Hi there,
I am trying to compute the following, and I am getting this error.
> A := map(convert, M, unit_free)*Unit('m'*(1/'s'^2));
(I had to put the Unit('m'*(1/'s'^2)) because the original units were kNm/s^2 (kg), and even though I simplified it, it's still using kNm/s^2, and leaves the m/s^2 for some reason when I try to remove the units. I tried simply changing the units on the original matrix, but the units menu has disappeared from the right-click menu!!)
> B := map(convert, K, unit_free);
Loading RealDomain;
solve;
Error, (in assuming) when calling 'Engine:-Dispatch'. Received: 'should not happen: Rename expects the input to contain unknown functions'
Why is it giving me this error? omega is an unknown variable that I am trying to solve for. I am going a modal analysis, so maybe there is a better way to find omega?
Any help appreciated!
Raquel
I have document Maple.mw. I want to copy all text to mathtype. How do I copy and paste?
Link download: maple document
Why does the following not work?
factors(x^4-1)
I have problem with 3Dplotting of this piecewise...can anyone help me please?!
since i know the output will be a value between 0 and 1 can i plot it for different values of Mu in this range to eliminate a dimension?
Mu(x1, x2, x3) = piecewise(`or`(`or`(x1 > 55, x2 > 10), y >= 2), 1, x1 < 35 and x2 <= 10 and x3 < 1, (1/10)*x2, `and`(`and`(x1 < 35 and x2 <= 10, x3 >= 1), x3 <= 2), max((1/10)*x2, x3-1), `and`(`and`(`and`(x1 >= 35, x1 <= 55), x2 <= 10), x3 <= 1), 1-((55-x1)*(1/20))((10-x2)*(1/10)), `and`(`and`(`and`(`and`(x1 >= 35, x1 <= 55), x2 <= 10), x3 >= 1), x3 <= 2), max(x3-1, 1-((55-x1)*(1/20))((10-x2)*(1/10))))
Thank you very much in advance...
Maple show "
Error, (in simplify/hypergeom/baseHG) Maple was unable to allocate enough memory to complete this computation. Please see ?alloc"
after I finish the equations set and run it.
what's the reason?
I have one probem in using Maple in comparison with Matlab.
Generally, when using Matlab, I write a long program with 500 lines (for example) and where I use some matricial calculations and other. When I want to repeat this program for some parameters (variables) many times, I transform the program to a procedure "Function" with just adding the command Function in the start of the program.
When using Maple, I have a difficulty to transform a long program which I want to repeat for some variables to a procedure "proc". The program uses packages like LinearAlgebra and other procedures.
Is there a simple way to transform a long Maple program to a procedure which should be repeated many times for some variables in Maple.
I have especially problems with the commands local, global, use (for packages), etc.. and the warning related to the variables. It is not easy for a long program with many variables to write them in local or global variables.
I find mapleform software   but I dont know how to use , and does anyone know another method to convert.  I know use
> with(MmaTranslator);
> MmaToMaple();
I can  automatically translated .nb files.  but this have
Error, (in readline) file or directory does not exist
another Error, missing operator or `;`
also I try to use
> FromMmaNotebook(Mma_notebook_filename, options);
I still dont know how is works?  can you explains for me and show me some example  , here is my example files.plot.zip
I need to model some spherical joints with damping.
Apparently, contrary to revolute joints, it seems that it is not possible to add damping in spherical joints. Indeed, contrary to the revolute joint where there is an option to put spring or damping element, i don't find this option in the spherical joint.
Do you have a idea to model spherical joints with damping (without changing the spherical joint)?
Thanks a lot for your help
During a lengthy computation of mine - done using a well established and scientifically sensible external package - I get a Too many level of recursion error in PDEtools/NumerDenom.
Since it has always worked fine for simpler computation with the exact same code, I am wondering whether, with a bigger bound of the level of recursion, the computation could be succesful.
Which is the max level of recursion than maple allows?
Is it possibile to manually (at one's own risk) raise it, in the same line as raising, for instance, stacklimits kernel option?
I want to simulating a mulitibody system, similar circular motion.
schematic diagram:
result:
Why the ball cannot keep on the circle?
 why_split.msim
When I print a Table with graphs in it, the graphs are compressed vertically to an extreme extent. There has to be some compression from the screen, of course, since I have a wide-screen (although the actual worksheet does not use the whole screen width because of the palette and the fact that I don't use full-screen mode. However, the vertical compression  (that is, in a direction where there is plenty of room on the page) is many times more than the horizontal compression. In order to get the printed graph to look normal, I have to stretch the screen graph vertically an extreme amount, which, of course, looks horribly distorted on the screen.
Also when printing a graph as part of a Table, the graph area is clipped so that the title and legend do not print.
I thought that the Table struction would be a good way to display related graphs. But this behavior is making the use of Tables tedious and much less satisfactory because of the missing titles and legends.
None of these things happen when I print a graph in a regular execution group outside a Table structure.
Has anybody else had this problem, and have you found a way to avoid the compression and get the legends?
I have been trying to fit a function to experimental data. To do this i was using
The data is of the type
When I use initialvalues, I get a result, that fits the data well, but is clearly not the desired minimum. Maple delivers g always bigger than 10000 which is nowhere near -7, where it has to be for physical reasons. When using parameterranges I get the error
Warning, no iterations performed as initial point satisfies first-order conditions.
He stopps computing and simply prints out my initialvalues or the first value that is in the parameterrange with a huge RSS.
How can I use initialvalues and parameterranges together for my data?
Hey
As a lot of people before me I'm severely dissappointed my Maple's ability to export a .mw file to .tex.
The output looks horrible and even disappears off the side of the page in some places.
I've searched far and wide on the internet but it's difficult for me to understand the few, outdated, results I've dug up.
Is it completely impossible to get my hands on a good (or just working) Maple 18 to LaTex exporter? It's not possible for me to begin coding my own.
Hi all, I am new to MAPLE, I have been using Mathematica mostly. Here is what i am trying to do in MAPLE,
Use the procedure plotmotion 2 on the plotmo worksheet to animate the motion of a marble in a bowl of the shape of the bottom half of the ellipsoid x^2/16 + y^2/12 +z^2/9 = 1
Can anyone help? It will be greatly appreciated.
Hi Maple People,
I got stuck trying to write a procedue for my project today.  My topic is Prime Constellations.
If you want to help me, please read my primer on constellations
https://docs.google.com/viewer?a=v&pid=sites&srcid=ZGVmYXVsdGRvbWFpbnxwcmltZWNvbnN0ZWxsYXRpb25zfGd4OjNmOWZlNWQxZDY2ODY4YmQ
The procedure should refine an offset Vector and increase a multiplier scalar.
I want to delay putting the broken procedure until I can simplify it and try again.
Matt Anderson
First 239 240 241 242 243 244 245 Last Page 241 of 371
