Hello everyone
Any one can help to plot a figure as follows
" A cross section of three colored basins of attraction on an (x, y)
plane at z = 0 and w = 0 for a = 2.48 and b = 0.5. Basins in green, red, and cyan leads to a strange attractor, a limit cycle, and a line equilibrium,
respectively. The yellow leads to unbounded orbits. " Where the system
xdot=y
ydot=z
zdot=w
wdot=-az-bw-y-xy.
and range of x=[-6,6] and y=[-3,6].
Hi everyone, is there any source of Maple competitions? Or related questions? I have a hard time finding books on this subject. I am very interested in Maple and hope to improve my Maple programming skills. In addition to frequently browsing this website, I encounter problems on the Internet sporadically, so I think starting with competition questions will be a quick way to improve.
can someone help me curve fitting these parameeters...i only got 1 for all of this 90As4.mw
with(Statistics)with(plots)with(Optimization)with(LinearAlgebra)
E[1] := 126*10^9E[2] := 11*10^9G[12] := 6.6*10^9G_0__12 := 10.1*10^9nu[12] := .28E_0__2 := 15.5*10^9
true_strain := [0, .406915, .710106, .989362, 1.28457, 1.53989, 1.86702, 2.21011, 2.625, 2.99202]; true_stress := [0, 46.0227*10^6, 81.8182*10^6, 109.091*10^6, 138.068*10^6, 163.636*10^6, 194.318*10^6, 219.886*10^6, 248.864*10^6, 267.614*10^6]; epsilon_dot := 10^(-4)
sigma_t := map(proc (epsilon) options operator, arrow; E[instantaneous]*(1-lambda[90*deg]*epsilon*(sum(P[i], i = 1 .. 10)-(sum(P[i]*exp(lambda[i]*epsilon/epsilon_dot), i = 1 .. 10)))/epsilon_dot)*epsilon end proc, true_strain)
obj := sum((sigma_t[i]-true_stress[i])^2, i = 1 .. 10)
indets(obj, name)
{E[instantaneous], P[1], P[2], P[3], P[4], P[5], P[6], P[7], P[8], P[9], P[10], lambda[1], lambda[2], lambda[3], lambda[4], lambda[5], lambda[6], lambda[7], lambda[8], lambda[9], lambda[10], lambda[90*deg]}
Optimization[Interactive](obj)
The solution was obtained with the following warning:
  no iterations performed as initial point satisfies first-order conditions
[Float(infinity), [E[instantaneous] = HFloat(1.0), P[1] = HFloat(1.0), P[2] = HFloat(1.0), P[3] = HFloat(1.0), P[4] = HFloat(1.0), P[5] = HFloat(1.0), P[6] = HFloat(1.0), P[7] = HFloat(1.0), P[8] = HFloat(1.0), P[9] = HFloat(1.0), P[10] = HFloat(1.0), lambda[1] = HFloat(1.0), lambda[2] = HFloat(1.0), lambda[3] = HFloat(1.0), lambda[4] = HFloat(1.0), lambda[5] = HFloat(1.0), lambda[6] = HFloat(1.0), lambda[7] = HFloat(1.0), lambda[8] = HFloat(1.0), lambda[9] = HFloat(1.0), lambda[10] = HFloat(1.0), lambda[90*deg] = HFloat(1.0)]]
Download 90As4.mw
I apologize for putting the equations in image format, but I thought that this way the community could better understand how to interpret the equations.
Below are 6 letters whose solution must be developed step by step so that the periodic extension of each one can then be done. I can solve all the letters by hand (solving in the notebook), but my big question is, how can I do the commands in Maple step by step so that I can solve them as if I were doing them by hand (look like in my notebool)? I need to check step by step. I would be extremely grateful for the help of any of you.
second part
What is the name of the procedure that provides the information about which steps Maple is using to solve an equation?
I ask because I think pdsolve is caught in a loop, but I can't see what it is trying.
(I can't think of this name at the moment. And Google Gemini returns nonsense. So, I am hoping that by answering this question, Google Gemini will be "trained.")
I find thus equation of course i use a little bit seperation by hand, i have 11 equation but i can't get results of parameters i don't know why my code is a little bit old i think and i don't know there is another technique for finding them or not here is the file of mp, thanks for any help
F_P_Correct.mw
for apear each part  remove (:)
As a newbie in Maple2024, my next step is to try to solve a Diophantine equation. Attempts with isolve failed. It is the famous task B3 from the IMO of 1988:
If for integers x and y the fraction (x^2+y^2)/(1+x*y) is a positive integer, then it is actually a square number.
The solution is well known. But I would like to learn how to use Maple using this example and would like some advice.
Best regards, Alfred_F
So I have this Maple document that I worked on yesterday, and now when I open it it just opens as the start-up screen where I can choose between document and worksheet mode. I can see that the file is much larger (900 kb) than an empty document, so it should definitely have the data still in there, but opening it with a text editor I couldn't manage to fix my issue. Does anyone have any tips? I have a back-up of the file (from the restore backup menu), but most of the content is not there, so it would be very helpful to get this one fixed.
Exercises.mw
Thanks in advance,
Kristian.
By using the second order ODE and its solution how i can get thus changing Rule?  i am looking for equation (8) by assumption of the paper he did, there is a trick but i don't know
idea.mw
Dear Power Users, Dataframes are a powerful tool within Maple. However, when I have 'undefined' in cells "Aggregate" or "DataSummary" does not provide answers. However, when I use "Statistics:-Mean" with the additional option "ignore=true" I can get an answer for one column (see attached worksheet). Adding "ignore" to aggregate apparently does not work. What is the method for ignoring the undefined data? In Excel when a cell is blank it will be ignored. Thank you for any help given.MP_Aggregate.mw
Ive been wondering what i can use this for and where maybe it has been overlooked ,if any one has any ideas im really interested, that pi^ cubed
360°/rad/pi^2
I
I analyzed the kinetic equation of the system and got this formula. I want to realize the sweep frequency analysis of the kinetic function by changing the size of omega2, but I don't know how to write a program. Want to ask for help
solve831.mw
In the Standard interface, the length of an expression that display in the worksheet can be limited using the Options dialog: Options Dialog - Precision Tab - Maple Help. However, I would like to know if I can change this option programmatically. The closest interface variables are elisiontermsbefore, elisiontermsafter and termelisionthreshold, but as the aforementioned help page states, they control the “term elision” and are not the same as “expression length limit”. So, is this possible?
Maple help pages keep getting worst with each release.
I want all input to be displayed using Maple 1D notation, so I can copy the example to my worksheet since I only use worksheet and not document (2D) mode.
So even though the first thing I do when I open help it to turn off the
                     view->Display examples with 2D
So it is no longer checked, I still see many pages using 2D math for input.
Here is one example ?D  page
If I copy one such input to my worksheet now it looks like this
eveything in 2D becomes ?? when I copy it.
So one can only look but not copy?
Is there any other option to make sure, really make sure, all examples have 1D as input?
The problem is that it is all not consistent. Some examples have a mix of 2D and 1D as the above page. Some are in 2D and some are in 1D.
And this is all on the same help page!
Does no one inside Maplesoft even look at their own help pages?
First 27 28 29 30 31 32 33 Last Page 29 of 371
