 I am having a very hard time with numerical stability. I am solving system of ode's (7-coupled ode's) using dsolve(stiff) and then using spline function for interpolation and finally solving system of pde's (2-coupled pde's) using pdsolve for one time step and solving all again for the next step. the solution is not stable and it requires very fine/small time step. Is there any procedure/method to improve the stability?
 What is the stability criteria of dsolve...
how to rewritten the PDEs to the matrix form like the following in Maple
Thank you for suggestions. The system in matrix form looks like z(k+1)=Az(k). The solution to that is z(k)=A^kz(0). Now, phase planes of the system would look different for different matrix A (specifically, eigenvalues of A). For example, for complex eigenvalues phase plane would look like a spiral. I'm having difficulties plotting those phase planes. It's easy for differential equation, but I'm not sure how to work with system of difference equation in Maple.
I have attempted making a translation the Wolfram Mathematic's document: Singular Value Decomposition.
I present Problems in showing the arches of angles. Besides result do not correspond .
Plot_singular_value_.mw
Gracias
Is there any way to modify the shading colors used in shading=zhue?
Maybe similar to what was done in the post for Color of the plot of convex hull of points or perhaps there is simpler way?
Dyson_Mclean_V3.mw
Dyson_Mclean_V5.mw
Hi All,
I have a question that I see has been seldom discussed except certain posts by Mr. Lopez. This concerns the estimation of optimum parameters of the solution of a system of differential equations to fit experimental data. I referred to the Maple document provided by Mr. Lopez on the Maplesoft website.
Good morning.
I want to do a program in a worksheet that it can recall other workeet for plotting with display.
I don´t know how can recall other worksheets.
Please help me.
P.D.: I send a worksheet 01-06-2011-robot-man.mw
I have a pbs: Suppose 3 vector A, B,C with noted [A:B]:=(list)[ A,B,-A,-B] (i.e a paralelogram);
An endomorphism T such that T(.) where (.)=A,B or C are B,C, and (list)[C,-A,-B,-B]
 and T([x:y])=[T([x]):T([y])] where x,y = A,B or C.
Problem: draw T^{n}[A:B] , i.e its boundary is a fractal figure when n is big.
GDQM2.mw
I am facing a very complicated system of nonlinear equation. This cannot be solve by using normal fsolve in Maple. Anyone can help me?
Thanks a lot
with(Physics):with(combinat):
comn := choose([u, v, mu, nu], 2):
def := seq(seq(seq(Physics[`.`](Dagger(Ket(aa, k)), Ket(bb, m)) = Physics[`.`](Ket(bb, m), Dagger(Ket(aa, k))), `in`(aa, comn[i][1])), `in`(bb, comn[i][2])), i = 1 .. nops(comn)), seq(seq(seq(Dagger(Physics[`.`](Dagger(Ket(aa, k)), Ket(bb, m)) = Physics[`.`](Ket(bb, m), Dagger(Ket(aa, k)))), `in`(aa, comn[i][1])), `in`(bb, comn[i][2])), i = 1 .. nops(comn));
Setup(def):
d1 := Physics[`.`...
I  used the DEtools package recently.
When working in a differential algebra with _Envdiffopdomain=[Dt,t] maple still returns something like Dt t^2. I would like him instead to assume, that Dt= dt/t and rewrite it as 2t + t^2 Dt. How can I achieve this behavior?
Hi , I'm Alan GHafur , I'm student in master dagree in Statistic in Irbil / Iraq .I want learn how can slove non linear function in Maple.
thank you for hlep me.
In 2D input it is possible to represnet
diff(f,x) as d/dx f
Is it possible to do
diff(f,x,x) as d^2/(dx)^2 f somehow?
Can one perform animation using the data file.
I want to animate the graph betweeen two variables say x and y, which I have stored in a data file. Does maple support any such operation?
I wrote a loop which is too long but I need its continuity so I wrote all of them in one loop.
The problem is too much time is needed to run it,even maple cannot run it.
I do not know whether my software has a problem or the way I wrote the program is wrong.
I attached the file.
result2_with_op90_to.mw
First 330 331 332 333 334 335 336 Last Page 332 of 371
