I am trying to solve a large nxl system of coupled differential equations. Maple seems to have trouble even for small n's so I wanted to know if anyone has any suggestions. Take the case of the following system of ODEs for my unknown functions f[0,0](x) and f[1,0](x).
ODEs:= {diff(f[0, 0](x), x)+2.*f[0, 0](x)/x^5+.5000000000*f[0, 0](x)/x = -15.58845727*sin(.5773502693*x)/x^2+140.2961154*sin(.5773502693*x)/x^4-81.*cos(.5773502693*x)/x^3, diff(f[1, 0](x), x)+6.*f[1, 0](x)/x^5+1.500000000*f[1, 0](x)/x-1.*f[0, 0](x)/x = -15.58845727*sin(.5773502693*x)/x^2+25.98076212*sin(.5773502693*x)*(1/x^4)^(1/4)*exp(1/x^4)*GAMMA(.7500000000, 1/x^4)/x^2+140.2961154*sin(.5773502693*x)/x^4-233.8268591*sin(.5773502693*x)*(1/x^4)^(1/4)*exp(1/x^4)*GAMMA(.7500000000, 1/x^4)/x^4-81.*cos(.5773502693*x)/x^3+135.*cos(.5773502693*x)*(1/x^4)^(1/4)*exp(1/x^4)*GAMMA(.7500000000, 1/x^4)/x^3-20.78460970*sin(.5773502693*x)/x^6+6.000000004*cos(.5773502693*x)/x^5+62.35382908*sin(.5773502693*x)/x^8-36.00000002*cos(.5773502693*x)/x^7, f[0, 0](.1) = 1.503497680, f[1, 0](.1) = -.5011660086}
Following Preben Alsholm's suggestion from my previous thread I am using lsode[adamsfull], since no other method i have tried worked for this problem. I am currently using:
Sollsodefull:=dsolve({ODEs}, numeric, method = lsode[adamsfull])
and it seems to work. I am wondering if there is a way to optimize this, as I will be extending my problem to n and l much larger than order unity numbers, therefore my system will contain about 10^4-10^5 equations. Solving this symple system of 2 equations takes a bit less than a second, but still it takes some time for the processor on my MBP. I am affraid it will be a nightmare for the full problem. Whats the most optimal dsolve option for this kind of problem? Any ideas?
I have also attempted dverk78, rkf45,rosenbrock, lsode(without the adamsfull option), and all failed for this particular system. Errors were:
1. For rkf45: Error, (in f00) cannot evaluate the solution past the initial point, problem may be complex, initially singular or improperly set up
2. For dverk78: Error, (in Soldverk78) cannot evaluate the solution past .1, step size < hmin, problem may be singular or error tolerance may be too small
3. For rosenbrock: Error, (in dsolve/numeric/SC/firststep) unable to evaluate the partial derivatives of f(x,y) for stiff solution
4. For lsode without [adamsfull]: Error, (in Sollsode) an excessive amount of work (greater than mxstep) was done
5. For default method with stiff=true and inplicit=true options: Error, (in dsolve/numeric/SC/firststep) unable to evaluate the partial derivatives of f(x,y) for stiff solution
I want to use the Maple Compiler to improve the performance of some of my codes. To get used to it, I tried doing the examples from the ?Compiler help-page, but everytime I run the compiler, I get the error message:
"Error, (in Compiler:-Compile) compiler exited with nonzero status 1:
Do some of you know a possible reason for this?
Thank you all.
Download test.mw
Please give me the matlab coding for plot together of attach figure by matlab.fig
thanks...!
is there a way I can use data (variables) from Maple environment in the Maplesim environment.
I have a scirpt in maple that generates the robots joints angles and need to use them in the 3D robot built in maplesim. I know I can export/Import data, but this sounds redundant. Is there a way to simply use an input block as a source of the data in maplesim and have the variable name generated in maple used int. Similar to what Matlab/Simulink does..
thanks.
Могу ли я использовать Клен, чтобы найти конкретные решения, которые выражаются либо в начальных и эллиптических функций для систем обыкновенных дифференциальных уравнений. Например, вы можете получить в Maple решений (sub_Solve01, sub_Solve02) для систем, которые перечислены в файле?
exp01.mw
I have a system of pdes and solved numerically using pdsolve (numeric) command.
The system consists of four first order partial differentia equations.
for example u(x,t), R(x,t)....
what command should I give to the Maple and get the graph of u(x,t) at a specific point x_0?
For example, I need a plot for u(30,t).
Is it possible with the maple plot?
I really appreciate your help.
Thank you for reading this post. :)
So this is my minimal working code. Everything works, but I cannot get the arrow size fixed you can see the animation propperly. Adding wid=1/2 gives an error message.
Is there a way to export worksheet to pdf format but not in A4 size since some lines are going beyond the page?
restart; with(Physics); with(Tetrads); with(PDETools)
0, "%1 is not a command in the %2 package", Tetrads, Physics
coords := zetabar, zeta, v, u
zetabar, zeta, v, u
X = [coords]
X = [zetabar, zeta, v, u]
ds2 := Physics:-`*`(Physics:-`*`(2, dzeta), dzetabar)+Physics:-`*`(Physics:-`*`(2, du), dv)+Physics:-`*`(Physics:-`*`(2, H(coords)), Physics:-`^`(du+Physics:-`*`(Ybar(coords), dzeta)+Physics:-`*`(Y(coords), dzetabar)-Physics:-`*`(Physics:-`*`(Y(coords), Ybar(coords)), dv), 2))
2*dzeta*dzetabar+2*du*dv+2*H(zetabar, zeta, v, u)*(du+Ybar(zetabar, zeta, v, u)*dzeta+Y(zetabar, zeta, v, u)*dzetabar-Y(zetabar, zeta, v, u)*Ybar(zetabar, zeta, v, u)*dv)^2
PDEtools:-declare(ds2)
Ybar(zetabar, zeta, v, u)*`will now be displayed as`*Ybar
vierbien := Matrix([[1, 0, -Ybar(coords), 0], [0, 1, -Y(coords), 0], [Physics:-`*`(H(coords), Y(coords)), Physics:-`*`(H(coords), Ybar(coords)), 1-Physics:-`*`(Physics:-`*`(H(coords), Y(coords)), Ybar(coords)), H(coords)], [Y(coords), Ybar(coords), -Physics:-`*`(Y(coords), Ybar(coords)), 1]])
vierbien := Matrix(4, 4, {(1, 1) = 1, (1, 2) = 0, (1, 3) = -Ybar(zetabar, Zeta, v, u), (1, 4) = 0, (2, 1) = 0, (2, 2) = 1, (2, 3) = -Y(zetabar, Zeta, v, u), (2, 4) = 0, (3, 1) = H(zetabar, Zeta, v, u)*Y(zetabar, Zeta, v, u), (3, 2) = H(zetabar, Zeta, v, u)*Ybar(zetabar, Zeta, v, u), (3, 3) = 1-H(zetabar, Zeta, v, u)*Y(zetabar, Zeta, v, u)*Ybar(zetabar, Zeta, v, u), (3, 4) = H(zetabar, Zeta, v, u), (4, 1) = Y(zetabar, Zeta, v, u), (4, 2) = Ybar(zetabar, Zeta, v, u), (4, 3) = -Y(zetabar, Zeta, v, u)*Ybar(zetabar, Zeta, v, u), (4, 4) = 1})
Physics:-Setup(coordinatesystem = (X = [zetabar, zeta, v, u]), metric = ds2, tetrad = vierbien, mathematicalnotation = true, automaticsimplification = true, signature = "+++-")
RicciT := proc (a, b) options operator, arrow; Physics:-SumOverRepeatedIndices(Ricci[mu, nu]*e_[a, `~mu`]*e_[b, `~nu`]) end proc
proc (a, b) options operator, arrow; Physics:-SumOverRepeatedIndices(Physics:-`*`(Physics:-`*`(Physics:-Ricci[mu, nu], Physics:-Tetrads:-e_[a, `~mu`]), Physics:-Tetrads:-e_[b, `~nu`])) end proc
SlashD := proc (f, a) options operator, arrow; Physics:-SumOverRepeatedIndices(Physics:-D_[mu](f)*e_[a, `~mu`]) end proc
proc (f, a) options operator, arrow; Physics:-SumOverRepeatedIndices(Physics:-`*`(Physics:-D_[mu](f), Physics:-Tetrads:-e_[a, `~mu`])) end proc
SlashD(H(X), 4) = H(X)[4]
(diff(H(X), zetabar))*Ybar(X)+(diff(H(X), zeta))*Y(X)+diff(H(X), v)-(diff(H(X), u))*Y(X)*Ybar(X) = H(X)[4]
Gamma := proc (a, b, c) options operator, arrow; -gamma_[a, b, c] end proc
proc (a, b, c) options operator, arrow; Physics:-`*`(Physics:-Tetrads:-gamma_[a, b, c], -1) end proc
Gamma(1, 4, 4) = 0
-(diff(Ybar(X), u))*Y(X)*Ybar(X)+Y(X)*(diff(Ybar(X), zeta))+Ybar(X)*(diff(Ybar(X), zetabar))+diff(Ybar(X), v) = 0
Gamma(2, 4, 4) = 0
-(diff(Y(X), u))*Y(X)*Ybar(X)+Y(X)*(diff(Y(X), zeta))+(diff(Y(X), zetabar))*Ybar(X)+diff(Y(X), v) = 0
Gamma(3, 4, 4) = 0
0 = 0
Gamma(4, 4, 4) = 0
0 = 0
Gamma(4, 1, 1) = 0
-(diff(Ybar(X), zeta))+(diff(Ybar(X), u))*Ybar(X) = 0
(15)
Gamma(4, 2, 2) = 0
-(diff(Y(X), zetabar))+(diff(Y(X), u))*Y(X) = 0
(16)
shearconditions := {-(diff(Y(X), zetabar))+(diff(Y(X), u))*Y(X) = 0, -(diff(Ybar(X), zeta))+(diff(Ybar(X), u))*Ybar(X) = 0, -(diff(Y(X), u))*Y(X)*Ybar(X)+Y(X)*(diff(Y(X), zeta))+(diff(Y(X), zetabar))*Ybar(X)+diff(Y(X), v) = 0, -(diff(Ybar(X), u))*Y(X)*Ybar(X)+Y(X)*(diff(Ybar(X), zeta))+Ybar(X)*(diff(Ybar(X), zetabar))+diff(Ybar(X), v) = 0}
(17)
simplify(RicciT(1, 2), shearconditions) = 0
H(X)*(diff(diff(Y(X), zeta), zetabar))*Ybar(X)-H(X)*Ybar(X)*Y(X)*(diff(diff(Ybar(X), u), zetabar))-H(X)*Ybar(X)^2*(diff(diff(Y(X), u), zetabar))-H(X)*Y(X)^2*(diff(diff(Ybar(X), u), zeta))-2*H(X)*Y(X)*Ybar(X)*(diff(diff(Y(X), u), zeta))+H(X)*Y(X)^2*Ybar(X)*(diff(diff(Ybar(X), u), u))-H(X)*Y(X)*(diff(diff(Ybar(X), u), v))+H(X)*Y(X)*Ybar(X)^2*(diff(diff(Y(X), u), u))-H(X)*(diff(diff(Y(X), u), v))*Ybar(X)+H(X)*(diff(Ybar(X), zetabar))^2+(-3*H(X)*Y(X)*(diff(Ybar(X), u))-(diff(H(X), u))*Y(X)*Ybar(X)+(diff(H(X), zeta))*Y(X)+(diff(H(X), zetabar))*Ybar(X)+diff(H(X), v))*(diff(Ybar(X), zetabar))+H(X)*(diff(Y(X), zeta))^2+(-4*H(X)*(diff(Y(X), u))*Ybar(X)-(diff(H(X), u))*Y(X)*Ybar(X)+(diff(H(X), zeta))*Y(X)+(diff(H(X), zetabar))*Ybar(X)+diff(H(X), v))*(diff(Y(X), zeta))+2*H(X)*Y(X)^2*(diff(Ybar(X), u))^2-Y(X)*((diff(H(X), zetabar))*Ybar(X)+(diff(H(X), zeta))*Y(X)+diff(H(X), v)-(diff(H(X), u))*Y(X)*Ybar(X))*(diff(Ybar(X), u))+2*(H(X)*(diff(Y(X), u))*Ybar(X)+(1/2)*(diff(H(X), u))*Y(X)*Ybar(X)-(1/2)*(diff(H(X), zeta))*Y(X)-(1/2)*(diff(H(X), zetabar))*Ybar(X)-(1/2)*(diff(H(X), v)))*(diff(Y(X), u))*Ybar(X) = 0
(18)
0 = 0
0 = 0
(19)
The values in the paraenthesis  should substitute H[4]. This sequence works in Maple 18 but not in Maple 2015
Download Question_algsubs_3.27.15.mw
Write a Maple code that performs the Gaussian elimination for an nxn matrix, converting it to an upper triangular matrix.
(Hint: you will need to use three for .. do loops.)
I want to make the model which moves along the specific direction (translational), So I used the "prismatic joint" to give the direction that I want to enforce. However, "Prismatic joint" only offers the direction along the "X", "Y", and "Z" axes though I want to give other direction.
Is there any way to give the specific direction (vector) to make my model move in that way ?
hello
i have some problem when iuse the digital libray with the delay components:
i have this error: delay variable not found in dependent variable list, [`Main.TransportDelay1.x`(T)]
it seems that the delay function in the modelica language is not well treated in MapleSim . At this level:
equation
    y = if 0 < delayTime then if delayTime <= time then x_delayed else y0 else pre(x);
    x_delayed = integer(delay(x, delayTime));
end Modelica.Electrical.Digital.Delay.TransportDelay;
I'm trying to use the command: DocumentTools[Retrieve](path,label), but i recieve the message "unable to retrieve label reference" no mather what i do. When i use the GUI: Insert - reference and get the value it works fine, but in that way I can't assign the value to a variable in the document.
here is an example:
The document i want to retrieve a value from:
a := 5;
#a gets the label (1)
The document i want to retrieve the value to:
with(DocumentTools);
path := FileTools:-JoinPath(["test.mw"], base = worksheetdir); = "C:\Users\Nicolai\CloudStation\Nicolai\Skole stof\Sem 7\test.mw"
Retrieve(path, "());
Retrieve(path, "(1)");
Retrieve(path, "a");
#None of the above works
Is it even possible to do such thing?
with best regards
Nicolai
I tried to use the Finance package and got:
with(Finance):
Warning, some commands in the Finance package may not work on this platform
Y := ItoProcess(1.0, mu, sigma, x, t);
Error, (in Finance:-ItoProcess) external linking: error loading external library finance.dll: The specified module could not be found.
Is it me or my pc that is causing this?
Murray
Hi:
I would like to slightly modify the "Explore" command -- I find it extremely useful, but the layout often doesn't work well for me (my typical use case is say 12 plots with ~10 parameters that vary). The problem is that the default alignment the columns of the table that contains a matrix of plots is "Center" and my plots don't fit on the screen properly (no matter how I play with sizes, placement, etc) and I would like it to be "Left" aligned --- aligning things manually (via right click) after the explore command is executed is possible, but painful, given that I often change my code.
... bottom line is that I would like to be able to re-define the "Explore" command.
I tried doing so by first calling:
showstat(Explore);
... then removing all the numbers, renaming the proc to sat MyExplore, declaring it (i.e. so maple understands it) and for now using that instead of the old Explore in my program (with no actual code changes for now). The problem is that I get the following error:
Error, (in DocumentTools:-Layout:-Table) number of Column arguments, 3, exceeds total column span, 1, computed from Rows' Cells
I think, somehow maybe showstat is not showing the full thing? or maybe it is part of a more complicated module? or maybe by removing the numbers the formatting got screwed up (i was careful here)?
So my question:
How would I define my own function "MyExplore" that (for now) contains exactly the same code and functionality as the built-in "Explore"?
thanks!
First 241 242 243 244 245 246 247 Last Page 243 of 371
