got an error when try to jacobian this
with(VectorCalculus):
f1 := -2*x1-x2; f2 := -x1-4*x2; g1 := 2*x1+3*x2-6; g2 := -x1; g3 := -x2;
penalty := lambda1*max(f1-M,0) + lambda2*max(f2-M,0) + (M^2)*(max(g1,0) + max(g2,0) + max(g3,0)):
obj := eval(penalty,[lambda1=3,lambda2=0.645,M=1]);
Hf := Jacobian(Jacobian(obj, [x1, x2, x3]), [x1, x2, x3]);
Error, invalid input: VectorCalculus:-Jacobian expects its 1st argument, f,
to be of type {Vector(algebraic), list(algebraic)}, but received 3*max(0, -2*x1-x2-1)+.645*max(0, -x1-4*x2-1)+max(0, 2*x1+3*x2-6)+max(0, -x1)+max(0, -x2)
Why does MapletViewer launch the Maplet Splash Screen and then pop up a box saying it has an error launching the Maplet spash screen? As my previous question stated, it also will not run the maplet, popping up another error box as "explanation".
convert(50, base, 12);
this can change base for integer, however can not change decimal
assume i change decimal to fraction first and then apply convert base to 12 to numer and denom, and divide again to get decimal
it may get a decimal based on base 12
however, how to make this base 12 operation apply in linear algebra calculation
https://drive.google.com/file/d/0B2D69u2pweEvUDJIeGlOVjFvNWc/edit?usp=sharing
https://drive.google.com/file/d/0B2D69u2pweEvV1BiRXhULTNPcWM/edit?usp=sharing
https://drive.google.com/file/d/0B2D69u2pweEvdXNrRlNadldXS0U/edit?usp=sharing
i find that maple 15 values are the same as extreme optimization library however, the sign are different
is it maple 15 accuracy correct or extreme library correct?
https://drive.google.com/file/d/0B2D69u2pweEvT01pazBxOEk1bWc/edit?usp=sharing
i worry for my research whether based on correct accuracy.
it can run without error in maple 15, however, the eigenvector values are wrong in maple 15 different from eigenvector function's result
then i test it in maple 12, it got error when run with following input
Error, invalid input: simplify uses a 1st argument, s, which is missing
> InputMatrix3;
                           [[30.15,29.95,29.95],[29.95,29.95,0],[29.95,0,0]]
NewInput3 := MatrixMatrixMultiply(Transpose(InputMatrix3), InputMatrix3);
FirstEigenValue := solve(Determinant(NewInput3-Matrix([[lambda1, 0, 0], [0, lambda1, 0], [0, 0, lambda1]])), lambda1)[1]; # find back eigenvalue from eigenvector
SecondEigenValue := solve(Determinant(NewInput3-Matrix([[lambda1, 0, 0], [0, lambda1, 0], [0, 0, lambda1]])), lambda1)[2]; # find back eigenvalue from eigenvector
ThirdEigenValue := solve(Determinant(NewInput3-Matrix([[lambda1, 0, 0], [0, lambda1, 0], [0, 0, lambda1]])), lambda1)[3]; # find back eigenvalue from eigenvector
v:=[ FirstEigenValue, SecondEigenValue, ThirdEigenValue];
NewMatrix3 := Matrix([[x1,x2,x3], [x4,x5,x6], [x7,x8,x9]]);
EigenvectorSol := simplify(solve({seq(seq((NewMatrix3 . NewInput3(1..-1,i))[j]=(v[i]* NewInput3(1..-1,i))[j], j=1..3), i=1..3)}, {seq(x||i, i=1..9)}));
EigenvectorT := Matrix([[rhs(EigenvectorSol[1]), rhs(EigenvectorSol[2]), rhs(EigenvectorSol[3])],[ rhs(EigenvectorSol[4]), rhs(EigenvectorSol[5]), rhs(EigenvectorSol[6])],[ rhs(EigenvectorSol[7]), rhs(EigenvectorSol[8]), rhs(EigenvectorSol[9])]]);
Old_Asso_eigenvector := Eigenvectors(MatrixMatrixMultiply(Transpose(InputMatrix3), InputMatrix3));
hi
DirectSearch answer has confused me. How to reduce the residual.
See the program.Direct.mw
Hi Maple users :)
do you know if exists a Maple package in order to perform a Panel method, for instance in the Hess-Smith version, for solving incompressible potential flow over thick 2d and 3d airfoil geometries?
Thank in advance for the help.
I have a matrix then I need to plot its columns as curves on one plot.
how to convert decimal number into given decimal number like algebra
for example, convert 191.715 , given a=12.2, b=3.5
how to find this a^2 + b^3
m := Matrix([[a1,a2,a3],[a4,a5,a6],[a7,a8,a9]]);
m2 := Determinant(m-Matrix([[1,0,0],[0,1,0],[0,0,1]]));
1. which family of polynomials do m2 belong to?
2. how to analyze m2?
Dear Friends
I have a problem in CPU time in MAPLE.
I write the codes in maple related to the nonlinear heat conduction problem in one dimension by Collocation method, but after 30 minutes no solution has been observed!!!
My codes are for N=4!, i.e., I have 25 equations with 25 unknowns!!!
If MAPLE can not solve this simple system, How can I solve 3 dimensional pdes by N=9,
In this case, I have 1000 equations with 1000 unknowns!!!
please help me and suggest me a fast iterative solver.
I should remark that my problem is stated in this paper
http://www.sciencedirect.com/science/article/pii/S1018364713000025
If there exist any other suitable method, I will be happy to receive any support.
With kind regards,
Emran Tohidi.
> restart;
> Digits := 20; N := 4; st := time(); u := sum(sum(a[m, n]*x^m*t^n, m = 0 .. N), n = 0 .. N); u := unapply(u, x, t); ut := diff(u(x, t), `$`(t, 1)); ut := unapply(ut, x, t); ku := simplify(1+u(x, t)^2); ku := unapply(ku, x, t); ux := diff(u(x, t), `$`(x, 1)); ux := unapply(ux, x, t); K := ku(x, t)*ux(x, t); K := unapply(K, x, t); Kx := diff(K(x, t), `$`(x, 1)); Kx := unapply(Kx, x, t); f := proc (x, t) options operator, arrow; x*exp(t)*(1-2*exp(2*t)) end proc;
print(`output redirected...`); # input placeholder
> S1 := {seq(u(i/N, 0)-i/N = 0, i = 0 .. N)}; S2 := {seq(u(0, j/N) = 0, j = 1 .. N)}; S3 := {seq(u(1, j/N)+ux(1, j/N)-2*exp(j/N) = 0, j = 1 .. N)}; S4 := {seq(seq(Kx(i/N, j/N)+f(i/N, j/N)-ut(i/N, j/N) = 0, i = 1 .. N-1), j = 1 .. N)}; S := `union`(`union`(`union`(S1, S2), S3), S4); sol := DirectSearch:-SolveEquations([op(S)], tolerances = 10^(-4), evaluationlimit = 1000000);
> assign(sol);
> u(x, t);
> CPUTIME := time()-st;
plot3d(u(x, t) - x exp(t), x = 0 .. 1, t = 0 .. 1)
I just bought and installed "The mathematical Survival Kit" but I can't figure out how does it work
Anybody can help?
Thanaks
Martina
with(combinat):
symMonomial := proc(test)
h := 0;
for i from 1 to nops(test) do
                h[i] := choose(test,i);
od;
c := copy(test);
k := 0;
for k from 1 to nops(test) do
                c[k] := 0;
                for i from 1 to nops(h[k]) do
                                ki := 1;
                                for j from 1 to nops(h[k][i]) do
                                                ki := ki*h[k][i,j];
                                od;
                                c[k] := c[k] + ki;
                od;
od;
return c;
sympoly := proc(test, number_of_roots)
with(combinat):
h := 0;
                h[i] := choose(z,i);
od;
c := 0;
                c[k] := 0;
                                ki := 1;
                                                ki := ki*h[k][i,j];
                                od;
                                c[k] := c[k] + ki;
                od;
od;
poly := x^number_of_roots;
for k from 1 to number_of_roots do
                poly := poly + c[k]*x^(number_of_roots-k);
od;
z := [x1, x2, x3, x4, x5, x6, x7, x8, x9, x10];
sigma := symMonomial(z);
f := expand(sigma[1]*sigma[2]);
f := expand(sigma[1]*sigma[1]); # two lambda value are the same
f := expand(sigma[1]*sigma[1]*sigma[1]); # three lambda value are the same
f := expand(sigma[1]^2+2*sigma[1]*sigma[2]+sigma[2]);
f := subs(x1=3, f);
f := subs(x2=2, f);
f := subs(x3=3, f);
f := subs(x4=4, f);
f := subs(x5=5, f);
f := subs(x6=6, f);
f := subs(x7=7, f);
f := subs(x8=8, f);
f := subs(x9=9, f);
f := subs(x10=lambda, f);
evalf(solve(f, lambda));
if degree(f) = 2 then
                f := f + lambda^3;
how to convert above f back to matrix form such as
m-Matrix([[lambda,0,0],[0,lambda,0],[0,0,lambda]]);
m2 := Determinant(m-Matrix([[lambda,0,0],[0,lambda,0],[0,0,lambda]]));
after tested m2 can not be expressed in terms of shell like polynomial,
it seems that it is from symmetric polynomial and it is from a non-homogenous polynomial which homogenize with a lambda
if solve f for new eigenvalue,
can traditional eignvector method calculate new eigenvector for these new kind of eigenvalues method?
A*x = lambda*x
in maple 15
https://drive.google.com/file/d/0B8F2D27rfQWgVXE1alN0V3JWU1U/edit?usp=sharing
there are 3 equation to be minimized
and i limit x between x + 5 and x - 5 as constraints
though f1 got a error in first line of command,
later i type a correct command for f1 in later part of script
What is the command to get a sequence of the first twenty prime numbers
First 267 268 269 270 271 272 273 Last Page 269 of 371
