-m)+t)+x^6*cosh(x+1-exp(-m)+t)^3)/((((x+1-exp(-m))^2-2)*cosh(x+1-exp(-m)+(t+1-exp(-m)))-(4*(x+1-exp(-m)))*sinh(x+1-exp(-m)+(t+1-exp(-m)))+(x+1-exp(-m))^6*cosh(x+1-exp(-m)+(t+1-exp(-m)))^3)*((x^2-2)*cosh(x+t)-4*x*sinh(x+t)+x^6*cosh(x+t)^3)*(((x+1-exp(-m))^2-2)*cosh(x+1-exp(-m)+t)-(4*(x+1-exp(-m)))*sinh(x+1-exp(-m)+t)+(x+1-exp(-m))^6*cosh(x+1-exp(-m)+t)^3+(x^2-2)*cosh(x+1-exp(-m)+t)-4*x*sinh(x+1-exp(-m)+t)+x^6*cosh(x+1-exp(-m)+t)^3)+(((x+1-exp(-m))^2-2)*cosh(x+1-exp(-m)+t)-(4*(x+1-exp(-m)))*sinh(x+1-exp(-m)+t)+(x+1-exp(-m))^6*cosh(x+1-exp(-m)+t)^3)*((x^2-2)*cosh(x+1-exp(-m)+t)-4*x*sinh(x+1-exp(-m)+t)+x^6*cosh(x+1-exp(-m)+t)^3)*(((x+1-exp(-m))^2-2)*cosh(x+1-exp(-m)+(t+1-exp(-m)))-(4*(x+1-exp(-m)))*sinh(x+1-exp(-m)+(t+1-exp(-m)))+(x+1-exp(-m))^6*cosh(x+1-exp(-m)+(t+1-exp(-m)))^3+(x^2-2)*cosh(x+t)-4*x*sinh(x+t)+x^6*cosh(x+t)^3));
(1-exp(-m))^2*u[tt]-(1-exp(-m))^2*u[xx]+(1-exp(-m))^2*u+(1-exp(-m))^2*u^3-(1-exp(-m))^2*(4*((x+1-exp(-m))^2-2)*cosh(x+2-2*exp(-m)+t)-16*(x+1-exp(-m))*sinh(x+2-2*exp(-m)+t)+4*(x+1-exp(-m))^6*cosh(x+2-2*exp(-m)+t)^3)*((x^2-2)*cosh(x+t)-4*x*sinh(x+t)+x^6*cosh(x+t)^3)*(((x+1-exp(-m))^2-2)*cosh(x+1-exp(-m)+t)-4*(x+1-exp(-m))*sinh(x+1-exp(-m)+t)+x^6*cosh(x+1-exp(-m)+t)^3)*((x^2-2)*cosh(x+1-exp(-m)+t)-4*x*sinh(x+1-exp(-m)+t)+x^6*cosh(x+1-exp(-m)+t)^3)/((((x+1-exp(-m))^2-2)*cosh(x+2-2*exp(-m)+t)-4*(x+1-exp(-m))*sinh(x+2-2*exp(-m)+t)+(x+1-exp(-m))^6*cosh(x+2-2*exp(-m)+t)^3)*((x^2-2)*cosh(x+t)-4*x*sinh(x+t)+x^6*cosh(x+t)^3)*(((x+1-exp(-m))^2-2)*cosh(x+1-exp(-m)+t)-4*(x+1-exp(-m))*sinh(x+1-exp(-m)+t)+(x+1-exp(-m))^6*cosh(x+1-exp(-m)+t)^3+(x^2-2)*cosh(x+1-exp(-m)+t)-4*x*sinh(x+1-exp(-m)+t)+x^6*cosh(x+1-exp(-m)+t)^3)+(((x+1-exp(-m))^2-2)*cosh(x+1-exp(-m)+t)-4*(x+1-exp(-m))*sinh(x+1-exp(-m)+t)+(x+1-exp(-m))^6*cosh(x+1-exp(-m)+t)^3)*((x^2-2)*cosh(x+1-exp(-m)+t)-4*x*sinh(x+1-exp(-m)+t)+x^6*cosh(x+1-exp(-m)+t)^3)*(((x+1-exp(-m))^2-2)*cosh(x+2-2*exp(-m)+t)-4*(x+1-exp(-m))*sinh(x+2-2*exp(-m)+t)+(x+1-exp(-m))^6*cosh(x+2-2*exp(-m)+t)^3+(x^2-2)*cosh(x+t)-4*x*sinh(x+t)+x^6*cosh(x+t)^3))
a := simplify(eqn1);
`[Length of output exceeds limit of 1000000]`
Download consistency_expmle_4.mw
"the set Q of rational numbers does not have the least-upper-bound property under the usual order. "
Proof:
"Consider the part A = {x in `&Qopf;`; 1<x^(2)<2<}, this part is not empty as [4/(3)]  in A; It is bounded by 2 as if x^(2)<4 then x<2. THe set of greatest elements of A, belonging to `&Qopf;`, is not empty."
Lemma:
"If [p/(q)]  in A with q  in `&Nopf;`^(*), then p>q for p>0 and p^(2)-2*q^(2)<0; or p^(2)-2*q^(2) in `&Zopf;`, thus"
p^2-2*q^2 <= -1
p^2-2*q^2 <= -1
"for all r  in `&Nopf;`^(*), put y=(r*p+1)/(r.p), we have :"
y > p/q
Now:
"y^(2)-2=supA/(r^(2)*q^(2)), with supA= r^(2)*p^(2)+2 r*p+1-2 r^(2)q^(2),"
otherwise; -1; s = r(p^2-2*q^2)+2*p+1
"a good choice for r, for instance r=2*p+1, we get from (1)"
(2*p+1)(p^2-2*q^2) <= (2*p+1)(-1)
2*p(p^2-2*q^2) <= 2*p(-1)
thus:
(2*p+1)(p^2-2*q^2)+2*p <= -1
2*p(p^2-2*q^2)+2*p <= -2
(2*p+1)*[(2*p+1)(p^2-2*q^2)+2*p] <= -2*p-1
(2*p+1)*[2*p(p^2-2*q^2)+1+2*p] <= -2*p-1
(2*p+1)*[(2*p+1)(p^2-2*q^2)+2*p]+1 <= -2*p
(2*p+1)*[2*p(p^2-2*q^2)+1+2*p]+1 <= -2*p
"finally, supA<0"
`and`(thus*y^2 < 2, `in`(y, A*with*y^2) and A*with*y^2 > 1)
"so, for any x  in p/(q) in A, there exists y  in A such that y>x: in conclusion A does'nt admit a greatest element."
Now, given*m = p/q, `and`(not `in`(Typesetting:-delayDotProduct(a*greatest*element*of*A, Then)*m, A), we*get*thus):
`and`(p > q, p^2-2*q^2 >= 0)
as*the*equation*p^2-2*q^2 = (0*has)*no*solutions and `in`((0*has)*no*solutions, nonnegint*nonnegint), we*get:
2*p^2-2*q^2 >= 1:
"for any r  in `&Nopf;`^(*)let's put m'=(r*p)/((r*q+1)); we have:"
(diff(m(x), x))^2-2 = supA/(r*q+1)^2:
With*supA = r^2*p^2-2*(r*q+1)^2 and r^2*p^2-2*(r*q+1)^2 = r[r[p^2-2*q^2]-4*q]-2:
"for a good choice of r, for example r=4*q+1, we get (back to (2)):"
supA > (0*thus)*(diff(m(x), x))^2 and (0*thus)*(diff(m(x), x))^2 > 2:
"So, for any greatest element m of A, it exists m', greatest element of A such as:"
diff(m(x), x) < m(x):
"A does not admit a least upper bound."
Download rational_numbers.mw
Proof:
Lemma:
p^2-2*q^2 <= -1
p^2-2*q^2 <= -1
y > p/q
Now:
thus:
"finally, supA<0"
2*p^2-2*q^2 >= 1:
Good day everyone,
please how can one solve this pde in terms of Bessel function or any other analytic solution with the plot.
See the file ID.mw
Do the following equation solve by method of line(MOL) with this software?
du/dt=0.01 d^2u/dx^2
conditions:
u(x,0)=10
u(0,t)=0
u(1,t)=0
t=1,delta t=0.1,x=1,Nx=10
thank you
hello everyone, I have problem in my project written by matlab to solving my equations with rang-kuta 4 order method. I send my project file.  please help me to run it correctly. thank you.
input Q_j n j V Z F_ve a_1 a_2 p_1 p_2 L A f m k c h t i;
for jj=1:n;
            s=Q_j(jj);
end
b=(-V)*Z;
o=(F_ve*A)*(((a_1^2)*p_1)-((a_2^2)*p_2))/L;
% RK4 method;
% md2z/dt2+cdz/dt+kz=f;
% dz_1/dt=z_2;
% mdz_2/dt+cdz_1/dt+z_1k=f;
% dz_2/dt=1/m(f-cz_2-kz_1);
f=0;
m=1;
k=s+b+o;
c=0;
h=0.5;
t=0:0.5:t;
z1=zeros (1,n);
z2=zeros (1,n);
z1 (1)=0;
z2 (1)=1;
% N=length (t);
f1=@(t,z1,z2)z2;
f2=@(t,z1,z2)f-(c*z2)-(k*z1);
for i=1:n-1;
    k1=f1 (t (i),z1 (i),z2 (i));
    m1=f2 (t (i),z1 (i),z2 (i));
    k2=f1 (t (i)+h/2,z1 (i)+0.5*k1*h,z2 (i)+0.5*m1*h);
    m2=f2 (t (i)+h/2,z1 (i)+0.5*k1*h,z2 (i)+0.5*m1*h);
    k3=f1 (t (i)+h/2,z1 (i)+0.5*k2*h,z2 (i)+0.5*m2*h);
    m3=f2 (t (i)+h/2,z1 (i)+0.5*k2*h,z2 (i)+0.5*m2*h);
    k4=f1 (t (i)+h,z1 (i)*k3*h,z2 (i)*m3*h);
    m4=f2 (t (i)+h,z1 (i)*k3*h,z2 (i)*m3*h);
    z1 (i+1)=z1 (i)+(h/6)*(k1+(2*k2)+(2*k3)+k4);
    z2 (i+1)=z2 (i)+(h/6)*(m1+(2*m2)+(2*m3)+m4);
end
plot (t,z1)
plot (t,z2)
plot (z,t)
The following error occurred when I simulate a build-in model, anyone could help me to solve this problem? Thanks first
Hi, as I can't manage to copy and paste on mapleprimes, I would be glad to get a hint ...
I am looking here for a tutor, that can help me doing some Maple V (5) programming.
I am a mathematic student and we use Maple programming.
I will be happy to pay a small amount of money for each exercice you help me doing,
if anyone is interested, please contact me here.
(The procedures that we usually have to write are for example:
 Newton-Raphson Method, Chebyshev Polynomial,...  I don't think it is hard for you.
Thank you very time for your time and your help.
First 237 238 239 240 241 242 243 Last Page 239 of 371
