Hi. I want to generate a Julia set, and teh first instruction in the demo, applications fractal is
GenerateComplex(a,b,c,d,e)
I have Maple13 and I can not find such instruction. Could you tell me where can I get it, or how to define it?
Help Please! :)
As it is seen in the picture, I can not integrate the power series. In contrast, the differentiation works!
what is wrong?
 support type error when plot, and moreover how to animate this plot
with(ExcelTools):
with(ListTools):
with(DynamicSystems):
filename := "0257.HK";
open3 := Import(cat(cat("C://Temp//HK//Bank//",filename),".xls"), filename, "B2:B100");
high3 := Import(cat(cat("C://Temp//HK//Bank//",filename),".xls"), filename, "C2:C100");
low3 := Import(cat(cat("C://Temp//HK//Bank//",filename),".xls"), filename, "D2:D100");
close3 := Import(cat(cat("C://Temp//HK//Bank//",filename),".xls"), filename, "E2:E100");
with(CurveFitting):
n := 31;
f := Vector(n);
f2 := Vector(n);
open2 := Vector(n);high2 := Vector(n);gain2 := Vector(n);algebra2 := Vector(n);creative2 := Vector(n);creative3 := Vector(n);
upper2 := Vector(n);lower2 := Vector(n);upperloweratio := Vector(n);
deltaopen2 := Vector(n); deltahigh2 := Vector(n); deltalow2 := Vector(n); deltaclose2 := Vector(n);
logn := Vector(n);
for i from 0 to n-4 do
open2[i+1] := PolynomialInterpolation([[0,open3[n-i][1]],[1,open3[n-(i+1)][1]],[2,open3[n-(i+2)][1]],[4,open3[n-(i+3)][1]]],t):
high2[i+1] := PolynomialInterpolation([[0,high3[n-i][1]],[1,high3[n-(i+1)][1]],[2,high3[n-(i+2)][1]],[4,high3[n-(i+3)][1]]],t):
low2[i+1] := PolynomialInterpolation([[0,low3[n-i][1]],[1,low3[n-(i+1)][1]],[2,low3[n-(i+2)][1]],[4,low3[n-(i+3)][1]]],t):
if (close3[i+1][1]/close3[i+2][1]-1) < 0 then
gain2[i+1] := -1*round(100*abs(close3[i+1][1]/close3[i+2][1]-1)):
gain2[i+1] := round(abs(100*(close3[i+1][1]/close3[i+2][1]-1))):
od;
n := 31;
newclose := Vector(n);
for j from 0 to n-4 do
x1 := close3[i+1];
y1 := close3[i+1];
newclose[i+1] := subs(y=y1, subs(x=x1, (1/2)*(-y+sqrt(-3*y^2-4*y*x))/y))
od;
close3 := newclose;
plot(close3(x), x=1..31);
od;
Hi, I have a bivariate generating function that looks like this
x/((1-x)*(2-x-x^k))
where x is enumerating by binary strings by length and k is counting a number patterns in the string. I would like to convert the series into partial fractions. Convert[parfrac] only seems to work when k is given a value, which I did for several small small choices, from which I guessed the general partial fraction decomposition. Would someone have an idea on how to extract the partial fractions directly in terms of x and k?
best, Luke
Hello all!
I have to solve 1D Heat equation with Neumann B.C. using implicit scheme.
I have:
I have my code in Maple for the solution of this problem using explicit sceme for Neumann B.C.. And I also have the solution of the problem using implicit scheme(but for Dirichle B.C.).
implicit_method_Dirichle_B.C..mws
explicit_method_Neumann_B.C..mws
I know that my Neumann B.C. for implicit scheme will be written like this.
I determined the ghost points and then got the final view of the B.Cs.:
But I can not imagine how I should put my Neumann  B.C. for implicit scheme in the code.
Please, help me! I will be very grateful!
Can anyone help me to solve this system of equations in Maple?
solve({
(-(1*Rfd*(1-(Ladssec/Lfd)+((((1.007033 +1*(Laqssec+Ll))*Ladssec)/(((Ra+0.04527646)^2+(1.007033 +1*(Ladssec+Ll))*(1.007033 +1*(Laqssec+Ll)))*Lfd)) *Ladssec)))/(Lfd))=-0.0069
,(-(1*Rfd*(-(Ladssec/Lfd)+((((1.007033 +1*(Laqssec+Ll))*Ladssec)/(((Ra+0.04527646)^2+(1.007033 +1*(Ladssec+Ll))*(1.007033 +1*(Laqssec+Ll)))*L1d)) *Ladssec)))/(Lfd))=0.002689
,(-(1*Rfd*(-((Ra+0.04527646)/((Ra+0.04527646)^2+(1.007033 +1*(Ladssec+Ll))*(1.007033 +1*(Laqssec+Ll))))*(Laqssec/L1q))*Ladssec)/(Lfd))=0.00002647
,(-(1*Rfd*(-((Ra+0.04527646)/((Ra+0.04527646)^2+(1.007033 +1*(Ladssec+Ll))*(1.007033 +1*(Laqssec+Ll))))*(Laqssec/L2q)) *Ladssec)/(Lfd))=-0.00001362
,(-(1*R1d*(-(Ladssec/Lfd)+((((1.007033 +1*(Laqssec+Ll))*Ladssec)/(((Ra+0.04527646)^2+(1.007033 +1*(Ladssec+Ll))*(1.007033 +1*(Laqssec+Ll)))*Lfd))*Ladssec)))/(L1d))=0.1052
,(-(1*R1d*(1-(Ladssec/Lfd)+((((1.007033 +1*(Laqssec+Ll))*Ladssec)/(((Ra+0.04527646)^2+(1.007033 +1*(Ladssec+Ll))*(1.007033 +1*(Laqssec+Ll)))*L1d)) *Ladssec)))/(L1d))=-0.2585
,(-(1*R1d*(-((Ra+0.04527646)/((Ra+0.04527646)^2+(1.007033 +1*(Ladssec+Ll))*(1.007033 +1*(Laqssec+Ll))))*(Laqssec/L1q))*Ladssec)/(L1d))=0.0009122
,(-(1*R1d*(-((Ra+0.04527646)/((Ra+0.04527646)^2+(1.007033 +1*(Ladssec+Ll))*(1.007033 +1*(Laqssec+Ll))))*(Laqssec/L2q)) *Ladssec)/(L1d))=-0.0005093
,(-(1*R1q*(((Ra+0.04527646)/((Ra+0.04527646)^2+(1.007033 +1*(Ladssec+Ll))*(1.007033 +1*(Laqssec+Ll))))*(Ladssec/Lfd))*Laqssec)/(L1q))=-0.000292
,(-(1*R1q*(-((Ra+0.04527646)/((Ra+0.04527646)^2+(1.007033 +1*(Ladssec+Ll))*(1.007033 +1*(Laqssec+Ll))))*(Ladssec/L1d))*Laqssec)/(L1q))=0.0008507
,(-(1*R1q*(1-(Laqssec/L1q)+((((1.007033 +1*(Ladssec+Ll))*Laqssec)/(((Ra+0.04527646)^2+(1.007033 +1*(Ladssec+Ll))*(1.007033 +1*(Laqssec+Ll)))*L1q))*Laqssec)))/(L1q))=-0.04423
,(-(1*R1q*(-(Laqssec/L2q)+((((1.007033 +1*(Ladssec+Ll))*Laqssec)/(((Ra+0.04527646)^2+(1.007033 +1*(Ladssec+Ll))*(1.007033 +1*(Laqssec+Ll)))*L2q))*Laqssec)))/(L1q))=0.0003831
,(-(1*R2q*(((Ra+0.04527646)/((Ra+0.04527646)^2+(1.007033 +1*(Ladssec+Ll))*(1.007033 +1*(Laqssec+Ll))))*(Ladssec/Lfd))*Laqssec)/(L2q))=-0.001785
,(-(1*R2q*(-((Ra+0.04527646)/((Ra+0.04527646)^2+(1.007033 +1*(Ladssec+Ll))*(1.007033 +1*(Laqssec+Ll))))*(Ladssec/L1d))*Laqssec)/(L2q))=-0.03134
,(-(1*R2q*(-(Laqssec/L1q)+((((1.007033 +1*(Ladssec+Ll))*Laqssec)/(((Ra+0.04527646)^2+(1.007033 +1*(Ladssec+Ll))*(1.007033 +1*(Laqssec+Ll)))*L1q))*Laqssec)))/(L2q))=4.239
,(-(1*R2q*(1-(Laqssec/L2q)+((((1.007033 +1*(Ladssec+Ll))*Laqssec)/(((Ra+0.04527646)^2+(1.007033 +1*(Ladssec+Ll))*(1.007033 +1*(Laqssec+Ll)))*L2q))*Laqssec)))/(L2q))=-4.868
}, {L1d, L1q, Ladssec, Laqssec, Lfd, R1d, R1q, Rfd, Ra, Ll},useassumptions)
assuming Lfd ~= 0.1632, R1d~=0.0269, L1d~=0.0750, L1q~=-0.1350, Ladssec~=0.0500, Laqssec~= -0.1500, Rfd~=0.0016, R1q~= 0.0215, Ra~=0.005, Ll~=0.15
which theory can explain the interaction of composition of group for combination of composition of group
if succeed to search a list of groups, what is the next step research them?
I have a linear system to solve.
mm:=proc(a,x,h,i)
local A,Z1,Z2,Z,F,result;  # to declare the local variable
A:=array(1..2,1..2,[[1,1],[a,a+h]]);
Z1:=evalf(int(1/(abs(y-x)+.000000001),y=a..a+h));
Z2:=evalf(int(y/(abs(y-x)+.000000001),y=a..a+h));
Z:=array([Z1,Z2]);
F:=evalm(inverse(A)&*Z);
result:=F[i]
end:
My questions:
1) My exact Z1 is Z1:=evalf(int(1/(abs(y-x)),y=a..a+h)); but I ask if can I put
the same for Z2.
2) Can I writte in a simple form the vector Z.  Because, later, il have a second system contains Z1,Z2, Z3, Z4,Z5.  The difference between Z1 and Z2 is the variable "y" added in the integral of Z2.
Many thinks.
I wish to  plot 2D animate for the soltion of this equation here is the code
with(PDEtools):
with(ArrayTools):
f:=u->sech(u):
g:=v->sech(v):
h:=1/10:
N:=20:
M:=20:
V:=x->x^2:
psi:=Array(0..N/h+1,0..M/h+1):
for i from 0 to N/h do
psi[i,0]:=evalf(f(i*h)):
for j from 0 to M/h do
psi[0,j]:=evalf(g(j*h)):
for i from 1 to N/h do
for j from 1 to M/h do
psi[i,j]:=-psi[i-1, j-1]+(1-(1/8)*h^2*V((1/2)*h*(j-i-1)))*psi[i, j-1]+(1-(1/8)*h^2*V((1/2)*h*(j- i+1)))*psi[i-1,j]:
ls:=[seq([seq([i*h,j*h,psi[i,j]],i=0..N/h)],j=0..M/h)]:
surfdata((ls),axes=boxed,labels=[`u`,`v`,`psi(u,v)`],shading=zhue,style=patchcontour);
Hey,
I am trying to write a single procedure to find the root of any function using the Newton-Raphson method, given the initial approximation and the tolerance. If this fails to converge, the program must then use the Bisection method to find the root. Need some help please. The current procedure i have done is only coming out with the first Iteration
Thanks for the help!
how to singularize existing function?
any group theory can describe the singularity function?
Good day, please how can one solve these BVPs using FINITE DIFFERENCE METHOD in maple. Here is the problem FDM.mw
I have some questions about Mobius Project:
  1. What is the license of the worksheets posted on Mobius Project's website?
    I can not find any information about the license of the materials submitted to the Mobius Project.
    Is my worksheets are protected by intellectual property laws and copyrighted by me?
    Or it is freely available for any use for everyone?
  2. What are the terms of use of Mobius Project and its service? I can not find it anywhere.
  3. What is the copyright for http://mobius.maplesoft.com/?
    I do not see any copyright in the footer of the site or elsewhere.
    So, no copyrights mean the materials/resources on this website can be freely copied/used by anyone?
I came across an image/photo and thought, It will be fun to try it in maple.
Except plotting a few triangles and circles, I couldn't make it.
Here is the image.
Have a look please.
Cheers!
I'm working on coupled differential equation.
The first system is :
y1''+y1'+y1=q1
q1''+e(q12-1)q1'+q1=y1"
And the second one :
y2''+y2'+y2=q2
q2''(t)+e(q22-1)q2'(t)+q2(t) = y2"+f(P) q1(t-tau)
This is a parametric system, f(P) and tau(P) are given function of the parameters P.
e is a constant
I have solved the first system with dsolve (using numeric option).
But when I try to solve the second one (with dsolve, numeric, setting P as a parameter), maple returns an error :
"Error, (in dsolve/numeric/process_input) input system must be an ODE system, got independent variables {t, t-1}"
I think Maple doesn't like " q1(t-tau)".
I have tried to create a new function q where :
q(t)=q1(t-tau)
But Maple returns the same error.
How can I fix it ?
Thanks for reading
EDIT : I have read there is no function in maple that solve delay differential equation.
But this is not a true DDE because q2 has no effect on q1
So I hope there is a way to "fool" maple and still use dsolve.
EDIT 2 :
I have found how to make it works.
I was using dsolve with the option compile (which increase (a lot) the efficiency of computation).
I delete this option and that's working.
Nevertheless, without the option compile, the computation is very very slow.
MapleHelp recommands to combine the 2 systems for more efficiency. But, when I combine, maple return the previous error.
How can I make it quicker ?
Here is the code :
test_2_cylindre_sans_compile.mw
First 270 271 272 273 274 275 276 Last Page 272 of 371
