As i  want to build a model of engine an want to supply compressed air for same ii prepared a engine model but now i am not geeting how to prepare model flow of compressed air and its expansion in enige and force crated on engine head.
How do I solve canonical diffusion mathematical equation in Maple?
http://www.maplesoft.com/applications/view.aspx?SID=5083&view=html&L=F
Error, (in hanoi) cannot determine if this expression is true or false: 0 < n
N:=n:moves:=[];
hanoi:=proc(N,source,dest,aux) global moves;
if N>0 then
hanoi(N-1,source,aux,dest):
moves:=[moves[],[N,source,dest]]:
hanoi(N-1,aux,dest,source);
sol:=hanoi(n,1,3,2);
There is million items in list,
what is the difference between seq and for loop ?
is seq faster than for loop?
it is very slow when running code below, how to speed up this part of code?
https://gist.github.com/LovelyYanki/c0b61fbb9d5954b34e03#file-gistfile1-txt
HSKeyIn := Table();
for ij from 1 to 1685159 do
s := solve([mm[ij][1,1]=1,mm[ij][1,2]=1,mm[ij][1,3]=1],[a,b,c]):
if nops(s) > 0 then
if (rhs(s[1][1]) = 1 or rhs(s[1][1]) = 0) and (rhs(s[1][2]) = 1 or rhs(s[1][2]) = 0) and (rhs(s[1][3]) = 1 or rhs(s[1][3]) = 0) then
#print(lhs(indices(T3, pairs)[ij])):
#print("***"):
h := HilbertSeries([mm[ij][1,1],mm[ij][1,2],mm[ij][1,3]], {a,b,c}, z):
#print(h):
if not assigned(HSkeyIn[h]) then
if mod(ij, 100) = 0 then
print(ij):
HSkeyIn[h] := [[mm[ij][1,1],mm[ij][1,2],mm[ij][1,3]]]:
print(ij):
HSkeyIn[h] := [op(HSkeyIn[h]), [mm[ij][1,1],mm[ij][1,2],mm[ij][1,3]]]:
mm := [[a, 1], [a, b]];
mmseq := {seq(mm[ij],ij=1..2)};
how to filter above in seq when any items in the [] has 1
criteria is below
if mm[ij][1] = 1 or mm[ij][2] = 1 or mm[ij][3] = 1 then
Dummy := 0:
mm2 := [op(mm2), mm[ij]]:
end if
People im with error to show a plot, this is a wor for universty about mechanic materials, and i'm with this error... do not show the plot... before, i've a error because the variable x has values, and i've to unassign to have this.. without unassign, has error in domin of the plot... i dont know how to do this ! And ive to send the work today.
Someone can help me about this?
Value of variables:
functions
plot algoritm...
plot algoritm
Thanks !
in page 137 of an introduction to groebner bases
how to eliminate the redundant solution (y^2-x*z, 0, -x^2+y*w)
from 3 of them?
eliminate({y,y^2-x*z,-z}, {x, y, z, w});
eliminate({-x,0,y}, {x, y, z});
eliminate({w,-x^2+y*w,-x}, {x, y, z, w});
Please help me to solve this integration
restart; with(LinearAlgebra); int(exp(-(ln(z/(snr*B^2))+4*sigma^2)^2/(32*sigma^2))*eta^2*(y/z)^((1/2)*eta^2-1)/(z*sqrt(32*Pi*sigma^2)*(2*sqrt(y*z))*(2*A[o]^(eta^2))), z, z = y/A[o]^2 .. infinity);
I have created and saved a MAPLE module in an .mla archive. The module contains three procedures A, B, C, where
A calls, B and C.
Once the module library has been loaded, A acccepts inputs and generates outputs.
Is it possible to create a MAPLE player worksheet which calls the module and share it with a Maple Player (only) user, so that they can then supply the inputs and observe the outputs from A using the Maple Player programme components?
Can anyone help?
MRB
I have purchased Maple 2015 Student Edition a few months ago.  Now, I was about to buy MapleSim Student Edition and I saw that MapleSim include a license of Maple.
If I buy MapleSim and Maple,  I would pay 198$ even if I could have bought only MapleSim and still get both products?
Can I get MapleSim Student without Maple at a lower price?
Maybe the version of Maple included in MapleSim has less features and that's why the cost of MapleSim and Maple are the same?
Thanks in advance!
I did some search on Google and on this website, but I haven't found anything.
please demonstrate to me how to set up a maple document to solve a simple beam design from the scratch.
S. Hassan
with(Groebner):
T := lexdeg([x,y,z],[e1,e2]);
intermsof1 := y;
intermsof2 := -z;
GB := Basis([e1-intermsof1, e2-intermsof2], 'tord',T);
result := NormalForm(y^2-x*z, GB,'tord', T);
result := NormalForm(y^2-x*z, GB, T);
originally Basis do not have error when without parameter 'tord'
after it has argument error, it has to be added extra parameter tord
NormalForm has the same error too.
i do not understand why it has error, how to solve?
i just want to express y^2-x*z in terms of y and -z
Where is the mapleclud palltte button ?   It is not in my Maple 16,  not in   mymaplecloud
How to upload a maple work sheet into  my maplecloud private  storage ?
consider quadratic equation ax^2+bx+c =0 :
the coefficients vary between -1 and +1 . just like this :
-1<a<+1 , -1<b<+1 , -1<c<+1 ;
how can some one proove that this equation should have real answers ?! can anybody help ? thanks in advance.
i am very new with Maple.
I have the following two equations:
x1=a-y1-d*y2;
x2=a-y2-d*y1;
I wish to express the first equation in terms of y1 and x2, so that
x1 = c - b*y1+d*x2;
where c=a-a*d and b=1-d^2. How can I get maple to rearrange the original equation x1 in term of y1, x2, c and b?
First 230 231 232 233 234 235 236 Last Page 232 of 371
