I have some data for a model in MapleSim that I would like to use a time look up table with.  I've found that the two options for interpolation are linear and 1st derivative, but the data was intended to be interpretted as piecewise constant.  Is there any way to acheive this option in MapleSim?
Code was computed on two different PC:
1) Win 8.1, Maple 17.02 x64
2) Win 8.1, Maple 18.01 x64
In brief:
n:=3:
Grid:-Seq('f(i)', i = 1 .. n):
works well in Maple 17.02 but gives an error in Maple 18.01. Why?
However,
(j -> Grid:-Seq('f(i)', i = 1 .. j))(n):
works well for both Maple versions.
according to examples from Maple help page
http://www.maplesoft.com/support/help/Maple/view.aspx?path=Grid%2fSeq
we have to pass exactly 'f(i)' (not just f(i)) into Grid:-Seq(...). Why?
Why doesn't Digits:=30: work properly for Grid:-Seq(...)?
For details see attached file. Output was produced in Maple 17.02. In Maple 18.01 the output will differ.
restart; n := 3; f1 := proc (i) options operator, arrow; evalf(sqrt(i)) end proc; f2 := proc (i) options operator, arrow; evalf(sqrt(i+1)) end proc; f3 := proc (i) options operator, arrow; evalf(i*Pi) end proc; g1 := proc (f, n) local za, zb, zc, str; str := sprintf("g1(%a,n)", f); za := seq(f(i), i = 1 .. n); zb := Grid:-Seq(f(i), i = 1 .. n); zc := (proc (j) options operator, arrow; Grid:-Seq(f(i), i = 1 .. j) end proc)(n); print("------------------------------"); print(cat("(a):   ", str), za); print(cat("(b):   ", str), zb); print(cat("(c):   ", str), zc); print("------------------------------") end proc; g2 := proc (f, n) local za, zb, zc, str; str := sprintf("g2(%a,n)", f); za := seq('f(i)', i = 1 .. n); zb := Grid:-Seq('f(i)', i = 1 .. n); zc := (proc (j) options operator, arrow; Grid:-Seq('f(i)', i = 1 .. j) end proc)(n); print("------------------------------"); print(cat("(a):   ", str), za); print(cat("(b):   ", str), zb); print(cat("(c):   ", str), zc); print("------------------------------") end proc
g1(f1, n);
"(a):   g1(f1,n)", 1., 1.414213562, 1.732050808
"(b):   g1(f1,n)", 1, 2^(1/2), 3^(1/2)
"(c):   g1(f1,n)", 1, 2^(1/2), 3^(1/2)
"(a):   g1(f2,n)", 1.414213562, 1.732050808, 2.
"(b):   g1(f2,n)", 1.414213562, 1.732050808, 2.000000000
"(c):   g1(f2,n)", 1.414213562, 1.732050808, 2.000000000
"(a):   g1(f3,n)", 3.141592654, 6.283185308, 9.424777962
"(b):   g1(f3,n)", 3.141592654, 6.283185308, 9.424777962
"(c):   g1(f3,n)", 3.141592654, 6.283185308, 9.424777962
"(a):   g2(f1,n)", 1., 1.414213562, 1.732050808
"(b):   g2(f1,n)", 1., 1.414213562, 1.732050808
"(c):   g2(f1,n)", 1., 1.414213562, 1.732050808
"(a):   g2(f2,n)", 1.414213562, 1.732050808, 2.
"(b):   g2(f2,n)", 1.414213562, 1.732050808, 2.
"(c):   g2(f2,n)", 1.414213562, 1.732050808, 2.
"(a):   g2(f3,n)", 3.141592654, 6.283185308, 9.424777962
"(b):   g2(f3,n)", 3.141592654, 6.283185308, 9.424777962
"(c):   g2(f3,n)", 3.141592654, 6.283185308, 9.424777962
Digits := 30;
30
"(a):   g1(f1,n)", 1., 1.41421356237309504880168872421, 1.73205080756887729352744634151
"(a):   g1(f2,n)", 1.41421356237309504880168872421, 1.73205080756887729352744634151, 2.
"(a):   g1(f3,n)", 3.14159265358979323846264338328, 6.28318530717958647692528676656, 9.42477796076937971538793014984
"(b):   g1(f3,n)", 3.14159265358979323846264338328, 6.283185308, 9.424777962
"(c):   g1(f3,n)", 3.14159265358979323846264338328, 6.283185308, 9.424777962
"(a):   g2(f1,n)", 1., 1.41421356237309504880168872421, 1.73205080756887729352744634151
"(a):   g2(f2,n)", 1.41421356237309504880168872421, 1.73205080756887729352744634151, 2.
"(a):   g2(f3,n)", 3.14159265358979323846264338328, 6.28318530717958647692528676656, 9.42477796076937971538793014984
Download Grid[Seq].mw
i am trying to export an animated gif file but the export windows freezes and exports an empty file with zero bytes
the animation was created by: display(map(p, convert(A(() .. (), 2), list)), insequence = true)
i have tried to give maple some time (2-3 hours) and i even tried to restart the computer and lauch maple and try to export it but it didnt worked
how can i export it or how can i plot the using commands
Greetings everyone. I tried to get the roots of this polynomial by using allvalues command. But I got the roots in indeces instead of the value of the roots.
what should i do?
matlab has break point in loops which in extremely useful tool for finding errors in long term loops,whay maple does not has sth similiar !?
How to identify whether biased game is changed based on the latest toss from a sequence
can HMM identify this?
for example
if
fair fair fair biased biased fair fair biased
I have a system of diff equations (see below). I am trying to obtain analytical solution. when I assume that z=wN, I receive such solution. Do anybody have idea if I know that z>wN, does this system has an analytical solution?
diff(K(t), t) = -(1/2)*(Q(t)^2*alpha^2*eta*upsilon-2*eta*alpha*(N*upsilon*w*C[max]-z*alpha*K(t))*Q(t)+N*w*(-2*C[max]*z*eta*alpha*K(t)+upsilon*((-N*w+z)*alpha+N*C[max]^2*w*eta)))*K(t)/((C[max]*w*N-alpha*Q(t))*upsilon*N*w)
diff(Q(t), t) = (1/2)*(-z*(Q(t)^2*alpha^2*eta-2*N*Q(t)*alpha*eta*w*C[max]+w*(w*(eta*C[max]^2-alpha)*N+z*alpha)*N)*K(t)-2*N*upsilon*w*(N*w-z)*(C[max]*w*N-alpha*Q(t)))/((C[max]*w*N-alpha*Q(t))*upsilon*N*w)
K(0) = K0, Q(0) = Q0
Dmitry
http://www.math.uni-frankfurt.de/~numerik/maplestoch/
read "D:/diffalg03/stochastic9";
Sigma := `<,>`(`<|>`(1.0, .5), `<|>`(.5, 1.0));
V := WienerProcess(Sigma);
Z := t -> exp(a*t+b*V(t)[1]+c*V(t)[2]);
drift1 := simplify(Drift(Z(t))/Z(t));
diffusion1 := simplify(Diffusion(Z(t))/Z(t));
with(stochastic);
linearsde(drift1, diffusion1[1][1]);
Euler(x[1],drift1,diffusion1[1][1]);
1.what are a, b, and c?
2. how to convert SDE for monte carlo for this ito formula?
3. how to convert to euler scheme with this ito formula
When greek symbols are used in code edit region (by copying from worksheet 2d math mode), they used to get exported properly to PDF but the only issue was large code edit region used to get cut off. But now with this new 18.01 update, code edit region is not cut off but greek symbol inside code edit region are not appearing in PDF export instead just pink boxes. Has anyone else also encountered this issue and suggest a resolution.
I am trying to find out the stiffness matrix of composite by using iterative loop that sums over each laminate and adds the result to the previously calculated matrix
D=null matrix
for i to 4 do Dply := evalf(evalm((1/3)*Q[i]*(z(i+1)^3-z(i)^3))); D := evalm(D+Dply) end do;
evalm(D);
although the values are coming out fine but in the diagonalm elements, it shows the true value + _rtable[4456495426] which I am not able to figure out why is it coming?
how i can trust in DirectSearch solution result.is there any creteria?
my variable is intensity.
this is my code:
ep0 := 1/(4*3.14); el := 8.54*10^(-2); hbar := 1; vf := 1/300; kb := 1; tem := 2.586*10^(-2); ci := 1; p := 1.458*10^16; beta := 2; ai := 7.1*10^(-4); bi := ai/sqrt(3); enph := .196; d := enph/(kb*tem); n0 := 1/(exp(enph/(kb*tem))-1); gama := hbar*vf; intensity := 10000001; w := 1.55; impurity := 7.2*10^3;
g := hbar*beta/(bi^2*sqrt(2*p*enph)); aa := g^2*(n0+1)/(2*Pi*hbar*gama^2); bb := g^2*n0/(2*Pi*hbar*gama^2); cc := 2/(Pi*gama^2); l := (1*hbar)*w/(2*kb*tem);u := el^2*intensity/(32*w*hbar^2);
DirectSearch:-SolveEquations([op([((enph*ln(1+exp(c+enph/(kb*tem)))/(kb*tem)-polylog(2, -exp(c))+polylog(2, -exp(c+enph/(kb*tem))))*enph*(kb*tem)^2-(enph^2*ln(1+exp(c+enph/(kb*tem)))/(kb^2*tem^2)+2*enph*polylog(2, -exp(c+enph/(kb*tem)))/(kb*tem)+2*polylog(3, -exp(c))-2*polylog(3, -exp(c+enph/(kb*tem))))*(kb*tem)^3+(-exp(b)*enph*ln(1+exp(c+enph/(kb*tem)))+exp(c+d)*enph*ln(1+exp(b-d+enph/(kb*tem)))+exp(b)*kb*tem*polylog(2, -exp(c))-exp(c+d)*kb*tem*polylog(2, -exp(b-d))-exp(b)*kb*tem*polylog(2, -exp(c+enph/(kb*tem)))+exp(c+d)*kb*tem*polylog(2, -exp(b-d+enph/(kb*tem))))*enph*(kb*tem)^2/((exp(b)-exp(c+d))*kb*tem)+(exp(b)*enph^2*ln(1+exp(c+enph/(kb*tem)))-exp(c+d)*enph^2*ln(1+exp(b-d+enph/(kb*tem)))+2*exp(b)*enph*kb*tem*polylog(2, -exp(c+enph/(kb*tem)))-2*exp(c+d)*enph*kb*tem*polylog(2, -exp(b-d+enph/(kb*tem)))+2*exp(b)*kb^2*tem^2*polylog(3, -exp(c))-2*exp(c+d)*kb^2*tem^2*polylog(3, -exp(b-d))-2*exp(b)*kb^2*tem^2*polylog(3, -exp(c+enph/(kb*tem)))+2*exp(c+d)*kb^2*tem^2*polylog(3, -exp(b-d+enph/(kb*tem))))*(kb*tem)^3/((exp(b)-exp(c+d))*kb^2*tem^2))*bb+u*(1/(1+exp(-l-c))-1/((1+exp(-l-c))*(1+exp(l-b))))-(((1*enph)*(enph-2*kb*tem*ln(1+exp(-b+enph/(kb*tem))))/(2*kb^2*tem^2)+2*kb^2*tem^2*(-polylog(2, -exp(-b+enph/(kb*tem)))+polylog(2, -cosh(b)+sinh(b))))*enph*(kb*tem)^2-(enph^2*(enph-3*kb*tem*ln(1+exp(-b+enph/(kb*tem))))-6*kb^2*tem^2*(enph*polylog(2, -exp(-b+enph/(kb*tem)))+kb*tem*(-polylog(3, -exp(-b+enph/(kb*tem)))+polylog(3, -cosh(b)+sinh(b)))))*(kb*tem)^3/(3*kb^3*tem^3)-(-exp(b)*enph^2+exp(c+d)*enph^2-2*exp(c+d)*enph*kb*tem*ln(1+exp(-b+enph/(kb*tem)))+2*exp(b)*enph*kb*tem*ln(1+exp(-c-d+enph/(kb*tem)))+2*exp(c+d)*kb^2*tem^2*polylog(2, -exp(-b))-2*exp(b)*kb^2*tem^2*polylog(2, -exp(-c-d))-2*exp(c+d)*kb^2*tem^2*polylog(2, -exp(-b+enph/(kb*tem)))+2*exp(b)*kb^2*tem^2*polylog(2, -exp(-c-d+enph/(kb*tem))))*enph*(kb*tem)^2/((2*(-exp(b)+exp(c+d)))*kb^2*tem^2)-(exp(b)*enph^3-exp(c+d)*enph^3+3*exp(c+d)*enph^2*kb*tem*ln(1+exp(-b+enph/(kb*tem)))-3*exp(b)*enph^2*kb*tem*ln(1+exp(-c-d+enph/(kb*tem)))+6*exp(c+d)*enph*kb^2*tem^2*polylog(2, -exp(-b+enph/(kb*tem)))-6*exp(b)*enph*kb^2*tem^2*polylog(2, -exp(-c-d+enph/(kb*tem)))+6*exp(c+d)*kb^3*tem^3*polylog(3, -exp(-b))-6*exp(b)*kb^3*tem^3*polylog(3, -exp(-c-d))-6*exp(c+d)*kb^3*tem^3*polylog(3, -exp(-b+enph/(kb*tem)))+6*exp(b)*kb^3*tem^3*polylog(3, -exp(-c-d+enph/(kb*tem))))*(kb*tem)^3/((3*(-exp(b)+exp(c+d)))*kb^3*tem^3))*aa-u*(1/(1+exp(l-b))-1/((1+exp(-l-c))*(1+exp(l-b)))) = 0, -cc*polylog(2, -exp(b))+cc*polylog(2, -exp(-c))-impurity = 0])], tolerances = 10^(-8), evaluationlimit = 20000)
Is it within the Physics environment possible to specify two sets, A and B, say, of quantities for which the following holds?
1.) any two elements of A anticommute,
2.) any two elements of B anticommute (as well), but
3.) any quantity from A commutes (not anticommutes) with any quantity from B.
Does there exist a Frobenius Group which is not  neither a Dihedralgroup nor  Symm(3) ?
Best regards
Kurt Ewald
I have a system of first order diff. equations which I would like to solve symbolically. Unfortunately, Maple does not solve the system. Do anybody have suggestions how can I solve this system (please see below):
diff(S(t), t) = -eta*(C[max]*w*N-alpha*Q(t))*K(t)*S(t)/(w*N*(S(t)+K(t))),
diff(K(t), t) = S(t)*((z*eta*alpha*(C[max]*w*N-alpha*Q(t))*S(t)-upsilon*(eta*alpha^2*Q(t)^2-2*C[max]*w*N*eta*alpha*Q(t)+((-N*w+z)*alpha+N*C[max]^2*w*eta)*N*w))*K(t)^2+(2*((1/2)*z*eta*(C[max]*w*N-alpha*Q(t))*S(t)+N*w*upsilon*(N*w-z)))*S(t)*alpha*K(t)+N*S(t)^2*w*alpha*upsilon*(N*w-z))/((K(t)^2*alpha*z+3*S(t)*K(t)*alpha*z+S(t)*(2*S(t)*z*alpha+upsilon*(C[max]*w*N-alpha*Q(t))))*(S(t)+K(t))*N*w),
diff(Q(t), t) = (-alpha*z*(z*eta*(C[max]*w*N-alpha*Q(t))*K(t)+N*w*upsilon*(N*w-z))*S(t)^2+(-z^2*eta*alpha*(C[max]*w*N-alpha*Q(t))*K(t)^2-(eta*alpha^2*Q(t)^2-2*C[max]*w*N*eta*alpha*Q(t)+N*w*((2*N*w-2*z)*alpha+N*C[max]^2*w*eta))*z*upsilon*K(t)-N*w*upsilon^2*(N*w-z)*(C[max]*w*N-alpha*Q(t)))*S(t)-N*w*z*alpha*upsilon*K(t)^2*(N*w-z))/((2*S(t)^2*alpha*z+(3*z*alpha*K(t)+upsilon*(C[max]*w*N-alpha*Q(t)))*S(t)+K(t)^2*alpha*z)*N*w*upsilon)
where initials conditions are:
S(0) = S0, K(0) = K0, Q(0) = Q0
Dmitry
very slow cause my computer have sound and overheat, still can not
calculated result
%c := Old_Asso_eigenvector1, a := Old_Asso_eigenvector3,
%b := Old_Asso_eigenvector2
% b <= c, a <= c,
% a ^ c = a, a V c = c
% b ^ c = b, b V c = c
with(ExcelTools):
with(ListTools):
with(DynamicSystems):
filename := "1207.HK";
open3 := Import(cat(cat("C://Temp//HK//Coal//",filename),".xls"), filename, "B2:B100");
high3 := Import(cat(cat("C://Temp//HK//Coal//",filename),".xls"), filename, "C2:C100");
low3 := Import(cat(cat("C://Temp//HK//Coal//",filename),".xls"), filename, "D2:D100");
close3 := Import(cat(cat("C://Temp//HK//Coal//",filename),".xls"), filename, "E2:E100");
with(CurveFitting):
n := 31;
f := Vector(n);
f2 := Vector(n);
open2 := Vector(n);high2 := Vector(n);gain2 := Vector(n);algebra2 := Vector(n);creative2 := Vector(n);creative3 := Vector(n);
upper2 := Vector(n);lower2 := Vector(n);upperloweratio := Vector(n);
deltaopen2 := Vector(n); deltahigh2 := Vector(n); deltalow2 := Vector(n); deltaclose2 := Vector(n);
logn := Vector(n);
for i from 0 to n-4 do
open2[i+1] := PolynomialInterpolation([[0,open3[n-i][1]],[1,open3[n-(i+1)][1]],[2,open3[n-(i+2)][1]],[4,open3[n-(i+3)][1]]],t):
high2[i+1] := PolynomialInterpolation([[0,high3[n-i][1]],[1,high3[n-(i+1)][1]],[2,high3[n-(i+2)][1]],[4,high3[n-(i+3)][1]]],t):
low2[i+1] := PolynomialInterpolation([[0,low3[n-i][1]],[1,low3[n-(i+1)][1]],[2,low3[n-(i+2)][1]],[4,low3[n-(i+3)][1]]],t):
if (close3[i+1][1]/close3[i+2][1]-1) < 0 then
gain2[i+1] := -1*round(100*abs(close3[i+1][1]/close3[i+2][1]-1)):
gain2[i+1] := round(abs(100*(close3[i+1][1]/close3[i+2][1]-1))):
deltaclose2[i+1] := close3[i+1][1] - close3[i+2][1];
deltahigh2[i+1] := high3[i+1][1] - high3[i+2][1];
deltaopen2[i+1] := open3[i+1][1] - open3[i+2][1];
logn[i+1] := ln(close3[i+1][1]/close3[i+2][1]);
f[i+1] := (high2[i+1] - open2[i+1])/4*1.8:
f2[i+1] := (open2[i+1] - low2[i+1])/4*1.8:
creative2[i+1] := simplify(((((close3[i+1][1]-close3[i+2][1]) + x)^2 -(close3[i+1][1]-close3[i+2][1])^2))/x)-x;
creative3[i+1] := simplify(((((close3[i+1][1]-close3[i+2][1]) + x)^3 -(close3[i+1][1]-close3[i+2][1])^3))/x);
upper2[i+1] := high3[i+1]-close3[i+1];
lower2[i+1] := close3[i+1]-low3[i+1];
upperloweratio[i+1] := round((lower2[i+1]/upper2[i+1])[1]);
od;
HilbertConj := proc(Px,Py)
return MatrixMatrixMultiply(Px,Py);
HilbertDisj := proc(Px,Py)
return Px+Py- MatrixMatrixMultiply(Px,Py);
t:=1;
i := 0;
InputMatrix3 := Matrix([[xxx, close3(t+1+i) , close3(t+2+i)],
[close3(t+1+i) , close3(t+2+i),0],
[close3(t+2+i),0 , 0]]):
InputMatrix3b := Matrix([[close3(t+1+i), close3(t+2+i) , close3(t+3+i)],
[close3(t+2+i) , close3(t+3+i),0],
[close3(t+3+i),0 , 0]]):
InputMatrix3c := Matrix([[close3(t+2+i), close3(t+3+i) , close3(t+4+i)],
[close3(t+3+i) , close3(t+4+i),0],
[close3(t+4+i),0 , 0]]):
m := MatrixMatrixMultiply(Transpose(InputMatrix3), InputMatrix3);
eigenvalues1 := Eigenvalues(m);
sys1 := MatrixMatrixMultiply(m-Matrix([[eigenvalues1[1],0,0],[0,eigenvalues1[1],0],[0,0,eigenvalues1[1]]]), Matrix([[x],[y],[z]]));
%solve([sys1[1][1],sys1[2][1],sys1[3][1]], [x,y,z]);
sol1 := solve([sys1[1][1],sys1[2][1]], [x,y,z]);
sys2 := MatrixMatrixMultiply(m-Matrix([[eigenvalues1[2],0,0],[0,eigenvalues1[2],0],[0,0,eigenvalues1[2]]]), Matrix([[x],[y],[z]]));
%solve([sys2[1][1],sys2[2][1],sys2[3][1]], [x,y,z]);
sol2 := solve([sys2[1][1],sys2[2][1]], [x,y,z]);
sys3 := MatrixMatrixMultiply(m-Matrix([[eigenvalues1[3],0,0],[0,eigenvalues1[3],0],[0,0,eigenvalues1[3]]]), Matrix([[x],[y],[z]]));
%solve([sys3[1][1],sys3[2][1],sys3[3][1]], [x,y,z]);
sol3 := solve([sys3[1][1],sys3[2][1]], [x,y,z]);
Old_Asso_eigenvector1 := Matrix([[rhs(sol1[1][1]),rhs(sol2[1][1]),rhs(sol3[1][1])],[rhs(sol1[1][2]),rhs(sol2[1][2]),rhs(sol3[1][2])],[rhs(sol1[1][3]),rhs(sol2[1][3]),rhs(sol3[1][3])]]);
Old_Asso_eigenvector2 := Eigenvectors(MatrixMatrixMultiply(Transpose(InputMatrix3b), InputMatrix3b)):
Old_Asso_eigenvector3 := Eigenvectors(MatrixMatrixMultiply(Transpose(InputMatrix3c), InputMatrix3c)):
% b <= c, a <= c, c := Old_Asso_eigenvector1, a := Old_Asso_eigenvector3, b := Old_Asso_eigenvector2
testa := HilbertConj(Old_Asso_eigenvector3[2], Old_Asso_eigenvector1);
testb := HilbertDisj(Old_Asso_eigenvector3[2], Old_Asso_eigenvector1);
testc := HilbertConj(Old_Asso_eigenvector2[2], Old_Asso_eigenvector1);
testd := HilbertDisj(Old_Asso_eigenvector2[2], Old_Asso_eigenvector1);
sysa := testa[1][1] = Old_Asso_eigenvector3[2][1][1];
sysb := testb[1][1] = Old_Asso_eigenvector1[2][1][1];
sysc := testc[1][1] = Old_Asso_eigenvector2[2][1][1];
sysd := testd[1][1] = Old_Asso_eigenvector1[2][1][1];
solve(sysa, xxx);
First 268 269 270 271 272 273 274 Last Page 270 of 371
