X belongto A, eigenvector(X) = 0
from this statement ,
using linearalgebra package eigenvectors function
the eigenvector matrix [3][1],[3][2],[3][3] are 1 , contradict 1=0
so, need to find another kind of eigenvector in terms of algebra
using original basic calculation solve, however got error
m := Matrix([[a1,a2,a3],[a4,a5,a6],[a7,a8,a9]]);
eigenvector1 := Eigenvectors(m);
solve(
[eigenvector1[2][1][1]=0, eigenvector1[2][1][2]=0, eigenvector1[2][1][3]=0,
eigenvector1[2][2][1]=0, eigenvector1[2][2][2]=0, eigenvector1[2][2][3]=0,
eigenvector1[2][3][1]=0, eigenvector1[2][3][2]=0, eigenvector1[2][3][3]=0]
solve(
eigenvector1[2][2][1]=0, eigenvector1[2][2][2]=0, eigenvector1[2][2][3]=0]
eigenvalue1 :=
(1/6)*(36*a7*a1*a3+108*a7*a2*a6+108*a8*a4*a3+36*a8*a5*a6
eigenvalue2 :=
-(1/12)*(36*a7*a1*a3+108*a7*a2*a6+108*a8*a4*a3+36*a8*a5*a6
eigenvalue3 :=
solve(MatrixMatrixMultiply(Matrix([[a1,a2,a3],[a4,a5,a6],[a7,a8,a9]])-Matrix([[eigenvalue1,0,0],[0,eigenvalue1,0],[0,0,eigenvalue1]]), Matrix([[x],[y],[z]])),[x,y,z]);
solve(MatrixMatrixMultiply(Matrix([[a1,a2,a3],[a4,a5,a6],[a7,a8,a9]])-Matrix([[eigenvalue2,0,0],[0,eigenvalue2,0],[0,0,eigenvalue2]]), Matrix([[x],[y],[z]])),[x,y,z]);
solve(MatrixMatrixMultiply(Matrix([[a1,a2,a3],[a4,a5,a6],[a7,a8,a9]])-Matrix([[eigenvalue3,0,0],[0,eigenvalue3,0],[0,0,eigenvalue3]]), Matrix([[x],[y],[z]])),[x,y,z]);
got error when using solve
> solve(MatrixMatrixMultiply(Matrix([[a1, a2, a3], [a4, a5, a6], [a7, a8, a9]])-Matrix([[eigenvalue1, 0, 0], [0, eigenvalue1, 0], [0, 0, eigenvalue1]]), Matrix([[x], [y], [z]])), [x, y, z]);
Error, invalid input: solve expects its 1st argument, eqs, to be of type {`and`, `not`, `or`, algebraic, relation(algebraic), ({set, list})({`and`, `not`, `or`, algebraic, relation(algebraic)})}, but received Matrix(3, 1, {(1, 1) = ((2/3)*a1-(1/6)*(36*a7*a1*a3+108*a7*a2*a6+108*a8*a4*a3+36*a8*a6*a5-72*a7*a3*a5-72*a8*a6*a1-72*a9*a4*a2+48*a9*a5*a1-12*a9*a1^2-12*a5*a1^2+8*a1^3-12*a9^2*a1-12*a5^2*a1-12*a9^2*a5-12*a9*a5^2+36*a8*a6*a9+36*a7*a3*a9+36*a4*a2*a1+36*a4*a2*a5+8*a9^3+8*a5^3+12*(54*a7*a2^2*a6*a4*a1+114*a8*a6*a9*a1*a4*a2+6*a8*a6*a9*a1*a7*a3+54*a8*a4*a3^2*a7*a9-60*a9*a1^2*a8*a6*a5-60*a8*a6*a7*a3*a5^2-60*a8*a6*a4*a2*a9^2-24*a9*a1*a4^2*a2^2+6*...
Hi Everybody,
I installed the Maple Toolbox for matlab and tried to run my old code.  For some reason, maple('restart') will cause Matlab to lock up.  Any ideas?
Windows 7 64-bit.  Matlab 2012b 32-bit, Maple 18 32-bit
Hi Mapleprimers,
I'm using CodeGeneration to convert a procedure I obtained with unapply() into a Matlab function.  I'm having problems getting the outputting function to run correctly in Matlab.  I'm going to dynamically generating equations, so directly editing the Matlab code won't work here.  I'm having problems getting any output in Matlab.  Here is the code I'm working on:  Series_addGear_codegen.mw
Ideally I would like output in a matrix.  I've tried putting the unapplied procedure in another procedure, but the CodeGeneration doesn't work.
This is the maple output from the function:
unapp(1,2,3,4,5);
{BAT_A = -2.267032891, BAT_V = 271, EM2_A = .4615464218, EM2_P = 125.0790803, EM2_T = -1, EM2_V = 271, EM2_W = 2, GBa_T = 12, GBa_W = 5/3, GBb_T = -4, GBb_W = 5, GEN_A = 1.805486469, GEN_P = 489.2868330, GEN_T = -12, GEN_V = 271, GEN_W = 5/3, ICE_mdot_g = 20}
Since I'll know the order of variables, I want the Matlab function to output:
[-2.267032891,  271,  .4615464218,  125.0790803,  -1, ...]
This is the output after putting the Matlab function in Matlab:
>> unapp(1, 1, 1, 1, 1)
Undefined function or variable 'BAT_A'.
Error in unapp (line 39)
unappreturn = unique([BAT_A == -t35 / 0.271e3 - t73 / 0.271e3 BAT_V == 271 EM2_A == t35 /
0.271e3 EM2_P == t35 EM2_T == -FD_T EM2_V == 271 EM2_W == FD_W GBa_T == t44 GBa_W == t41 GBb_T
== -ICE_T GB
This is the Matlab code that is generated by Maple 18:
MCode:=CodeGeneration[Matlab](unapp, declare = [FD_T::float, FD_W::float, GB_R::float, ICE_T::float, ICE_W::float],defaulttype=float,optimize,defaulttype = numeric);
Warning, could not preprocess. Found `abs` or similar in the 'While'/'For' conditions.
Warning, procedure/module options ignored
function unappreturn = unapp(FD_T, FD_W, GB_R, ICE_T, ICE_W)
t2 = 0.1e1 * FD_T * FD_W;
t5 = abs(FD_W);
t7 = abs(FD_T);
t9 = t5 ^ 2;
t13 = t7 ^ 2;
t15 = t9 * t5;
t21 = t13 * t7;
t23 = t9 ^ 2;
t31 = t13 ^ 2;
t33 = 0.1483000000e3 - 0.4267000000e1 * t5 - 0.1277000000e2 * t7 + 0.3640000000e-1 * t9 - 0.1160000000e1 * t5 * t7 + 0.2580000000e0 * t13 - 0.1181000000e-3 * t15 + 0.5994000000e-3 * t9 * t7 - 0.1171000000e-3 * t5 * t13 - 0.1739000000e-2 * t21 + 0.1245000000e-6 * t23 - 0.1200000000e-5 * t15 * t7 + 0.1584000000e-5 * t9 * t13 - 0.4383000000e-6 * t5 * t21 + 0.2947000000e-5 * t31;
if (-t2 == 0.0e0)
t35 = 0.0e0;
elseif (-t2 < 0.0e0)
t35 = t33;
t35 = -t33;
end
t36 = ICE_T * ICE_W;
t37 = 0.1e1 * t36;
t41 = ICE_W / GB_R;
t42 = abs(t41);
t44 = ICE_T * GB_R;
t45 = abs(t44);
t47 = t42 ^ 2;
t51 = t45 ^ 2;
t53 = t47 * t42;
t59 = t51 * t45;
t61 = t47 ^ 2;
t69 = t51 ^ 2;
t71 = 0.5280000000e-11 - 0.3849000000e-13 * t42 + 0.7190000000e2 * t45 + 0.1168000000e-15 * t47 - 0.1296000000e1 * t42 * t45 - 0.2489000000e1 * t51 - 0.1451000000e-18 * t53 - 0.1326000000e-3 * t47 * t45 + 0.8141000000e-2 * t42 * t51 + 0.4539000000e-2 * t59 + 0.6325000000e-22 * t61 + 0.2091000000e-6 * t53 * t45 - 0.3455000000e-5 * t47 * t51 - 0.2499000000e-4 * t42 * t59 + 0.5321000000e-4 * t69;
if (-t37 == 0.0e0)
t73 = 0.0e0;
elseif (-t37 < 0.0e0)
t73 = t71;
t73 = -t71;
end
unappreturn = unique([BAT_A == -t35 / 0.271e3 - t73 / 0.271e3 BAT_V == 271 EM2_A == t35 / 0.271e3 EM2_P == t35 EM2_T == -FD_T EM2_V == 271 EM2_W == FD_W GBa_T == t44 GBa_W == t41 GBb_T == -ICE_T GBb_W == ICE_W GEN_A == t73 / 0.271e3 GEN_P == t73 GEN_T == -t44 GEN_V == 271 GEN_W == t41 ICE_mdot_g == t36]);
I am not able to simplify my equation, any help would be appreciated ! I want the V[0]^2/r[0]  term to be eliminated
restart:with(Student[VectorCalculus]):
R1:=rho(diff(u(r,theta,z,t)*(V[0])^2/r[0],t)+ u(r,theta,z,t)*V[0](diff(u(r,theta,z,t)*V[0]/r[0],r))+v(r,theta,z,t)*V[0]/(r*r[0])*diff(u(r,theta,z,t)*V[0],theta)+w(r,theta,z,t)*V[0]*diff(u(r,theta,z,t)*V[0]/r[0],z)-(v(r,theta,z,t)*V[0])^2/(r*r[0])) +diff(p(r,theta,z,t)*rho*V[0]^2/r[0],r); simplify(R1*r[0]/V[0]^2);
rho((diff(u(r, theta, z, t), t))*V[0]^2/r[0]+u(r, theta, z, t)*V[0]((diff(u(r, theta, z, t), r))*V[0]/r[0])+v(r, theta, z, t)*V[0]^2*(diff(u(r, theta, z, t), theta))/(r*r[0])+w(r, theta, z, t)*V[0]^2*(diff(u(r, theta, z, t), z))/r[0]-v(r, theta, z, t)^2*V[0]^2/(r*r[0]))+(diff(p(r, theta, z, t), r))*rho*V[0]^2/r[0]
((diff(p(r, theta, z, t), r))*rho*V[0]^2+rho((w(r, theta, z, t)*V[0]^2*(diff(u(r, theta, z, t), z))*r+(diff(u(r, theta, z, t), t))*V[0]^2*r+u(r, theta, z, t)*V[0]((diff(u(r, theta, z, t), r))*V[0]/r[0])*r*r[0]-v(r, theta, z, t)^2*V[0]^2+v(r, theta, z, t)*V[0]^2*(diff(u(r, theta, z, t), theta)))/(r*r[0]))*r[0])/V[0]^2
Download 1.mw
hello evreybody i have these Error :
restart:with(plots):
M:=765 : m:=587 :I:=76.3*10^3 :Jp:=7.3*10^3 :e:=10.92: F:=0.42: omega:=0.56 :ka:=0.1:kb:=0.1:kc:=0.1: lambda1:=0.1 :lambda2:=0.1:lambda3:=0.1:
Error, illegal use of an object as a name
please help
thank you !
sign is different runnning the same script in maple 12 and maple 15 in different machine, just using matrixmultiply and matrix(xxx, shape=hermitian)
assume my window 7 infected by virus, can maple prevent virus change
its accuracy?
or
is there any change between maple 12 and maple 15?
i feel that i will have to make large effort in order to find reason such as reinstall maple 12.
window 7 maple 15
[[a = 3.720799777 10 , b = -3.720817167 10 ]], 0.3469023622
[(-0.737729376724384 + 0. I) ((-0.737729376724384100 + 0. I) a
+ (-0.738311510115612690 + 0. I) b) + (-0.590656319609631
- 0. I) ((-0.590656319609630831 + 0. I) a
+ (-0.589459378339369122 + 0. I) b) + (0.326925800179577
- 0. I) ((0.326925800179577230 + 0. I) a
+ (0.327770888454982090 + 0. I) b) = -0.736196608749071 + 0. I,
(-0.590656319609631 + 0. I) ((-0.591008582207233624 + 0. I) a
+ (-0.589459378339369010 + 0. I) b) + (0.331003458223746
+ 0. I) ((0.331003458223746439 + 0. I) a
+ (0.327770888454981812 + 0. I) b) + (-0.735625969091165
- 0. I) ((-0.735625969091165288 + 0. I) a
+ (-0.738311510115613134 + 0. I) b) = 0.327869065042947 + 0. I
window 8 maple 12
[[a = 0.2249293777, b = 1.221244758]], 0.9888653482, "************"
[(0.737729376724384100 + 0. I) ((0.737729376724384100 + 0. I) a
+ (-0.738311510115612690 + 0. I) b) + (0.590656319609631053 - 0. I)
((0.590656319609631053 + 0. I) a + (-0.589459378339369122 + 0. I) b) +
(0.326925800179576676 - 0. I) ((0.326925800179576676 + 0. I) a
+ (0.327770888454982090 + 0. I) b) = -0.736196608749071002 + 0. I,
(0.590656319609631053 + 0. I) ((0.591008582207233624 + 0. I) a
+ (-0.589459378339369010 + 0. I) b) + (-0.331003458223746605 + 0. I) ((
-0.331003458223746605 + 0. I) a + (0.327770888454981812 + 0. I) b) + (
-0.735625969091165178 - 0. I) ((-0.735625969091165178 + 0. I) a
+ (-0.738311510115613134 + 0. I) b) = 0.327869065042946218 + 0. I]
7
Dihedralgroup(9) acts on the set 1..9 and has order 9
g:=SmallGroup(18,1) acts on the set 1..18 and has order 18.
Question:
Is it possible to let g act on 1..9, too) and how can I do that?
Best regards
Kurt Ewald
Hi All. Hope all is well.
Assume that we have partitioned [0,a], into N equidistant subintervals and in each subinterval we have M sets of polynomials of arbitrary form[say bij(t)](a.e Taylor series, or Bernstein series,…)
for Example with N=4, M=3 and by Taylor series we have:
now we want to approximate a function, asy f(t), in this interval with following form:
If we have:
(Tau is a constant number)
then: How can  we find L and Z matrices using maple? Is it any way? (or other softwares?)
Mahmood   Dadkhah
Ph.D Candidate
Applied Mathematics Department
1. how to do optimization with partial differential equation as constraints in maple
2. how to do optimization with  partial differential equation as objective function in order to make output obey this model
I was given that solitary initial state to see how it will deform as time goes on. am struggling to get my code so that I can get video frames. please help on how I can generate my code
uo(x)= a0x2(1-x)2 for x (less than or equal to) x (less than or equal) 1
u0(x)    = 0 for x > 1
the video clips will be representing the function u(*,t) :x to u(x,t)
for a sequence of choices of t such as t=0; t=0,5...t=3
 “Error, too many levels of recursion” ,but there’s just a single expression.
How can this happen?
The help documents read,
 The function unames returns an expression sequence consisting of all the active names in the current Maple session which are ``unassigned names''.
But what unames() returns is obviously not the contents one expects:
It is not a very important question... but i like when i have a nice worksheet.
I would like to change the color of the maple input. Unfortunately, i manage to change the color for the inputs already created but not for the new maple input.
How can i change the color for the new maple input i want to create ?
How can I solve raychaudhuri equations numerically using GRtensor?
g := (-12*y^2+1)/(4*y^2+1)^3 * ln(abs(-1+2^(1-x-I*y)));
Compute Int(g, [x=1/2 .. infinity, y=0 .. infinity]).
PS: this stems from How to calculate hard integral?,
but it is not related to the RH.
First 269 270 271 272 273 274 275 Last Page 271 of 371
