hi friends
I encountered a problem and I can not draw the plot of this code
> sol := fsolve({diff(S, x) = 0, diff(S, y) = 0}, {x, y});
> with(VectorCalculus);
> with(linalg);
> s1 := evalf(subs(sol, linalg[grad](S, [x, y])));
> with(LinearAlgebra);
> s2 := evalf(subs(sol, linalg[hessian](S, [x, y]))); pmp0 := [x-subs(sol, x), y-subs(sol, y)]; sapprox := s0+evalm(`&*`(`&*`(transpose(pmp0), s2), pmp0));
> with(Statistics);
> with(stats); statevalf[icdf, chisquare[4]](.95);
> with(plottools);
> with(plots);
> with(linalg); ellips := {seq(stats*([statevalf[icdf, chisquare[4]]])(c) = sapprox, c = [.5, .95, .999])};
> plots(ellips(x, y), x = 950 .. 1000, y = 700 .. 750, grid = [50, 50], view = [950 .. 1000, 700 .. 750]);
can you helpe me?Thank you
Dear Friends,
I am solving 6 ODEs using maple15. then i got this error. anyone know abou this? thank you.
problem2.mw
restart:with (plots): B:=1:M:=1:Gr:=0.5:Pr:=3:w:=0.02:blt:=5:Bi:=10:
Eq1:=diff(f(eta),eta,eta,eta)-(diff(f(eta),eta))^(2)+f(eta)*diff(f(eta),eta,eta)+B*H(eta)*(F(eta)-diff(f(eta),eta))-M*diff(f(eta),eta)+Gr*theta(eta)=0;
diff(diff(diff(f(eta), eta), eta), eta)-(diff(f(eta), eta))^2+f(eta)*(diff(diff(f(eta), eta), eta))+H(eta)*(F(eta)-(diff(f(eta), eta)))-(diff(f(eta), eta))+.5*theta(eta) = 0
Eq2:=(1+Nr)*diff(theta(eta),eta,eta)+Pr*f(eta)*diff(theta(eta),eta)+(2/3)*H(eta)*B*(theta1(eta)-theta(eta))=0;
(1+Nr)*(diff(diff(theta(eta), eta), eta))+3*f(eta)*(diff(theta(eta), eta))+(2/3)*H(eta)*(theta1(eta)-theta(eta)) = 0
Eq3:=H(eta)*F(eta)+H(eta)*diff(G(eta),eta)+G(eta)*diff(H(eta),eta)=0;
H(eta)*F(eta)+H(eta)*(diff(G(eta), eta))+G(eta)*(diff(H(eta), eta)) = 0
Eq4:=F(eta)^2+G(eta)*diff(F(eta),eta)+B*(F(eta)-diff(f(eta),eta))=0;
F(eta)^2+G(eta)*(diff(F(eta), eta))+F(eta)-(diff(f(eta), eta)) = 0
Eq5:=G(eta)*diff(G(eta),eta)+B*(f(eta)+G(eta))=0;
G(eta)*(diff(G(eta), eta))+f(eta)+G(eta) = 0
Eq6:=G(eta)*diff(theta1(eta),eta)+l*B*(theta1(eta)-theta(eta))=0;
G(eta)*(diff(theta1(eta), eta))+l*(theta1(eta)-theta(eta)) = 0
bcs:=f(0)=0,(D(f))(0)=1,(D(theta))(0)=-Bi*(1-theta(0)),(D(f))(blt)=0,F(blt)=0,G(blt)=-f(blt),H(eta)=w,theta(blt)=0,theta1(blt)=0;
f(0) = 0, (D(f))(0) = 1, (D(theta))(0) = -10+10*theta(0), (D(f))(5) = 0, F(5) = 0, G(5) = -f(5), H(eta) = 0.2e-1, theta(5) = 0, theta1(5) = 0
L:=[0.5,1,1.5,2];
[.5, 1, 1.5, 2]
for k from 1 to 4 do p:=dsolve(eval({Eq1,Eq2,Eq3,Eq4,Eq5,Eq6,bcs},Nr=L[k]),[f(eta),F(eta),G(eta),H(eta),theta(eta),theta1(eta)],numeric,output=listprocedure);end do:
Error, (in dsolve/numeric/bvp) unevaluated names in system not allowed: {Y[9], Y[10]}
Download problem2.mw
I have generated a picture using pointplot and display that creates a grid of colors based on the angle between vectors and (1,0) in R^2. Each angle is given a unique color via the HSV color space. I would like to provide a legend explaining the colour, something along the lines of
red (brown) green (blue) red
0                Pi                 2*Pi
and possibly
red       (brown)       green
angle1                     angle2
Is there an easy way to do this, or will I have to mess around with a custom pointplot/textplot solution?
Is it possible to use an option similar to range when using lsode method for dsolve? The ODEs I am trying to solve is stiff and will not work with the flag stiff=true or with method=rosenbrock unless i set Digits:=20. I want to avoid doing that as much as possible, since I believe wit will be very taxing, computationally. I have a very large systeom to solve. I found that method=lsode works with the default Digits=15.
However I need to have the solutions in a given range stored for future access and manipulations. Using range gives me an error:
Error, (in dsolve/numeric/an_args/lsode) lsode keyword was range, optional keyword must be one of 'ctrl', 'initial', 'itask', 'output', 'procedure', 'procvars', 'start', 'number', 'abserr', 'relerr', 'maxfun', 'minstep', 'maxstep', 'initstep', 'startinit', 'implicit', 'optimize', 'complex'
I cannot figure out how to use range or something similar with lsode. Anyone knows?
Hi! I have to solve a very large system of ODEs for a set of functions that can be indexed with two integers, n and l, call them f[n,l](x), where n ranges from 1 to an order 1000 number and l ranges from 1 to an order 10 number.
What is the best strategy in dsolve, keeping in mind I will only need to have quick access to the values of the first few such functions, say f[0,0](x) and f[0,1](x) for any given x in a given range. I dont need to store the rest, and trying to store all of them actually will give me a warning about length of output exceeds limit of 1000000. So, having maple output the result of dsolve in a procedural form seems to be what I want. However in doing so, for evey value of x i call the solving procedure maple will solve the system each time, thus taking a long time.
My dilema is: to save storage space and memory I want to use dsolve output as procedures. To save time, when accessing the functions I need (only the first few in the large set of unknown functions that obey the ODE) for a given value of x, I would like maple to have those already stored instead of computing them with each invocation. So, what I need is a somehow split behavior of output. For some of my unknown functions to act as if i use range in dsolve, so that I have access at the values without further computation, and for the rest of the solutions (most of the unknown functions) just keep them in procedural form. How do I achieve this?
Below is a schematic of my probem:
ODEs:={Set of about 10000 coupled ODEs for functions labeled f[n,l] n ranging from 1..1000 and l from 1..10}
dsolve(ODEs,numeric, output=???)#What options to put in dsolve such that I have quick access to f[0,0](x) and f[0,1](x) in a given range (say xmin=0.1 and xmax=10 for example) but not store the rest.
     I have a question regarding pdsolve, or Solve from the PDEtools package. I have a set of equations relating partial derivatives, and I'd like to isolate certain terms without explicitly known the functions. I can do this for a single equation, but not multiple ones. I'm curious if Maple can currently handle a system of eqns like these easily, since I will be increasing the number of eqns in the future. Here's the code
PDEtools:-declare(H=H(x,y,t)):
H(x, y, t)*`will now be displayed as`*H
eq1:= H[tt](x,y,t) = H[xx](x,y,t) + H[yy](x,y,t);
H[tt](x, y, t) = H[xx](x, y, t)+H[yy](x, y, t)
eq2 := diff(H[tt](x,y,t), t) = diff(H[tx](x,y,t), x) + diff(H[ty](x,y,t), y);
diff(H[tt](x, y, t), t) = diff(H[tx](x, y, t), x)+diff(H[ty](x, y, t), y)
eq3 := diff(H[tx](x,y,t), t) = diff(H[xx](x,y,t), x) + diff(H[xy](x,y,t), y);
diff(H[tx](x, y, t), t) = diff(H[xx](x, y, t), x)+diff(H[xy](x, y, t), y)
eq4 :=diff(H[ty](x,y,t), t) = diff(H[xy](x,y,t), x) + diff(H[yy](x,y,t), y);
diff(H[ty](x, y, t), t) = diff(H[xy](x, y, t), x)+diff(H[yy](x, y, t), y)
PDEtools:-Solve(eq3, H[xy]);
H[xy](x, y, t) = Int(diff(H[tx](x, y, t), t)-(diff(H[xx](x, y, t), x)), y)+_F1(x, t)
PDEtools:-Solve({eq1, eq2, eq3, eq4}, H[xy]);
Error, (in pdsolve/sys) the input system cannot contain equations in the arbitrary parameters alone; found equation depending only on {H[tt](x,y,t), H[xx](x,y,t), H[yy](x,y,t)}: H[tt](x,y,t)-H[xx](x,y,t)-H[yy](x,y,t)
Download PDESolveHelp.mw
Hi! I am trying to plot and store in memory some specific combinations of the solutions of the systems of ODEs that I get numerically from dsolve for a particular range of the independent variable.
A particular case for my problem is the following system of stiff ODEs for two unknown functions f[0,0](x) and f[1,0](x) beween xini (where the Initial conditions are defined) and xfin, an arbitrary value of x. Note that rosebrock method does not work, and I can only solve it with lsode[adamsfull] or lsode[backfull]. I am attaching a maple file that shows what I have done.
############## System of ODEs that needs to be solved ####################################
xini := .1
.1
xfin := 2
SystemToSolve := diff(f[0, 0](x), x)+(2./x^5+.5000000000/x)*f[0, 0](x) = -15.58845727*sin(.5773502693*x)/x^2+(46.76537182*(3.*sin(.5773502693*x)-1.732050808*x*cos(.5773502693*x)))/x^4, diff(f[1, 0](x), x)+(6./x^5+1.500000000/x)*f[1, 0](x)-1.*f[0, 0](x)/x = (-15.58845727*sin(.5773502693*x)/x^2+(46.76537182*(3.*sin(.5773502693*x)-1.732050808*x*cos(.5773502693*x)))/x^4)*(1.-1.*(1/x^4)^(1/4)*exp(1/x^4)*GAMMA(.7500000000, 1/x^4))-(1.*(-10.39230485*sin(.5773502693*x)/x^2+(31.17691454*(3.*sin(.5773502693*x)-1.732050808*x*cos(.5773502693*x)))/x^4+(4.*((.8660254040*(3.*sin(.5773502693*x)-1.732050808*x*cos(.5773502693*x)))/x+(.8660254040*((3.*(1.-6./x^2))*sin(.5773502693*x)+10.39230485*cos(.5773502693*x)/x))/x))/((1/x^4)^(1/4)*exp(1/x^4)*GAMMA(.7500000000, 1/x^4)*x^5)))*(1/x^4)^(1/4)*exp(1/x^4)*GAMMA(.7500000000, 1/x^4), f[0, 0](xini) = 1.503498546, f[1, 0](xini) = -.5011661819:
ListProcs := dsolve({SystemToSolve}, numeric, method = lsode[backfull], output = listprocedure):
f00 := eval(f[0, 0](x), ListProcs);
proc (x) local _res, _dat, _solnproc, _xout, _ndsol, _pars, _i; option `Copyright (c) 2000 by Waterloo Maple Inc. All rights reserved.`; if 1 < nargs then error "invalid input: too many arguments" end if; _EnvDSNumericSaveDigits := Digits; Digits := 15; if _EnvInFsolve = true then _xout := evalf[_EnvDSNumericSaveDigits](x) else _xout := evalf(x) end if; _dat := Array(1..4, {(1) = proc (_xin) local _xout, _n, _y0, _ctl, _octl, _reinit, _errcd, _fcn, _i, _yini, _pars, _ini, _par; option `Copyright (c) 2002 by the University of Waterloo. All rights reserved.`; table( [( "complex" ) = false ] ) _xout := _xin; _ctl := array( 1 .. 34, [( 1 ) = (2), ( 2 ) = (.1), ( 3 ) = (.1), ( 4 ) = (1), ( 5 ) = (1), ( 6 ) = (22), ( 7 ) = (0), ( 9 ) = (-.5011661819), ( 8 ) = (1.503498546), ( 11 ) = (0.1e-6), ( 10 ) = (0.1e-6), ( 13 ) = (0), ( 12 ) = (0), ( 15 ) = (0), ( 14 ) = (0), ( 18 ) = (0), ( 19 ) = (0), ( 16 ) = (0), ( 17 ) = (0), ( 22 ) = (0), ( 23 ) = (0), ( 20 ) = (0), ( 21 ) = (0), ( 27 ) = (0), ( 26 ) = (0), ( 25 ) = (0), ( 24 ) = (0), ( 31 ) = (0), ( 30 ) = (0), ( 29 ) = (0), ( 28 ) = (0), ( 32 ) = (0), ( 33 ) = (-1), ( 34 ) = (0)  ] ); _octl := array( 1 .. 34, [( 1 ) = (2), ( 2 ) = (.1), ( 3 ) = (.1), ( 4 ) = (1), ( 5 ) = (1), ( 6 ) = (22), ( 7 ) = (0), ( 9 ) = (-.5011661819), ( 8 ) = (1.503498546), ( 11 ) = (0.1e-6), ( 10 ) = (0.1e-6), ( 13 ) = (0), ( 12 ) = (0), ( 15 ) = (0), ( 14 ) = (0), ( 18 ) = (0), ( 19 ) = (0), ( 16 ) = (0), ( 17 ) = (0), ( 22 ) = (0), ( 23 ) = (0), ( 20 ) = (0), ( 21 ) = (0), ( 27 ) = (0), ( 26 ) = (0), ( 25 ) = (0), ( 24 ) = (0), ( 31 ) = (0), ( 30 ) = (0), ( 29 ) = (0), ( 28 ) = (0), ( 32 ) = (0), ( 33 ) = (-1), ( 34 ) = (0)  ] ); _n := trunc(_ctl[1]); _yini := Array(0..2, {(1) = .1, (2) = 1.503498546}); _y0 := Array(0..2, {(1) = .1, (2) = 1.503498546}); _fcn := proc (N, X, Y, YP) option `[Y[1] = f[0,0](x), Y[2] = f[1,0](x)]`; YP[1] := -15.58845727*sin(.5773502693*X)/X^2+46.76537182*(3.*sin(.5773502693*X)-1.732050808*X*cos(.5773502693*X))/X^4-(2./X^5+.5000000000/X)*Y[1]; if 1/X^4 < 0 then YP[1] := undefined; return 0 end if; if 1/X^4 < 0 then YP[1] := undefined; return 0 end if; YP[2] := (-15.58845727*sin(.5773502693*X)/X^2+46.76537182*(3.*sin(.5773502693*X)-1.732050808*X*cos(.5773502693*X))/X^4)*(1.-1.*evalf((1/X^4)^(1/4))*exp(1/X^4)*GAMMA(.7500000000, 1/X^4))-1.*(-10.39230485*sin(.5773502693*X)/X^2+31.17691454*(3.*sin(.5773502693*X)-1.732050808*X*cos(.5773502693*X))/X^4+4.*(.8660254040*(3.*sin(.5773502693*X)-1.732050808*X*cos(.5773502693*X))/X+.8660254040*(3.*(1.-6./X^2)*sin(.5773502693*X)+10.39230485*cos(.5773502693*X)/X)/X)*evalf(1/(1/X^4)^(1/4))/(exp(1/X^4)*GAMMA(.7500000000, 1/X^4)*X^5))*evalf((1/X^4)^(1/4))*exp(1/X^4)*GAMMA(.7500000000, 1/X^4)-(6./X^5+1.500000000/X)*Y[2]+1.*Y[1]/X; 0 end proc; _pars := []; if not type(_xout, 'numeric') then if member(_xout, ["start", "left", "right"]) then return _y0[0] elif _xout = "method" then return "lsode" elif _xout = "numfun" then return trunc(_ctl[24+trunc(_ctl[1])]) elif _xout = "initial" then return [seq(_yini[_i], _i = 0 .. _n)] elif _xout = "parameters" then return [seq(_yini[_n+_i], _i = 1 .. nops(_pars))] elif _xout = "initial_and_parameters" then return [seq(_yini[_i], _i = 0 .. _n)], [seq(_yini[_n+_i], _i = 1 .. nops(_pars))] elif _xout = "last" then if _ctl[2]-_y0[0] = 0. then error "no information is available on last computed point" else _xout := _ctl[2] end if elif _xout = "enginedata" then return eval(_octl, 1) elif _xout = "function" then return eval(_fcn, 1) elif type(_xin, `=`) and type(rhs(_xin), 'list') and member(lhs(_xin), {"initial", "parameters", "initial_and_parameters"}) then _ini, _par := [], []; if lhs(_xin) = "initial" then _ini := rhs(_xin) elif lhs(_xin) = "parameters" then _par := rhs(_xin) elif select(type, rhs(_xin), `=`) <> [] then _par, _ini := selectremove(type, rhs(_xin), `=`) elif nops(rhs(_xin)) < nops(_pars)+1 then error "insufficient data for specification of initial and parameters" else _par := rhs(_xin)[-nops(_pars) .. -1]; _ini := rhs(_xin)[1 .. -nops(_pars)-1] end if; _xout := lhs(_xout); if _par <> [] then `dsolve/numeric/process_parameters`(_n, _pars, _par, _yini) end if; if _ini <> [] then `dsolve/numeric/process_initial`(_n, _ini, _yini, _pars) end if; if _pars <> [] then _par := {seq(rhs(_pars[_i]) = _yini[_n+_i], _i = 1 .. nops(_pars))}; for _i from 0 to _n do _y0[_i] := subs(_par, _yini[_i]) end do; for _i from _n+1 to _n+nops(_pars) do _y0[_i] := _yini[_i] end do else for _i from 0 to _n do _y0[_i] := _yini[_i] end do end if; _octl[2] := _y0[0]; _octl[3] := _y0[0]; for _i to _n do _octl[_i+7] := _y0[_i] end do; for _i to nops(_pars) do _octl[2*_n+30+_i] := _y0[_n+_i] end do; for _i to 34 do _ctl[_i] := _octl[_i] end do; if _Env_smart_dsolve_numeric = true and type(_y0[0], 'numeric') then procname("right") := _y0[0]; procname("left") := _y0[0] end if; if _xout = "initial" then return [seq(_yini[_i], _i = 0 .. _n)] elif _xout = "parameters" then return [seq(_yini[_n+_i], _i = 1 .. nops(_pars))] else return [seq(_yini[_i], _i = 0 .. _n)], [seq(_yini[_n+_i], _i = 1 .. nops(_pars))] end if else return "procname" end if end if; if _xout-_y0[0] = 0. then return [seq(_y0[_i], _i = 0 .. _n)] end if; _reinit := false; if _xin <> "last" then if 0 < 0 and `dsolve/numeric/checkglobals`(0, table( [ ] ), _pars, _n, _yini) then _reinit := true; if _pars <> [] then _par := {seq(rhs(_pars[_i]) = _yini[_n+_i], _i = 1 .. nops(_pars))}; for _i from 0 to _n do _y0[_i] := subs(_par, _yini[_i]) end do; for _i from _n+1 to _n+nops(_pars) do _y0[_i] := _yini[_i] end do else for _i from 0 to _n do _y0[_i] := _yini[_i] end do end if; for _i to _n do _octl[_i+7] := _y0[_i] end do; for _i to nops(_pars) do _octl[2*_n+30+_i] := _y0[_n+_i] end do end if; if _pars <> [] and select(type, {seq(_yini[_n+_i], _i = 1 .. nops(_pars))}, 'undefined') <> {} then error "parameters must be initialized before solution can be computed" end if end if; if not _reinit and _xout-_ctl[2] = 0 then [_ctl[2], seq(_ctl[_i], _i = 8 .. 7+_n)] else if sign(_xout-_ctl[2]) <> sign(_ctl[2]-_y0[0]) or abs(_xout-_y0[0]) < abs(_xout-_ctl[2]) or _reinit then for _i to 34 do _ctl[_i] := _octl[_i] end do end if; _ctl[3] := _xout; if Digits <= evalhf(Digits) then try _errcd := evalhf(`dsolve/numeric/lsode`(_fcn, var(_ctl))) catch: userinfo(2, `dsolve/debug`, print(`Exception in lsode:`, [lastexception])); if searchtext('evalhf', lastexception[2]) <> 0 or searchtext('real', lastexception[2]) <> 0 or searchtext('hardware', lastexception[2]) <> 0 then _errcd := `dsolve/numeric/lsode`(_fcn, _ctl) else error  end if end try else _errcd := `dsolve/numeric/lsode`(_fcn, _ctl) end if; if _errcd < 0 then userinfo(2, {dsolve, `dsolve/lsode`}, `Last values returned:`); userinfo(2, {dsolve, `dsolve/lsode`}, ` t =`, _ctl[2]); _i := 8; userinfo(2, {dsolve, `dsolve/lsode`}, ` y =`, _ctl[_i]); for _i from _i+1 to 7+_n do userinfo(2, {dsolve, `dsolve/lsode`}, `	 `, _ctl[_i]) end do; if _errcd+1. = 0. then if _ctl[14+trunc(_ctl[1])] <> 0 then error "an excessive amount of work was done, maxstep may be too small" else error "an excessive amount of work (greater than mxstep) was done" end if elif _errcd+2. = 0. then error "too much accuracy was requested for the machine being used" elif _errcd+3. = 0. then error "illegal input was detected" elif _errcd+4. = 0. then error "repeated error test failures on the attempted step" elif _errcd+5. = 0. then error "repeated convergence test failures on the attempted step" elif _errcd+6. = 0. then error "pure relative error control requested for a variable that has vanished" elif _errcd+7. = 0. then error "cannot evaluate the solution past %1, maxfun limit exceeded (see <a href='http://www.maplesoft.com/support/help/search.aspx?term=dsolve,maxfun' target='_new'>?dsolve,maxfun</a> for details)", evalf[8](_ctl[2]) else error "unknown error code returned from lsode %1", trunc(_errcd) end if end if; if _Env_smart_dsolve_numeric = true then if _y0[0] < _xout and procname("right") < _xout then procname("right") := _xout elif _xout < _y0[0] and _xout < procname("left") then procname("left") := _xout end if end if; [_xout, seq(_ctl[_i], _i = 8 .. 7+_n)] end if end proc, (2) = Array(1..3, {(1) = 18446744078356217278, (2) = 18446744078356217454, (3) = 18446744078356217630}), (3) = [x, f[0, 0](x), f[1, 0](x)], (4) = []}); _solnproc := _dat[1]; _pars := map(rhs, _dat[4]); if not type(_xout, 'numeric') then if member(x, ["start", 'start', "method", 'method', "left", 'left', "right", 'right', "leftdata", "rightdata", "enginedata", "eventstop", 'eventstop', "eventclear", 'eventclear', "eventstatus", 'eventstatus', "eventcount", 'eventcount', "laxtol", 'laxtol', "numfun", 'numfun', NULL]) then _res := _solnproc(convert(x, 'string')); if 1 < nops([_res]) then return _res elif type(_res, 'array') then return eval(_res, 1) elif _res <> "procname" then return _res end if elif member(x, ["last", 'last', "initial", 'initial', NULL]) then _res := _solnproc(convert(x, 'string')); if type(_res, 'list') then return _res[2] else return NULL end if elif member(x, ["parameters", 'parameters', "initial_and_parameters", 'initial_and_parameters', NULL]) then _xout := convert(x, 'string'); _res := _solnproc(_xout); if _xout = "parameters" then return [seq(_pars[_i] = _res[_i], _i = 1 .. nops(_pars))] else return [_res[2], seq(_pars[_i] = [_res][2][_i], _i = 1 .. nops(_pars))] end if elif type(_xout, `=`) and member(lhs(_xout), ["initial", 'initial', "parameters", 'parameters', "initial_and_parameters", 'initial_and_parameters', NULL]) then _xout := convert(lhs(x), 'string') = rhs(x); if lhs(_xout) = "initial" then if type(rhs(_xout), 'list') then _res := _solnproc(_xout) else _res := _solnproc("initial" = ["single", 2, rhs(_xout)]) end if elif not type(rhs(_xout), 'list') then error "initial and/or parameter values must be specified in a list" elif lhs(_xout) = "initial_and_parameters" and nops(rhs(_xout)) = nops(_pars)+1 then _res := _solnproc(lhs(_xout) = ["single", 2, op(rhs(_xout))]) else _res := _solnproc(_xout) end if; if lhs(_xout) = "initial" then return _res[2] elif lhs(_xout) = "parameters" then return [seq(_pars[_i] = _res[_i], _i = 1 .. nops(_pars))] else return [_res[2], seq(_pars[_i] = [_res][2][_i], _i = 1 .. nops(_pars))] end if elif type(_xout, `=`) and member(lhs(_xout), ["eventdisable", 'eventdisable', "eventenable", 'eventenable', "eventfired", 'eventfired', "direction", 'direction', NULL]) then return _solnproc(convert(lhs(x), 'string') = rhs(x)) elif _xout = "solnprocedure" then return eval(_solnproc) elif _xout = "sysvars" then return _dat[3] end if; if procname <> unknown then return ('procname')(x) else _ndsol := `tools/gensym`("f[0,0](x)"); eval(FromInert(_Inert_FUNCTION(_Inert_NAME("assign"), _Inert_EXPSEQ(ToInert(_ndsol), _Inert_VERBATIM(pointto(_dat[2][2])))))); return FromInert(_Inert_FUNCTION(ToInert(_ndsol), _Inert_EXPSEQ(ToInert(x)))) end if end if; try _res := _solnproc(_xout); _res[2] catch: error  end try end proc
f10 := eval(f[1, 0](x), ListProcs);
proc (x) local _res, _dat, _solnproc, _xout, _ndsol, _pars, _i; option `Copyright (c) 2000 by Waterloo Maple Inc. All rights reserved.`; if 1 < nargs then error "invalid input: too many arguments" end if; _EnvDSNumericSaveDigits := Digits; Digits := 15; if _EnvInFsolve = true then _xout := evalf[_EnvDSNumericSaveDigits](x) else _xout := evalf(x) end if; _dat := Array(1..4, {(1) = proc (_xin) local _xout, _n, _y0, _ctl, _octl, _reinit, _errcd, _fcn, _i, _yini, _pars, _ini, _par; option `Copyright (c) 2002 by the University of Waterloo. All rights reserved.`; table( [( "complex" ) = false ] ) _xout := _xin; _ctl := array( 1 .. 34, [( 1 ) = (2), ( 2 ) = (.1), ( 3 ) = (.1), ( 4 ) = (1), ( 5 ) = (1), ( 6 ) = (22), ( 7 ) = (0), ( 9 ) = (-.5011661819), ( 8 ) = (1.503498546), ( 11 ) = (0.1e-6), ( 10 ) = (0.1e-6), ( 13 ) = (0), ( 12 ) = (0), ( 15 ) = (0), ( 14 ) = (0), ( 18 ) = (0), ( 19 ) = (0), ( 16 ) = (0), ( 17 ) = (0), ( 22 ) = (0), ( 23 ) = (0), ( 20 ) = (0), ( 21 ) = (0), ( 27 ) = (0), ( 26 ) = (0), ( 25 ) = (0), ( 24 ) = (0), ( 31 ) = (0), ( 30 ) = (0), ( 29 ) = (0), ( 28 ) = (0), ( 32 ) = (0), ( 33 ) = (-1), ( 34 ) = (0)  ] ); _octl := array( 1 .. 34, [( 1 ) = (2), ( 2 ) = (.1), ( 3 ) = (.1), ( 4 ) = (1), ( 5 ) = (1), ( 6 ) = (22), ( 7 ) = (0), ( 9 ) = (-.5011661819), ( 8 ) = (1.503498546), ( 11 ) = (0.1e-6), ( 10 ) = (0.1e-6), ( 13 ) = (0), ( 12 ) = (0), ( 15 ) = (0), ( 14 ) = (0), ( 18 ) = (0), ( 19 ) = (0), ( 16 ) = (0), ( 17 ) = (0), ( 22 ) = (0), ( 23 ) = (0), ( 20 ) = (0), ( 21 ) = (0), ( 27 ) = (0), ( 26 ) = (0), ( 25 ) = (0), ( 24 ) = (0), ( 31 ) = (0), ( 30 ) = (0), ( 29 ) = (0), ( 28 ) = (0), ( 32 ) = (0), ( 33 ) = (-1), ( 34 ) = (0)  ] ); _n := trunc(_ctl[1]); _yini := Array(0..2, {(1) = .1, (2) = 1.503498546}); _y0 := Array(0..2, {(1) = .1, (2) = 1.503498546}); _fcn := proc (N, X, Y, YP) option `[Y[1] = f[0,0](x), Y[2] = f[1,0](x)]`; YP[1] := -15.58845727*sin(.5773502693*X)/X^2+46.76537182*(3.*sin(.5773502693*X)-1.732050808*X*cos(.5773502693*X))/X^4-(2./X^5+.5000000000/X)*Y[1]; if 1/X^4 < 0 then YP[1] := undefined; return 0 end if; if 1/X^4 < 0 then YP[1] := undefined; return 0 end if; YP[2] := (-15.58845727*sin(.5773502693*X)/X^2+46.76537182*(3.*sin(.5773502693*X)-1.732050808*X*cos(.5773502693*X))/X^4)*(1.-1.*evalf((1/X^4)^(1/4))*exp(1/X^4)*GAMMA(.7500000000, 1/X^4))-1.*(-10.39230485*sin(.5773502693*X)/X^2+31.17691454*(3.*sin(.5773502693*X)-1.732050808*X*cos(.5773502693*X))/X^4+4.*(.8660254040*(3.*sin(.5773502693*X)-1.732050808*X*cos(.5773502693*X))/X+.8660254040*(3.*(1.-6./X^2)*sin(.5773502693*X)+10.39230485*cos(.5773502693*X)/X)/X)*evalf(1/(1/X^4)^(1/4))/(exp(1/X^4)*GAMMA(.7500000000, 1/X^4)*X^5))*evalf((1/X^4)^(1/4))*exp(1/X^4)*GAMMA(.7500000000, 1/X^4)-(6./X^5+1.500000000/X)*Y[2]+1.*Y[1]/X; 0 end proc; _pars := []; if not type(_xout, 'numeric') then if member(_xout, ["start", "left", "right"]) then return _y0[0] elif _xout = "method" then return "lsode" elif _xout = "numfun" then return trunc(_ctl[24+trunc(_ctl[1])]) elif _xout = "initial" then return [seq(_yini[_i], _i = 0 .. _n)] elif _xout = "parameters" then return [seq(_yini[_n+_i], _i = 1 .. nops(_pars))] elif _xout = "initial_and_parameters" then return [seq(_yini[_i], _i = 0 .. _n)], [seq(_yini[_n+_i], _i = 1 .. nops(_pars))] elif _xout = "last" then if _ctl[2]-_y0[0] = 0. then error "no information is available on last computed point" else _xout := _ctl[2] end if elif _xout = "enginedata" then return eval(_octl, 1) elif _xout = "function" then return eval(_fcn, 1) elif type(_xin, `=`) and type(rhs(_xin), 'list') and member(lhs(_xin), {"initial", "parameters", "initial_and_parameters"}) then _ini, _par := [], []; if lhs(_xin) = "initial" then _ini := rhs(_xin) elif lhs(_xin) = "parameters" then _par := rhs(_xin) elif select(type, rhs(_xin), `=`) <> [] then _par, _ini := selectremove(type, rhs(_xin), `=`) elif nops(rhs(_xin)) < nops(_pars)+1 then error "insufficient data for specification of initial and parameters" else _par := rhs(_xin)[-nops(_pars) .. -1]; _ini := rhs(_xin)[1 .. -nops(_pars)-1] end if; _xout := lhs(_xout); if _par <> [] then `dsolve/numeric/process_parameters`(_n, _pars, _par, _yini) end if; if _ini <> [] then `dsolve/numeric/process_initial`(_n, _ini, _yini, _pars) end if; if _pars <> [] then _par := {seq(rhs(_pars[_i]) = _yini[_n+_i], _i = 1 .. nops(_pars))}; for _i from 0 to _n do _y0[_i] := subs(_par, _yini[_i]) end do; for _i from _n+1 to _n+nops(_pars) do _y0[_i] := _yini[_i] end do else for _i from 0 to _n do _y0[_i] := _yini[_i] end do end if; _octl[2] := _y0[0]; _octl[3] := _y0[0]; for _i to _n do _octl[_i+7] := _y0[_i] end do; for _i to nops(_pars) do _octl[2*_n+30+_i] := _y0[_n+_i] end do; for _i to 34 do _ctl[_i] := _octl[_i] end do; if _Env_smart_dsolve_numeric = true and type(_y0[0], 'numeric') then procname("right") := _y0[0]; procname("left") := _y0[0] end if; if _xout = "initial" then return [seq(_yini[_i], _i = 0 .. _n)] elif _xout = "parameters" then return [seq(_yini[_n+_i], _i = 1 .. nops(_pars))] else return [seq(_yini[_i], _i = 0 .. _n)], [seq(_yini[_n+_i], _i = 1 .. nops(_pars))] end if else return "procname" end if end if; if _xout-_y0[0] = 0. then return [seq(_y0[_i], _i = 0 .. _n)] end if; _reinit := false; if _xin <> "last" then if 0 < 0 and `dsolve/numeric/checkglobals`(0, table( [ ] ), _pars, _n, _yini) then _reinit := true; if _pars <> [] then _par := {seq(rhs(_pars[_i]) = _yini[_n+_i], _i = 1 .. nops(_pars))}; for _i from 0 to _n do _y0[_i] := subs(_par, _yini[_i]) end do; for _i from _n+1 to _n+nops(_pars) do _y0[_i] := _yini[_i] end do else for _i from 0 to _n do _y0[_i] := _yini[_i] end do end if; for _i to _n do _octl[_i+7] := _y0[_i] end do; for _i to nops(_pars) do _octl[2*_n+30+_i] := _y0[_n+_i] end do end if; if _pars <> [] and select(type, {seq(_yini[_n+_i], _i = 1 .. nops(_pars))}, 'undefined') <> {} then error "parameters must be initialized before solution can be computed" end if end if; if not _reinit and _xout-_ctl[2] = 0 then [_ctl[2], seq(_ctl[_i], _i = 8 .. 7+_n)] else if sign(_xout-_ctl[2]) <> sign(_ctl[2]-_y0[0]) or abs(_xout-_y0[0]) < abs(_xout-_ctl[2]) or _reinit then for _i to 34 do _ctl[_i] := _octl[_i] end do end if; _ctl[3] := _xout; if Digits <= evalhf(Digits) then try _errcd := evalhf(`dsolve/numeric/lsode`(_fcn, var(_ctl))) catch: userinfo(2, `dsolve/debug`, print(`Exception in lsode:`, [lastexception])); if searchtext('evalhf', lastexception[2]) <> 0 or searchtext('real', lastexception[2]) <> 0 or searchtext('hardware', lastexception[2]) <> 0 then _errcd := `dsolve/numeric/lsode`(_fcn, _ctl) else error  end if end try else _errcd := `dsolve/numeric/lsode`(_fcn, _ctl) end if; if _errcd < 0 then userinfo(2, {dsolve, `dsolve/lsode`}, `Last values returned:`); userinfo(2, {dsolve, `dsolve/lsode`}, ` t =`, _ctl[2]); _i := 8; userinfo(2, {dsolve, `dsolve/lsode`}, ` y =`, _ctl[_i]); for _i from _i+1 to 7+_n do userinfo(2, {dsolve, `dsolve/lsode`}, `	 `, _ctl[_i]) end do; if _errcd+1. = 0. then if _ctl[14+trunc(_ctl[1])] <> 0 then error "an excessive amount of work was done, maxstep may be too small" else error "an excessive amount of work (greater than mxstep) was done" end if elif _errcd+2. = 0. then error "too much accuracy was requested for the machine being used" elif _errcd+3. = 0. then error "illegal input was detected" elif _errcd+4. = 0. then error "repeated error test failures on the attempted step" elif _errcd+5. = 0. then error "repeated convergence test failures on the attempted step" elif _errcd+6. = 0. then error "pure relative error control requested for a variable that has vanished" elif _errcd+7. = 0. then error "cannot evaluate the solution past %1, maxfun limit exceeded (see <a href='http://www.maplesoft.com/support/help/search.aspx?term=dsolve,maxfun' target='_new'>?dsolve,maxfun</a> for details)", evalf[8](_ctl[2]) else error "unknown error code returned from lsode %1", trunc(_errcd) end if end if; if _Env_smart_dsolve_numeric = true then if _y0[0] < _xout and procname("right") < _xout then procname("right") := _xout elif _xout < _y0[0] and _xout < procname("left") then procname("left") := _xout end if end if; [_xout, seq(_ctl[_i], _i = 8 .. 7+_n)] end if end proc, (2) = Array(1..3, {(1) = 18446744078356217278, (2) = 18446744078356217454, (3) = 18446744078356217630}), (3) = [x, f[0, 0](x), f[1, 0](x)], (4) = []}); _solnproc := _dat[1]; _pars := map(rhs, _dat[4]); if not type(_xout, 'numeric') then if member(x, ["start", 'start', "method", 'method', "left", 'left', "right", 'right', "leftdata", "rightdata", "enginedata", "eventstop", 'eventstop', "eventclear", 'eventclear', "eventstatus", 'eventstatus', "eventcount", 'eventcount', "laxtol", 'laxtol', "numfun", 'numfun', NULL]) then _res := _solnproc(convert(x, 'string')); if 1 < nops([_res]) then return _res elif type(_res, 'array') then return eval(_res, 1) elif _res <> "procname" then return _res end if elif member(x, ["last", 'last', "initial", 'initial', NULL]) then _res := _solnproc(convert(x, 'string')); if type(_res, 'list') then return _res[3] else return NULL end if elif member(x, ["parameters", 'parameters', "initial_and_parameters", 'initial_and_parameters', NULL]) then _xout := convert(x, 'string'); _res := _solnproc(_xout); if _xout = "parameters" then return [seq(_pars[_i] = _res[_i], _i = 1 .. nops(_pars))] else return [_res[3], seq(_pars[_i] = [_res][2][_i], _i = 1 .. nops(_pars))] end if elif type(_xout, `=`) and member(lhs(_xout), ["initial", 'initial', "parameters", 'parameters', "initial_and_parameters", 'initial_and_parameters', NULL]) then _xout := convert(lhs(x), 'string') = rhs(x); if lhs(_xout) = "initial" then if type(rhs(_xout), 'list') then _res := _solnproc(_xout) else _res := _solnproc("initial" = ["single", 3, rhs(_xout)]) end if elif not type(rhs(_xout), 'list') then error "initial and/or parameter values must be specified in a list" elif lhs(_xout) = "initial_and_parameters" and nops(rhs(_xout)) = nops(_pars)+1 then _res := _solnproc(lhs(_xout) = ["single", 3, op(rhs(_xout))]) else _res := _solnproc(_xout) end if; if lhs(_xout) = "initial" then return _res[3] elif lhs(_xout) = "parameters" then return [seq(_pars[_i] = _res[_i], _i = 1 .. nops(_pars))] else return [_res[3], seq(_pars[_i] = [_res][2][_i], _i = 1 .. nops(_pars))] end if elif type(_xout, `=`) and member(lhs(_xout), ["eventdisable", 'eventdisable', "eventenable", 'eventenable', "eventfired", 'eventfired', "direction", 'direction', NULL]) then return _solnproc(convert(lhs(x), 'string') = rhs(x)) elif _xout = "solnprocedure" then return eval(_solnproc) elif _xout = "sysvars" then return _dat[3] end if; if procname <> unknown then return ('procname')(x) else _ndsol := `tools/gensym`("f[1,0](x)"); eval(FromInert(_Inert_FUNCTION(_Inert_NAME("assign"), _Inert_EXPSEQ(ToInert(_ndsol), _Inert_VERBATIM(pointto(_dat[2][3])))))); return FromInert(_Inert_FUNCTION(ToInert(_ndsol), _Inert_EXPSEQ(ToInert(x)))) end if end if; try _res := _solnproc(_xout); _res[3] catch: error  end try end proc
ftoplot := unapply(f00(x)+0.45e-1*f10(x)/x^(3/2), x)
proc (x) options operator, arrow; f00(x)+0.45e-1*f10(x)/x^(3/2) end proc
plot(ftoplot(x), x = xini .. xfin)
Download Test2ODEs.mw
The approach in that file works, however I have a question regarding the efficiency of my method, since I plan to extend the system to many more ODEs besides just 2 and also extend the range to a larger xfin. In this method, since I define the function to plot in terms of f01 and f02, wich are procedures, does this mean that for each x on the grid for the plot(ftoplot,x=xini..xfin) maple actually computes the solutions f00(x) and f01(x) and then forms the ftoplot combination and plots that specific point? If the default sampling of my interval is, say 1000 points, does it mean that the way I wrote it I will have 1000 invocations of the dsolve procedure, for each x in the sample? I am not sure, it seems to me that is the case. This would imply that instead of advancing the solution at each step maple starts over again from xini. How could I just avoid this behavior and instead have access to the values of ftoplot(x) in the range xini to xfin stored from one invocation of dsolve?
The ideal scenario for me would be to have f[0,0](x) and f[0,1](x) stored as an interpolated function between xini and xfin from the solutions of one invocation of dsolve prior to defining ftoplot. Can this be achieved in principle? How? Remember, i have to use method=lsode and range is not accepted.
hi friends
After this cods i see very error
 > restart;
read(orbit.sav ): whit(plots):
ax := -G*Mz*x/(x^2+y^2)^(3/2);
ay := -G*Mz*y/(x^2+y^2)^(3/2);
i := 'i'; j := i+1;
for k from 0 to 3 do
x := 7*10^6; Vx := 0;
y := 0; Vy := 9000;
dt := evalf(1/2^k);
for i from 0 to 328 do
X[i] := evalf(x); Y[i] := evalf(y);
for n to 40*2^k do
x := evalf((1/2)*ax*dt^2+Vx*dt+x); y := evalf((1/2)*ay*dt^2+Vy*dt+y);
Vx := evalf(ax*dt+Vx); Vy := evalf(ay*dt+Vy)
od;
if i mod 41= 0 then
dX[k, i] := X[i]-XS[j]; dY[k, i] := Y[i]-YS[j]
fi
od;
p[k] := plot([seq([(X[i]-XS[j])*(1/1000), (Y[i]-YS[j])*(1/1000)], i = 0 .. 328)], color = green) end do;
p1 := display({seq(p[k], k = 0 .. 3)}, thickness = 3)
SI := [seq(41*i, i = 0 .. 8)]
p2 := plot({seq([seq([(1/1000)*dX[k, i], (1/1000)*dY[k, i]], k = 0 .. 1), [0, 0]], i = SI)}, color = black)
display({p1, p2}, scaling = constrained, labels = ['dx', 'dy'])
display({p1, p2}, view = [-.1 .. .5, -.4 .. .2], scaling = constrained, labels = ['dx', 'dy'])
can you help me Please?
Does anyone know how to using some softward convert ?  for example  I have maple code , but I want to using mathematica code .I need fast way.
To run Maple script, on windows, I type
cmaple.exe   my_file.mpl
and this works well. So if my_file.mpl has the line int(sin(x),x);  the result of the above is:
> int(sin(x),x);
                                                        -cos(x)
> quit
memory used=0.9MB, alloc=8.3MB, time=0.05
sometimes, it will be nice to use cmaple to quickly do one time calculation on the fly such as the above, without having to open Maple GUI or write/edit a file. For example, I'd like to be able to do something like
cmaple.exe   "int(sin(x),x);"
but ofcourse the above does not work as is, since it expects its input to be a file. I tried
cmaple.exe   << "int(sin(x),x);"
but that did not work (for obvious reasons, since the input string is not a file name).
I tried different re-directions, as shown in this page for windows, but maple expects the input to be a file.
Is there a way to use cmaple with command directly written as string as above? I am using Maple 2015.
There is no menu item called "Startup Code"
in the "Edit" menu item of my Maple 13.
Please help!
We're starting on indefinite integrals in my 1st year calculus class.
A quick example would be int(sin(x), x);=-cos(x)+C
Maple doesn't add the +C on the end of it's solution. Can someone explain or point me to a resource? I've tried searching but I can't find an answer.
Dear,
I have a perfectly working when all parameters are known (figure 1), however I want to perform a sensitivity analysis by derivating the code if one parameter is unknown. Because of multiple possible answers and because of the complexity of the formula, I cannot run this script and get solutions. Any ideas how I can this calculation lighter so it is able to run? Values should be real and positive (so 1 or 2 solutions are the only one I'm interested in)
Any ideas, how I can make this code runnable? (file is below)
I'm stuck on this for a while now :/ So I hope someone will be able to help me
Many thanks in advance!l
Question.mw
Figure 1: [URL=http://s1240.photobucket.com/user/laggstar/media/Parameter%20f%20known.png.html][IMG]http://i1240.photobucket.com/albums/gg494/laggstar/Parameter%20f%20known.png[/IMG][/URL]
Figure 2: [URL=http://s1240.photobucket.com/user/laggstar/media/Parameter%20f%20unknown.png.html][IMG]http://i1240.photobucket.com/albums/gg494/laggstar/Parameter%20f%20unknown.png[/IMG][/URL]
This should be trivial but I am not able to figure out the right syntax to execute it
The pdf is given by :
f_X(x)={ 1/25 *x, 0<=x<5
             2/5 -x/25, 5<=x<10
             0, otherwise
I have tried to use the "CumulativeDistributiveFunction" so far
First 240 241 242 243 244 245 246 Last Page 242 of 371
