I want to translate my maple code with matrice multiplication  to C code. But the command  "Multiply" cannot be translated. So I want to edit the function translation by myself. I use "AddFunction" command to create a new function  "Multiply" and want to specify its corresponding C code.
f := proc ()
local x,y;
x := Matrix([[1, 2], [3, 4]]);
y := Matrix([[1,3],[4,2]]);
Multiply(x, y);
NULL;
LanguageDefinition:-Define("NewC", extend = "C", AddFunction("Multiply", [Matrix,Matrix]::Matrix,
proc (X, Y)
local a,b;
a := 2;
b := convert(a, string);
Printer:-Print("Mmultiply(", X);
Printer:-Print(",", Y, ")"); Printer:-Print("\n");
Printer:-Print("from", b, "to");
Printer:-Print(",", Y, "do") end proc, numeric = double));
Translate(f, language = "NewC")
But when I run it, the "Multiply" function cannot be translated.  The result is:
Warning, type signature [CodeGeneration:-Names:-ArrayType(integer,CodeGeneration:-Names:-ArrayRanges(1 .. 2,1 .. 2),CodeGeneration:-Names:-ArrayOptions()), CodeGeneration:-Names:-ArrayType(integer,CodeGeneration:-Names:-ArrayRanges(1 .. 2,1 .. 2),CodeGeneration:-Names:-ArrayOptions())] for function Multiply is not recognized
void f (void)
  int x[2][2];
  int y[2][2];
  x[0][0] = 1;
  x[0][1] = 2;
  x[1][0] = 3;
  x[1][1] = 4;
  y[0][0] = 1;
  y[0][1] = 3;
  y[1][0] = 4;
  y[1][1] = 2;
  Multiply(x, y);
I don't know why "Multiply(x,y)" cannot be translated.
If I put two "Multiply(x, y)" in the procedure, like this:
f := proc ()
local x,y;
Multiply(x, y);
Multiply(x, y);
NULL;
proc (X, Y)
local a;
a := 2;
THe result is:
Warning, cannot resolve types, reassigning x's type
Warning, cannot resolve types, reassigning y's type
Error, (in CodeGeneration:-IssueError) type 'Matrix' cannot be translated to target language
I don't know why type 'Matrix' cannot be translated.
Maplesim 7.0(1) installer looks for Maple 18 installation.  Will Maplesim work with Maple 2015?
If not, what is the expected date of making both products compatible?
G
integral.mw
Hi all, I want the best for you.
I really have confused with this bad integral (HeunB)which I've got it 2 weeks ago from a solution by Maple 17. I should solve this one to solve the derivative of this too.
Help me please, I attached the attribute file.
Regards.
It's been a while since I have used Maple. To be honest I haven't used it for over six years.
I am trying to solve simple differential equations, however I have many issues.
I am trying to simulate what author of this paper did 06421188.pdf
My file looks like this (Pendulum.mw)
Can someone help me to simulate this system? I simply can't remember how to do it.
Cheers,
Bart
Attached is a photo with the code I am working for.
On the top is practice code with a simpler ODE to help with trouble shooting, on the bottom is the ODE I am working with.
I was hoping to gain insight about the _z1 symbol in the solution, I haven't been able to find much help on other threads.  I would like to know how I can go about working with it - if it is something on my end or if it is the nature of the equation I am working with.
Thank you for any help,
Josh
I have a nice procedure that is as follows, that explores the behaviour of a mapping in R^2.
InversePoincare := proc (v) options operator, arrow; v*Norm(v, 2)/(1-Norm(v, 2)^2) end proc
SphereVectorPlot := proc (T, radius, radiusIncrements, angleIncrements, lengthParam)
local listOfPairs;
listOfPairs := {seq(seq([[radius*r*cos(2*angle*Pi/angleIncrements)/radiusIncrements, radius*r*sin(2*angle*Pi/angleIncrements)/radiusIncrements], T(InversePoincare(`<,>`(radius*r*cos(2*angle*Pi/angleIncrements)/radiusIncrements, radius*r*sin(2*angle*Pi/angleIncrements)/radiusIncrements)))-InversePoincare(`<,>`(radius*r*cos(2*angle*Pi/angleIncrements)/radiusIncrements, radius*r*sin(2*angle*Pi/angleIncrements)/radiusIncrements))], r = 0 .. radiusIncrements), angle = 0 .. angleIncrements)};
if lengthParam = false then
 return arrow(listOfPairs, scaling = constrained, shape = arrow)
 return arrow(listOfPairs, length = lengthParam, scaling = constrained, shape = arrow)
end if
Essentially, we plot vectors v at location u. Since the vectors v in general vary wildly in magnitude, I would like to visualize the magnitude change by using color and/or transparency, preferably the latter. Is it possible to do so, and if so, how?
I have modeled a slidercrank with absolute coordinates.
I have a slight problem when I want to mesure the Euler angles with Euler angle sensors.
In fact, the angle of the crank around the z axis (gamma1) always stay betwen -pi and pi. I would have like to see the value of my angle always increases with the evolution of the time since I impose a constant torque on the crank.
How can I do to observe the Euler angles of a body (parameterized with absolute coordinates) without any limit between [-pi,pi]?
PS: I insert my model attached
slidercrank_3D_AC.msim
Hello everyone. I am trying to make a position time graph of a charged particle in an gravitational and electric field. This is just for an application of Maple to Lagrangian mechanics. I have set up my Lagrangian, did the Euler-Lagrange equation, and solved the differential equation. When I go to plot it, just the axes show up and I dont have a line. I have followed other examples of Lagrangian mechanics in Maple and its still not working. Here is the code for the odeplot:
Eq7:=dsolve({Eq6,initial},{q(t)},numeric,output=listprocedure)
odeplot(Eq7,t=0..10)
Eq6 is the Euler-Lagrange equation for my system, initial is the initial values, and q(t) is the position of the particle.
Any suggestions will help.
If i have to solve the eq. i have to guess what U2 is  until i get close to U1 that the error is ok. can i do this in maple. or du i have to make program.
Recently a a simple problem which i can not handle by myself, made me confused.
I have simple code of maple which is not stable at all. Everytime I run the code, the final result which is the determinant of a matrix, changes and I can not see the problem with the code. In fact i noticed that problem occures when the matrix is being build by culculating the coefficients of some constant values.  I have attached the code. Could you see what is wrong here?
Thanks by the way.
Download Code.mw
The default way a prompt shows on my maple is
[> blah blah blah
but i see in many worksheets including maple help pages that it shows as
> blah blah blah
My Question is how do i remove that left square bracket "[" from appearing ?
   Hi, there
 I work with maple 13 and made a file that its contet is plotting curves and its size is
151 MB.Now when I want to open it the file cannot be opened completely only about a quarter of its contents rises.
Thanks for your help
REGARDS
Yegan
hi, is there a way to change color of the page in Maple 18? in fact I am preparing my lectures using slideshow option and want to change the color instead of the default white.
Hi guys,
       I have the following Lagrange function.
       (Note :w is the generalized co-cordinate.)
       L := (diff(w(r, t), t, r))*v(r, t)
       ( I know
        If L =diff(w(t),t)*v(t)..... I can write EulerLagrange(L,t,w(t) but I dont know how to handle above function)
        Thanks in advance!!!
First 242 243 244 245 246 247 248 Last Page 244 of 371
