I have a problem.
I solved a problem, but i like to get one solution for one variable.
i send my project.
help me please.21-07-2011_-ecuacion.mw
Dear guys
In my program I have a loop and after some calculation I want to write the results. I use:
" writedata("D:\\arvin\\bao-cmb-h.txt", convert(T, array), float);"
but maple give me an error:
" Error, (in convert/list) object too large "
how can I write my data?
I'm developing an application that I'd like to use elements of an array as parameters in MapleSim components - is there a way to use Maple arrays/vectors in MapleSim?
Also is there a way to open a file and read its contents (data) as the starting point (parameter set) for a MapleSim simulation?
Hi Dr. Kamel Boughrara,
I have a question,  I know phi = B*A, but in code i can't understand a part of it, can you kindly explain it in engineering terms.
kindly see the attach file for phi.
Second question
why e-->sum(factor(e(t)),n=1..100), wht this means,
Hi guys,
I am working on the following pde
m0=-Bwssss+(Ft-Bwss2)s(ws+rs0)+(Ft-Bwss2)wss+q
where
Ft=EAe+T0+pwgPiDo2 (Hw-z)/4-pmgPiDi2 (Hm-z)/4
I have question regrding the analytical solution in section 3.3,  I am attaching a file.   Question is regarding  the programming you did, does it has any effect on the solution.  Because i tried to change the values for p, and other variables but could't see the effect.
Also wht the following variable means;
Hi i´m writing a paper about math and i use maple 10 and M. Word 2007 for it, i started with a Laptop with Windows 7 and when i finished it, i open the archive in a desk computer having the same especifications  i notice that the images of ecuations were altered changing "+" and "-" for "C´s" and "K´s", i tried a lot of computers with others especifications and my problem still the same, i changed the format and other stuff but i can´t...
I have a question related to Modulated Markov Rate Process (MMRP). Please see MMRP and here. For more information see this
In this kind of markov chain it is necessary to have ON and OFF state that separte by a exponential distribution. Also the number of items as mentioned in the figures has a...
i use symmetric function package
with(SF):
i would like to know after calculating the basis toS(....)
which function can be used to convert into polynomials?
as i expect to get the sequence from any polynomials generated from it
Hi:
I am running a home network, XP and Maple 11 on the old computer, Win 7 and single-user Maple 15 on the new.
It took a long time, but I finally got a wireless network running, so that Win7 on the new computer can open and access all the files on the old computer.
But when I run Maple15 on the new computer and try to open an old computer file, Maple 15 cannot see the old computer or any of its directories, even though it has a "network" tab on the "open" command.
If you create a Maplet using the Maplet builder, how can you insert it into your worksheet ? ... e.g. having a hyperlink or button which when clicked runs your Maplet ?
I'm using maple 13.
The expression that I paste below is quite large and subsequent expressions are also swelling. This is causing maple to slow down and in some instances I get a message saying the kernel has disconnected (maple just times out) I want a way to programmatically reduce the size of the output. I have tried simplify(expr,size) and this has helped some. I don't want to use simplify(expr,symbolic) because of the presence of the square roots. Is there...
which package can calculate schwinger function?
I hope I've got the terminology right...
I've got a set of functions that I want to display in a maplet table. The tables shows up fine, except all the functions are written like:
x^2+1
What I'd like is them to be shown like:
x^2+1
I've tried playing with MathMLViewer, but that doesn't seem to work.
In coding theory, there are parity-check codes whose parity-check matrices H are generated via column permutations. For instance, the LDPC codes constructed in Gallager's 1962 IRE Trans paper uses the following H matrix:
[ X1 ]
[ X2 ]
[ Xn ]
where submatrices X2 .. Xn are just random column permutations of X1. However, to make the codes efficient in decoding, there is one restriction which requires that any two row vectors in...
First 329 330 331 332 333 334 335 Last Page 331 of 371
