I am having issues opening my final year project, it was working an hour ago and now it will not open. When I try to open the file it brings up a box title TEXT FORMAT CHOICE with the options: MAPLE TEXT, PLAIN TEXT, MAPLE INPUT and CANCEL.
This is all my work and I need it to complete my year.
Any help with how I can rectify this would be extremely helpful.
Many thanks
Some maple worksheets are created in other languages (spanish, german, french, russian, etc...) , I attempted to use google translate but it is a paid service.  There are alternate free translators however I can't seem to get any of them working using the URL package.
I'm trying to send data to http://translation.babylon.com/english/to-spanish/
Using similar code from my previous question with google translate we end up with a huge mess and no embedded translations in the code.
s := "The quick brown fox jumps over the lazy dog":
result := URL:-Get(StringTools:-FormatMessage("http://translation.babylon.com/english/to-spanish/", s));
Any suggestions?
I am trying to optimize a 39, 1 MATLAB matrix, but cannot seem to get a result beyond a 6, 1 matrix. I am getting "Warning, cannot resolve types, reassigning t##'s type" where t## varies from each time I run it, and can show multiple of these warnings. It also says "Warning, cannot translate list".
I found a pretty similar problem posted here earlier, where the user "Carl Love" suggested to replace a command from the original code with
Matlab(
     subsop([-1,1]= J, eval([codegen:-optimize](tmp, tryhard), pow= `^`)),
     output = string, defaulttype = numeric
I was wondering what exactly this command does? Can I apply it to my code to solve my problem? It yielded a result that looks (on the surface) as an optimized code, but I don't feel completely comfortable using it without being certain.
What I have done is simply to replace Matlab(tmp, optimize) with the suggested code above. My code is attached. Thanks in advance for any help.
OptiMatrix.mw
I'm, trying to write a nested loop in maple, but I keep getting the Unterminated Loop error. I'm sure the solution is quite simple, but I haven't been able to find it. Any suggestions would be much appreciated. The loop looks like this:
i:=0:
di:=25:
n:=1:
while (n<=nLimit) do
sol1:=fsolve(eq1, y=i..i+di)
     if type(sol1, numeric) = true then
     lambda(n) :=sol1
     i:=i+di
     n:=n+1
     else  i:=i+di
Most of the worksheets in the maple application center with embedded components do not allow the implicit codes to be seen. Right clicking on the component property (edit click action) does show the codes.
Can anyone please tell me how to have access to these codes in other to see the interaction between the different components (table, plot, bottoms,etc)? Thank you very much.
John.
The physics package is pretty awesome, but one thing that would be a big help is some functionality for entering and resolving vectors in angle/magnitude format (50 angle 45 degrees, or what have you.) Is there a way to do this?
Joe
Evaluation of Primitive Hydrogenic Coulomb & Exchange Integrals
I would appreciate if someone would check my worksheet wherein these integrals are evaluated applying the method of Eyring, Walter, & Kimball, p 396, Quantum Cemistry, Wiley (1944).
Please write me at cordes@stny.rr.com, and I'll email you a MAPLE worksheet.
Thank you for your consideration.
     I want to know what K1 and K2 means in the answer after using Euler Lagrange command.
Sum(a^(k/a^k), k= 1..n);
Hej hej,
is there a way to obtain confidence intervals for the parameters in a NonlinearFit? To give you an impression of the problem which I was working on, I created a minimial working example (not sure wheather that actually helps). In this particular case, I have two parameters to fit the coefficients of a binomial series to some data I obtained. Beyond the values of the parameters (in a least square fit), I'm also interested in some kind of confidence interval, to get a feeling about how realiable my values are. Is there a direct (or even indirect) way to obtain such a thing. Either directly as a Maple function (confidenceintervals is not supported for NonlinearFit, if I'm not mistaken) or as something I can implement myself (within a reasonable time frame, as in hours rather than days).
Thanks in advance!
Cheer,
Sören
restart; with(plots); with(Statistics)
alpha[0] := 1.000000000:
m__max := 4:
model := Fit(pochhammer(z__1, m)*h__exp^m/factorial(m), [seq(m, m = 0 .. m__max)], [seq(alpha[m], m = 0 .. m__max)], m, output = [leastsquaresfunction, residuals], weights = [seq(1/abs(alpha[m]), m = 0 .. m__max)], iterationlimit = 10000)
model := [pochhammer(1.42349754368085, m)*16.2763580438677^m/factorial(m), Vector[row](5, {(1) = 0., (2) = -0.120508651249829e-1, (3) = 0.113910530162494e-1, (4) = 0.348907003220054e-3, (5) = -0.305508272150429e-2})]
plots[multiple](logplot, [{seq([m, alpha[m]], m = 0 .. m__max)}, style = point, color = black], [{seq([m, model[1]], m = 0 .. m__max)}])
Download nonlinearfit-problem.mw
I'm trying to use Maple to show that the Hilbert transform of the natural log of |H(jw)| is -arctan(H(jw))
for a minimum phase network; The network I choose is the simplest filter there exists i.e. a low pass RC-filter
with transfer function H(jw)=1/(1+tau*j*omega) therefore |H(jw)|=1/sqrt(1+(tau*omega)^2))
Here is what I did:
assume(omega > 0); assume(tau > 0); interface(showassumed = 0);
result5 := (int((1/2)*log(1+(tau*nu)^2)/(nu-omega), nu = -infinity .. infinity, CauchyPrincipalValue))/Pi
simplify(result5, symbolic)
unfortunately this does not give me the expected result: -arctan(w*tau*omega)
can anyone here tell me what the right way to do it is?
thanks in advance
hugo
Dear Community Members,
We have problem with calculation in Maple v11 and v18. when we make a calculation by using maple v11 and v18, we was not able to get the solution as you see enclosed. when we clicked to "enter + ; ", programme does not run.
I want to know, how one can install third party package into Maple13, the package is "wkptest" i downloaded it from link http://cpc.cs.qub.ac.uk/summaries/ADTY. If anyone knows how to do this please help.
When I create a component, here a label component, and set a name property and then click OK, that name seems to go into some list never to be erased. If I then delete the first name and put in a new name and click OK. thus saving it, and the then try to use that name again on a different component, I am told that the name is already in use. Well, no existing component has the name, but it is still in Maple's list of components. If I go to edit an action for any component and input %+command completion, I get a list of components which includes the deleted name which does not belong to any existing component. Since the name is on this list, I cannot reuse the component name.
How do I clean up this erroneous list of component names, so that a mistake in naming one component doesn't forever prevent me from using it on the component for which it was intended?
I run the same notebook in Maple 2015 that I used to run in Maple 18.02.
I noticed that it no longer auto-scroll when the print messages reached the bottom of the window as it did with Maple 18.02. This means, I can't see which line the computation is at at the moment, since I can't see the last line printed (it is not visible), without me having to manually use the vertical slider to scroll down trying to catch up with it. But it is hard to do this all the time.  It starts to scroll ok until the last printed message reached the bottom of the window, but then it stops.
This is very annoying, becuase I'd like to see the messages as it is running, so I know which equation is being solved when I look at the screen.  The messages are like this, with some print message I put in the loop
memory used=0.53MiB, alloc change=0 bytes, cpu time=16.00ms, real time=7.00ms, gc time=0ns
*** loop counter 100
etc..
Is there an option one has to configure to make the screen scoll with the output? I looked but do not see one now.
I do not remember having to do anything in Maple 18.02. It seems natural that it should scroll down as messages are being displayed. This is how all apps work.
I am using Maple 2015, windows 7, 64 bit OS and 64 bit Maple. Using Worksheet, was created in Maple 18.02. Other than this, everything else works ok so far.
Standard Worksheet Interface, Maple 2015.0, Windows 7, February 17 2015 Build ID 1022128
thank you
First 243 244 245 246 247 248 249 Last Page 245 of 371
