On my journey of discovery in the Maple world, which is new to me, I have now looked at the linear algebra packages. I am less interested in numerics than in symbolic calculations using matrices. I would like to illustrate this with the following task:
Let A be any regular (n; n) matrix over the real numbers for natural n. The regular (n; n) matrix X that solves the equation
X - A^(-1)*X*A = 0 for each A is to be determined. In this, A^(-1) is the inverse of A. Is there perhaps a symbolic solution for a specifically chosen n?
The solution to this old exercise is known. X is every real multiple of the unit/identity matrix, i.e. the main diagonal is occupied by a constant and all other matrix elements are zero.
Executing the code in ?InvertedPendulum produces an error when
sysLin := Linearize(convert(sysEqs, list), [u(t)], [x(t), theta(t)], lin_point)
is executed. The problem is the line where EQ4 is assigned a value.
Something is wrong with the line where EQ4 is assigned a value. It is not executed.
It is like the mode changes to text for that line????
I thought I had post with collection showing timelimit still hangs in Maple. But can't find it searching. I wanted to add this to it.
If someone finds such post, please let me know and I will append this to that post and delete this.
I just found another example where int() hangs all of Maple, using timelimit. I put timelimit of 30 seconds. After 2 hrs it is still running.
Maple 2024.1 on windows 10. This shows clearly that timelimit in Maple still does not work when It was supposed to have been fixed in Maple 2021?
For me, if there is anything that will make me stop using Maple for good, it is this timelimit issue.
Because with timelimit not working all the time, my program keeps hanging. It is not possible to do antything then. Having to keep checking if the program is still running or have hanged and restarting it is not a way to develop software.
Software that have been in development for almost 45 years now like Maple, should have figured by now how to implement timelimit that works.
Note that, with smaller timelimit it is possible it will  not hang, because longer time limit makes it end in the code path which causes the hang. When I tried 5 seconds for example instead of 30 second, it did not hang With 30 it does. so if you try it and it does not hang, please increase the timelimit a little and it will surely hang. Just make sure to do restart each time, since Maple remembers last result.
maple's server.exe was running at full cpu also.
`Standard Worksheet Interface, Maple 2024.1, Windows 10, June 25 2024 Build ID 1835466`
Physics:-Version();
`The "Physics Updates" version in the MapleCloud is 1810 and is the same as the version installed in this computer, created 2024, September 18, 18:16 hours Pacific Time.`
libname;
"C:\Users\Owner\maple\toolbox\2024\Physics Updates\lib", "C:\Program Files\Maple 2024\lib"
M:=-6*(3^(1/2)*(27*R^2-4)^(1/2)-9*R)^(1/3)/(-6*(3^(1/2)*(27*R^2-4)^(1/2)-9*R)^(1/3)*R+(-6*I*3^(1/6)-2*3^(2/3))*2^(1/3)+2^(2/3)*(I*3^(5/6)-3^(1/3))*(3^(1/2)*(27*R^2-4)^(1/2)-9*R)^(2/3));
try #this hangs
    timelimit(40,int(M,R));
    print("finished with no timeout");
catch:
    print("waiting for timeout");
end try;
-6*(3^(1/2)*(27*R^2-4)^(1/2)-9*R)^(1/3)/(-6*(3^(1/2)*(27*R^2-4)^(1/2)-9*R)^(1/3)*R+(-(6*I)*3^(1/6)-2*3^(2/3))*2^(1/3)+2^(2/3)*(I*3^(5/6)-3^(1/3))*(3^(1/2)*(27*R^2-4)^(1/2)-9*R)^(2/3))
Download int_hangs_with_timelimit.mw
Update OCT 10, 2024
This is another example showing hang in Maple 2024.1 using timelimit. So adding it to this collection. I had large collection of such problems but not able to find it now.
I was trying to verify this solution (which could very well be wrong) on ode with IC. timelimit hangs when I added assumptions as shown. Used 10,20,30 seconds, and so on. all hang. Waited and waited.
Does it hang on other systems? I am using Windows 10 and Maple 2024.1 with 128 GB RAM on fast CPU.
sol:=y(x) = -8/9*x-11/9+1/9*arcsin(1/103*2509^(1/2)*tan(1/5*(x+5/2509*2509^(1/2)*arctan(1/2509*2509^(1/2)*(103*tan(37)+90*sec(37)))-1)*2509^(1/2))*(90*2509^(1/2)*tan(1/5*(x+5/2509*2509^(1/2)*arctan(1/2509*2509^(1/2)*(103*tan(37)+90*sec(37)))-1)*2509^(1/2))-103*(2509*tan(1/5*(x+5/2509*2509^(1/2)*arctan(1/2509*2509^(1/2)*(103*tan(37)+90*sec(37)))-1)*2509^(1/2))^2+2509)^(1/2))/(2509*tan(1/5*(x+5/2509*2509^(1/2)*arctan(1/2509*2509^(1/2)*(103*tan(37)+90*sec(37)))-1)*2509^(1/2))^2+10609)-90/103):
ode:=5*diff(y(x),x) = 7+10*sin(8*x+9*y(x)+11):
IC:=y(1) = 2:
func:=y(x);
y(x)
try
    timelimit(30,`assuming`([odetest(sol,[ode, op(IC)],func)],[positive, func::positive]));
catch:
    print("timed out OK");
end try;
print("After try/catch");
Download time_limit_hang_example_oct_10_2024.mw
I would like to officially offer $1,000 prize for any one who can solve the timelimit hanging problem in Maple. Will send you personal check of this amount if you find why it hangs and provide fix to use that I can verify works.
I recently moved from Windows 10 to Windows 11. I am using Maple 2022.2, and I got that installed and working OK.
I have four Maple worksheets that I have saved as tasks on Windows 10, but my OS move requires some adjustments. When I try save the modified worksheets to the default Maple help database, I get an error saying that the database is read-only. When I try to make a new database file, Maple asks if it should create it, but then I get an error that Maple can't open the new database.
Suggestions?
Jno.
I have the function  and derivate with respect to ν and make the change variable ν=1/t it seems it doesn’t work. I put the derivate of 1/t => -1/t2 by hand  (could it be done by “dchange” the hole transformation ?)
I want to approximate the value of the integral. It seems that the solution of the equation and plot in 2 situations for low-frequency ν < 1014  and for high frequency so  when the exponential is dominated.
Thus plot the whole function E2 in the two situations. Could it be done with a series?
For value h := 6.62607015*10^(-34); c := 299792458; T := 273 + 24; k := 1.380649*10^(-23);
ec := 1.602176634*10^(-19); ν1 :=1012 ; ν2 := 1017 ;Tq := 1.765358264*10^(-19);
Could it be merged E2 into one plot for ν = 1012 .. 1017?
PPh1.mw
Loop is not executing all values just considerinng 1st value of tau0 =0.3.
Also how to plot a 2D graph from the loop result
Attaching sheet with questions in the sheet:
for_loop_question_rec.mw
Dear Maple user
I want to add caption for all four graphs with a,b,c,d at the bottom centre of each graph that should be arrange in 2X2 array and the array bottom caption as Figure 6, also i want to save the output of the array graphs in desktop with jpeg format. sample graph i have uploaded.
A1:= plot(sin(x), x = -Pi .. Pi,title = "Graph at M^2=1",caption = "Fig a"):# This caption is at the centre bottom of first graph and the title of A1 is M*M (M^2)should be display
A2:= plot(cos(x), x = -Pi .. Pi,caption = "Fig b"):# This caption is at the centre bottom of second graph
A3 := plot3d(1.5^x*sin(y), x = -3 .. 3, y = -3 .. 3,caption = "Fig c"):# This caption is at the centre bottom of Third graph
A4 := plot3d(1.3^x*sin(y), x = -1 .. 2*Pi, y = 0 .. Pi,caption = "Fig d"):# This caption is at the centre bottom of forth graph
display(Array(1 .. 2, 1 .. 2, [[A1, A2], [A3, A4]]), aligncolumns = [1],caption = "Fig 6"):# This caption at the bottom centre of array graphs
I cannot remember that this was an issue in Maple 6/9/11, so it must have changed later on up to 22.
The following limit fails to execute
1/(r_S^5*(_C2*r_S^4 + _C2*r_S^3 + _C2*r_S^2 + f[3](0)*r_S + f[4](0)));
limit(%, f[4](0) = infinity);
It fails to calculate the limit with result as zero.
Bernoulli first order ode has form as show in wikipedia  and also on Maple own site as
Notice that it is P(x)*y above and not P(x)* y^(-1) so the y(x) must be linear in that term.   But when I give Maple this ode
ode:=diff(y(x),x) + x*y(x)^(-1)= y(x)^(-1);
Which is clearly not of the form above, it solves it as Bernoulli.  In the above ode, P(x) is x and Q(x) is 1 and n is -1.
The ode advisor correctly said it is separable. But trace shows it used Bernoulli. Also when asking it to solve it as Bernoulli, it does.
What Am I missing here?  Is it not wrong for Maple to use Bernoulli method on this ode which is not Bernoulli?
Worksheet below
Physics:-Version();
`The "Physics Updates" version in the MapleCloud is 1805 and is the same as the version installed in this computer, created 2024, September 3, 11:35 hours Pacific Time.`
libname;
IC:=y(1) = 0;
DEtools:-odeadvisor(ode);
diff(y(x), x)+x/y(x) = 1/y(x)
y(1) = 0
[_separable]
infolevel[dsolve]:=5;
dsolve(ode,y(x));  #why this says it solved it as Bernoulli ?
Methods for first order ODEs:
--- Trying classification methods ---
trying a quadrature
trying 1st order linear
trying Bernoulli
<- Bernoulli successful
y(x) = (-x^2+c__1+2*x)^(1/2), y(x) = -(-x^2+c__1+2*x)^(1/2)
dsolve(ode,y(x),[Bernoulli])
Classification methods on request
Methods to be used are: [Bernoulli]
* Tackling ODE using method: Bernoulli
trying Bernoulli
Download why_this_ode_bernullli_sept_15_2024.mw
I don't know how make my graph be beter for real part and imaginary part and abs part which part how work with parameter can any one explain on this example?
G.mw
I've recently started to move my Maple software development from pure Maple to Visual Studio Code with GitHub. Previous code attachments in workbooks are now moved to its own folders, and fetched by the $include instruction.
The approach works quite well, but I have experienced a strange effect. While the Maple workbook itself is in the local GitHub folder, I do experience that when documents within the Maple workbook, after a while the code is fetched from the backup location. This doesn't work, as the $included files can't be found there. Only way is to close the workbook, and open it again.
First image shows location of Maple workbook, second location of document (backup position, error), third location of document after reopening workbook (working).
i did two case of this equation and odetest is worked good but in this case the odetest is not worked well anyone can determine what is mistake ?
F_P_Correct_case_three.mw
Dear Maple user I am facing error while running the codes  to plot the graph for two data sets .
I am attaching the files.
Error_in_Display_1.mw
HTR.mw
In above problem, Additionally How to  plot  heat transfer rate  Q versus L^2  for distinct porosity parmeters(Sh) , using  heat transfer rate formula, Q = (q*L)/(k*A*T[b])=theta'(1).
using  [Sh = 0.1, L^2 = 0.1, Nr =0 .1, Ha =0 .1, Pe = 0.1],  [Sh = 0.3, L^2 = 0.3, Nr = 0.1, Ha = 0.1, Pe =0 .1],   [Sh = 0.5, L^2 =0 .5, Nr =0 .1, Ha = 0.1, Pe =0 .1].
I get my on results but the results are not the same please help me if i did any mistake in my code
symmetry_PDESYS_3_time_fraction[1].mw
First 26 27 28 29 30 31 32 Last Page 28 of 371
