I am trying to create a ring of difference operators with customly defined actions. I have managed to get the code to work to an extent, but I am having trouble creating the inverse operators. For example, if Sn sends n to n+2, I want to create Sn^(-1) that sends n to n-2. When I tried to input this into the algebra itself, it gave me the following error: "Error, (in Ore_algebra:-skew_algebra) indeterminate n may appear in a single commutation only". Below is the code that creates the difference algebra. Apologies for the bad formatting.
> with(Ore_algebra);
> CreateDifferenceAlgebra := proc (vars::(list(symbol)), offsets::(list(numeric)))
local actions, i, var, diff_op,
shift_offset, algebra; actions := table();
for i to numelems(vars) do
   var := vars[i];
   diff_op := convert(cat("S",\var), symbol);
   shift_offset := offsets[i];
   actions[diff_op] := (proc (values) options operator, arrow; proc (u, order)
      local res; res := u;
      to order do res := subs(values[1] = values[1]+values[3], res*values[2]) end do;
      res
   end proc)([var, diff_op, shift_offset]) end do;
algebra := Ore_algebra:-skew_algebra(seq(shift = [convert(cat("S",
vars[i]), symbol), vars[i]], i = 1 .. numelems(vars)),
action = {seq(convert(cat("S", vars[i]), symbol) =
actions[convert(cat("S", vars[i]), symbol)], i = 1 ..
numelems(vars))}); return algebra end proc
I have currently a Maple session running with only one open worksheet.
The worksheet only contains an input line with the name "a" and an output line with the name "a".
The fan of my laptop is running full throttle and the task manager displays 10% CPU usage and a very high power usage (3 mserver.exe running, the process with the cpu load is javaw.exe. Suspending this process shuts down the fan).
After about an hour I decided to ask. While typing this post (in Firefox, probably unrelated) the CPU usage went down and the fan went quite. The total system CPU usage is now down to 2%.
Has anybody seen the same? What could have cause it? It's not the first time I observe this. Anything that I could check before restarting Maple? All on Windows 10 after system restart.
Update:
The thread that consumes cpu is called ucrtbase.dll!configthreadlocate
Starting Maplesim in parallel almost immediately turns off the fan while the displayed cpu load is still high but now variing.
I can't understand why Maple interprets 1 .05  as 1 * 5 = 5 , and 2 .05  as 2 * 5 = 10 . Note the space between 1 and .05
In a different calculation I accidentally inserted a space between 1 and .05, and received a strange answer, and finally narrowed it down to a space.
But now I wonder why it is it is interpreting this way. Also I see that 2  0.05 produces an error. But  2 .05 is treated as 10. There is an implied multiplication? But the multiplication should be 2 * .05 , which is 1 and not 10.
i found thus condition which if we substitute in equation must be equal to zero, i don't know  how i can get zero
test_pde1.mw
I have encountered an issue: eq1 is not satisfied, though eq2 is satisfied for the parametric value (10). I need assistance in finding a way to ensure that both equations are satisfied simultaneously. Please provide guidance or suggest a potential approach for addressing this issue.verf_kk.mw
I have  a big problem in transformation How we can do suh transformation in  type of  procure  without use any hand work for example in physic abs|-| remove the exponential term how the maple remove that term automatically and collect all term and do my transformation this example is really hard one which is must do a lot by hand and mixed them which maybe a week take my time to get results and how i reach the results without spending that time i have a result of this equation and i am try to get but i don't know the results of this person is correct or not but i will share in here,  i did some try i will share in here too if in DEchange add U(xi) it will work and give me the other step but i need something more effective, when q^* is conjugate of q =exp(-ipsi(x,t))U(xi)
with(PDEtools)
with(Physics)
with(SolveTools)
undeclare(prime)
tr := {t = tau, x = xi/k+v*tau^alpha/(k*alpha)+theta, u(x, t) = U(xi)*exp(I*(xi/k+v*tau^alpha/(k*alpha)+mu*tau+theta)), u[1](x, t) = U(xi)*exp(-I*(xi/k+v*tau^alpha/(k*alpha)+mu*tau+theta))}
pde := I*(I*U(xi)*exp(I*(xi/k+v*tau^alpha/(k*alpha)-mu*tau+theta))*w-exp(I*(xi/k+v*tau^alpha/(k*alpha)+mu*tau+theta))*(diff(U(xi), xi))*v)+a*(diff(u(x, t), `$`(x, 2)))+b*U(xi)^2*u(x, t)+C[1](h[1]*(diff(u(x, t), `$`(x, 4)))+h[2]*(diff(u(x, t), x))^2*u[1](x, t)+h[3]*abs(diff(u(x, t), x))^2*u(x, t)+h[4]*U(xi)^2*(diff(u(x, t), `$`(x, 2)))+h[5]*u(x, t)^2*(diff(u[1](x, t), `$`(x, 2)))+h[6]*U(xi)^4*u(x, t))+I*C[2]*(h[7]*(diff(u(x, t), `$`(x, 4)))+h[8]*U(xi)^2*(diff(u(x, t), x))+h[9]*u(x, t)^2*(diff(u[1](x, t), x))) = 0
I*(I*U(xi)*exp(I*(xi/k+v*tau^alpha/(k*alpha)-mu*tau+theta))*w-exp(I*(xi/k+v*tau^alpha/(k*alpha)+mu*tau+theta))*(diff(U(xi), xi))*v)+a*(diff(diff(u(x, t), x), x))+b*U(xi)^2*u(x, t)+C[1](h[1]*(diff(diff(diff(diff(u(x, t), x), x), x), x))+h[2]*(diff(u(x, t), x))^2*u[1](x, t)+h[3]*abs(diff(u(x, t), x))^2*u(x, t)+h[4]*U(xi)^2*(diff(diff(u(x, t), x), x))+h[5]*u(x, t)^2*(diff(diff(u[1](x, t), x), x))+h[6]*U(xi)^4*u(x, t))+I*C[2]*(h[7]*(diff(diff(diff(diff(u(x, t), x), x), x), x))+h[8]*U(xi)^2*(diff(u(x, t), x))+h[9]*u(x, t)^2*(diff(u[1](x, t), x))) = 0
PDEtools:-dchange(tr, pde, [xi, tau, U, U(xi)])
I*(I*U(xi)*exp(I*(xi/k+v*tau^alpha/(k*alpha)-mu*tau+theta))*w-exp(I*(xi/k+v*tau^alpha/(k*alpha)+mu*tau+theta))*(diff(U(xi), xi))*v)+a*((2*I)*exp(I*(xi/k+v*tau^alpha/(k*alpha)+mu*tau+theta))*(diff(U(xi), xi))/k+exp(I*(xi/k+v*tau^alpha/(k*alpha)+mu*tau+theta))*(diff(diff(U(xi), xi), xi))-U(xi)*exp(I*(xi/k+v*tau^alpha/(k*alpha)+mu*tau+theta))/k^2)*k^2+b*U(xi)^3*exp(I*(xi/k+v*tau^alpha/(k*alpha)+mu*tau+theta))+C[1](h[1]*(-(4*I)*exp(I*(xi/k+v*tau^alpha/(k*alpha)+mu*tau+theta))*(diff(U(xi), xi))/k^3-6*exp(I*(xi/k+v*tau^alpha/(k*alpha)+mu*tau+theta))*(diff(diff(U(xi), xi), xi))/k^2+(4*I)*exp(I*(xi/k+v*tau^alpha/(k*alpha)+mu*tau+theta))*(diff(diff(diff(U(xi), xi), xi), xi))/k+exp(I*(xi/k+v*tau^alpha/(k*alpha)+mu*tau+theta))*(diff(diff(diff(diff(U(xi), xi), xi), xi), xi))+U(xi)*exp(I*(xi/k+v*tau^alpha/(k*alpha)+mu*tau+theta))/k^4)*k^4+h[2]*(exp(I*(xi/k+v*tau^alpha/(k*alpha)+mu*tau+theta))*(diff(U(xi), xi))+I*U(xi)*exp(I*(xi/k+v*tau^alpha/(k*alpha)+mu*tau+theta))/k)^2*k^2*U(xi)*exp(-I*(xi/k+v*tau^alpha/(k*alpha)+mu*tau+theta))+h[3]*abs((exp(I*(xi/k+v*tau^alpha/(k*alpha)+mu*tau+theta))*(diff(U(xi), xi))+I*U(xi)*exp(I*(xi/k+v*tau^alpha/(k*alpha)+mu*tau+theta))/k)*k)^2*U(xi)*exp(I*(xi/k+v*tau^alpha/(k*alpha)+mu*tau+theta))+h[4]*U(xi)^2*((2*I)*exp(I*(xi/k+v*tau^alpha/(k*alpha)+mu*tau+theta))*(diff(U(xi), xi))/k+exp(I*(xi/k+v*tau^alpha/(k*alpha)+mu*tau+theta))*(diff(diff(U(xi), xi), xi))-U(xi)*exp(I*(xi/k+v*tau^alpha/(k*alpha)+mu*tau+theta))/k^2)*k^2+h[5]*U(xi)^2*(exp(I*(xi/k+v*tau^alpha/(k*alpha)+mu*tau+theta)))^2*((diff(diff(U(xi), xi), xi))*exp(-I*(xi/k+v*tau^alpha/(k*alpha)+mu*tau+theta))-(2*I)*(diff(U(xi), xi))*exp(-I*(xi/k+v*tau^alpha/(k*alpha)+mu*tau+theta))/k-U(xi)*exp(-I*(xi/k+v*tau^alpha/(k*alpha)+mu*tau+theta))/k^2)*k^2+h[6]*U(xi)^5*exp(I*(xi/k+v*tau^alpha/(k*alpha)+mu*tau+theta)))+I*C[2]*(h[7]*(-(4*I)*exp(I*(xi/k+v*tau^alpha/(k*alpha)+mu*tau+theta))*(diff(U(xi), xi))/k^3-6*exp(I*(xi/k+v*tau^alpha/(k*alpha)+mu*tau+theta))*(diff(diff(U(xi), xi), xi))/k^2+(4*I)*exp(I*(xi/k+v*tau^alpha/(k*alpha)+mu*tau+theta))*(diff(diff(diff(U(xi), xi), xi), xi))/k+exp(I*(xi/k+v*tau^alpha/(k*alpha)+mu*tau+theta))*(diff(diff(diff(diff(U(xi), xi), xi), xi), xi))+U(xi)*exp(I*(xi/k+v*tau^alpha/(k*alpha)+mu*tau+theta))/k^4)*k^4+h[8]*U(xi)^2*(exp(I*(xi/k+v*tau^alpha/(k*alpha)+mu*tau+theta))*(diff(U(xi), xi))+I*U(xi)*exp(I*(xi/k+v*tau^alpha/(k*alpha)+mu*tau+theta))/k)*k+h[9]*U(xi)^2*(exp(I*(xi/k+v*tau^alpha/(k*alpha)+mu*tau+theta)))^2*((diff(U(xi), xi))*exp(-I*(xi/k+v*tau^alpha/(k*alpha)+mu*tau+theta))-I*U(xi)*exp(-I*(xi/k+v*tau^alpha/(k*alpha)+mu*tau+theta))/k)*k) = 0
Download find_ODE.mw
I just got 2 questions regarding symbols and answers in MapleFlow (I might be doing something wrong here).
- In trying to input the integral int(F(x), x = -pi/5 .. pi/5) - this is just an example! - as a symbol,
MapleFlow doesn´t accept fractions or multiplications for bondaries values, unless I input "int(F(x), x = -pi/5 .. pi/5 =". Is there anyway to do it?
- is it possible to have the answer as 2*cos((3*Pi)/10), like in Maple, instead of 2.00*cos(300e-3*pi) ()symbolic expression) or 1.18 (numeric expression)?
Thanks in advance for your help.
How can I check if a name has been used/entered already but was not assigned to a value
The variable palette only lists assigned names.
I tried unames() but this lists all unassigned names. A 'user' option (which filters for user-assigned names) as in anames() does not seem to exist.
One of my failed attempts (in 1D-Math):
unames():
initial_unames := {%}:
new_name;
{unames()} minus initial_unames; # should ideally return a reduced set containing new_name;
has(%,new_name)
What else can be done? (I am probably overlooking something very simple.)
@Rouben Rostamian
Dear Sir Professor Rostamian my name is Viorel Popescu from the Polytechnic University of Bucharest if you remember in the summer of 2019 you helped me to solve the equation: rH''(r)+H'(r)+(rk^2-r^2*b^2/R^2)H(r)=0 where k, b, and R are real constants positive number, with condition H(R)=0 and H'(1/R)=R. I appreciate it very much, please I'm in a similarly embarrassing situation to beg you for an answer. I want to find the equation of audion and complete the experiment http://www.michaelvio.byethost8.com/Audion.pdf
My account in Maple Primes is the same michaelvio (35) as the email michaelvio@yahoo.com and also @gmail.com it's an experiment that I want to make for my PhD. Practically I suppose that the energy can be approx. as a series of power of frequency t from I selected severaral terms Ea := 0.00762014687*t + a*t^2 + b*t^3 + c*t^4 + d*t^5 and I guess that satisfies an equation as in the document. The case of photons is beyond my possibility, but a little help from a distinguished Professor as you should cheer me up Audion1.mw
Audion.docx
Please help!
I noticed that the Linearly Implicit Euler method (also known as the Semi-Implicit Euler method) is not available in Maple's built-in ODE solvers. This method is useful for stiff ODEs, where part of the function is treated implicitly (for the linear term) and part is treated explicitly (for the non-linear term).
I know that the Linearly Implicit Euler method is a specialized method that probably does not find enough widespread use to justify its inclusion as a standard feature in Maple, especially given Maple's focus on numerical methods such as Runge-Kutta methods and fully implicit methods for rigid equations.
I’m wondering:
  1. Why isn’t this method included in Maple’s standard set of numerical solvers?
  2. How can I implement this method in my own code in Maple to solve stiff ODEs?
Any guidance or examples of implementation would be greatly appreciated!
Thank you!
Linearly_Implicit_Method.pdf
The usual ODE must be solved:
y´´*(y^3-y)+y´^2 *(y^2+1)=0
"Dangerous places" of the definition domain must be described: Where are the general solution y(x) and its derivatives continuous?
Could anyone help me to convert a code written in Mathematica to a Maple worksheet? I have PDF only. Could any one have a look on Mpale sheet and PDF....
Mathematica__to_Maple.mw
Mathematica_file.pdf
An animation only allows one time parameter.
I have an setup in which I have a time parameter + another parameter or more(e.g., offset, scale, whatever).
I would like some way to easily traverse phase space and see the result and animate with time at those specific parameters(ideally animate along any path in the phase space).
In my case what this means is that there is a 2D rectangle in which represents the phase space. E.g., time x offset. This effects the animation by setting the current parameters. If the animation is animated in time it moves across the vertical. Basically a "2d slider". Alternatively have actually 2(or more) independent sliders.
Currently I have to manually set the parameter then re-execute the animation to see the new animation.
e.g.,
  animation(plot, [f(t,offset)], t=0..1,offset=1..5)
How to use maple to compute the solution of two coupling equations that both have higher order derivatives? I used dsolve and couldn't solve it.
question928.mw
I was wondering if there is a way to measure/extract the contact forces that occur during a contact event? Preferably I would like to visualize the contact forces in the 3D result view.
I would also like to extract information about slippage in a contact.
Is this somehow possible?
First 25 26 27 28 29 30 31 Last Page 27 of 371
