I will use the following dummy example.
with function,f
f:=(xid,yid)->sum(x[i],i=1..xid)*sum(y[i],i=1..yid);
and a complicated term, myterm
myterm:=(f(3,4)+f(2,2))*f(1,1):
myterm:=expand(myterm);
'if' i have some previous knowledge, or know a bit of the term, i can find the structure by doing this
repar:=[f(1,1),f(2,2),f(3,4)];  # Or with more f(xid,yid) terms
tmp:=seq(repar[i]=ff[i],i=1..3);
simplify(myterm,{tmp});          # This is fine, gives me what i want
But, can we go further, and more 'obvious'
Given the fucntion f, same as before, and the same 'myterm'
can I have this
iwant:=(f(3,4)+f(2,2))*f(1,1);  # as a result, straightforward
so I dont have to go back to 'repar' and find that the terms exactly are.
Dear all;
I need a help in this question.
u(x,y,t) my solution of PDE. x,y space, and t=time.
In the case without t. .i.e. u(x,y). Here is a visualization of the lattice u(x_i,y_j). i=1..3, anf j=1..3.  Please try this example, it's working.
my question, if i would like to add a third variable t, i.e.  and get u(x_i,y_j,t_k)  on each points. I would like to show the lattice in (x,y) plan for each t_k. I Think I will get many parallel lattice.
Please can some one, modify this code to get the parallel lattice. Thanks.
with(PDEtools):
interface(rtablesize=20):
Here,
L := 'L':
N := 'N':
g := 'g':
Z := i -> -L+2*L/(N+1)*i;
x[0] = Z(0),x[N+1] = Z(N+1),y[0] = Z(0),y[N+1] = Z(N+1);
N := 4;
L := 1;
r := L/(N+1)/4;
ngon := (n,x,y,r,phi) -> [seq([x+r*cos(2*Pi*i/n+phi), y+r*sin(2*Pi*i/n+phi)], i = 1 .. n)]:
p[1] := display([seq(polygonplot(ngon(4,Z(0),Z(j),r,Pi/2),color=magenta),j=0..N+1),
seq(polygonplot(ngon(4,Z(N+1),Z(j),r,Pi/2),color=magenta),j=0..N+1),
seq(polygonplot(ngon(4,Z(i),Z(0),r,0),color=magenta),i=1..N),
seq(polygonplot(ngon(4,Z(i),Z(N+1),r,0),color=magenta),i=1..N),
seq(seq(polygonplot(ngon(20,Z(i),Z(j),r,0),color=white),i=1..N),j=1..N),
textplot([seq(seq([Z(i+0.1),Z(j),typeset(u[i,j])],i=0..N+1),j=0..N+1)],align={above,right})],view=[Z(-1)..Z(N+2),Z(-1)..Z(N+2)],tickmarks=[[seq(Z(i)=typeset(x[i]=evalf[2](Z(i))),i=0..N+1)],[seq(Z(i)=typeset(y[i]=evalf[2](Z(i))),i=0..N+1)]],
axes=boxed,scaling=constrained,labels=[``,``]):
p[1];
What is the weak solution integral equation for
du(x)/dx2 -(1+x2 ) u(x)-1=0
okay so we have to, In the Notation of this question http://www.mapleprimes.com/questions/201278-Fix-A-Syntax-Error-In-My-Simple-Function-please-Help , let f0 be contained in V be any given function and de ne
a sequence (fn) with n contained in (N subscript 0) of functions fn contained in V by
(f subscript 0) := f0  and   fn+1=Afn  for all n contained in (N subscript 0).
prove that this sequence converges pointwise, i.e. that for all   i,j contained in [N]X[N],
(f subscript infinity)(i, j) := (lim n-> infinity  fn(i, j)) exists and that "triangle"(f subscript infintiy) =0
and that
f1 = 0 :
any help would be much appreciated guys <3
I have a plot of a sinusoidal function(cos_phi) which changes with incrementing values of variable k. When this function goes above 1 or below -1 I would like to have the range of k for which it occurs outputed somehow. Would anybody know how to do this?
I am having trouble printing out a limit cylce on maple 16.  I have the attached file and if anybody could look at it and perhaps help me out it would be greatly appreciated.  The first limit cycle is supposed to look somewhat like the second one.  I'v tried many different things but nothing seems to be working.  an explenation would also be nice too.  if the file does not open correctly also let me know. thank you very much.
 Math_4710_Hilbert_16.mw
Hi , i need to write some maple functions for the equations below and i am not sure if this should be arrays or not. please see the question below;
Consider a factory which manufactures only one product. Raw material is bought from external supplier and stored until required.
Finished items are held in a warehouse. The operation of factory and its warehouse
can be modelled as a set of equations as folllows.
 Let us define at time t :
R(t) = Raw material stored (units)
F(t) = finished goods stock (units)
B(t) = order backlog (units)
T(t) = target stock level for finished goods (units)
All variables defined above give quantities at the start of week t.
X( t, t+1 )= weekly orders received from customers
M( t, t+1 )= raw material supplied per week.
P( t, t+1 )= production per week.
D(t, t+1 )= amount dispatched to customers per week.
All variables defined above give quantities over week t to t+1
(i.e over the week t). The operation of the factory and its warehouse can be expressed
as a set of equations given as follows:
Backlog and Stock Position
(1) B(t+1) = B(t)+X (t,t+1)–D(t,t+1)
(2) T(t+1) =(m +1)/m(X(t,t+1)+X(t–1,t)+…+X (t–m+1,t–m+2))
(assuming that the company wishes to maintain m (suppose m=5)) weeks stock of
finish items and hence the target level is m times the average of the last m–1 weeks)
(3) R (t+1)=R(t)+M(t,t+1)–P(t,t+1)
(4) F (t+1)=F (t) +P(t,t+1)–D(t,t+1)
Rates
(5) D (t,t+1) = B(t) if B(t)<F(t)
F (t) otherwise
(6) M (t,t+1) = P(t–1,t)
(7) P (t,t+1) = T(t) – F(t) + D(t,t+1)
= R(t) if result exceeds R(t)
= 0 if the result is negative
Given the initial values for the variables, it is possible to simulate this system to study
how the system will respond to the order rate. Suppose that all is calm, and the factory
has operated as follows for the last five weeks.
Target warehouse stock = 250
Finished goods stock = 250
Raw material stock = 150
Production rate = 50/week
Material supply rate = 50/week
Order rate = 50/week
Order backlog = 50
Suppose the behaviour continues for the first week of the simulation but that during
next week orders double due to the sales promotion. During the third week orders
drops to zero as all demand returns of the previous week was satisfied. For the fourth
week and the succeeding weeks, demand returns to an order rate of 50/week. What
happens elsewhere in the system? A deterministic simulation will provide the answer
to the above mentioned question.
 For this compute the following.
i) The values of the equations (1)–(4) at the start of week t.
ii) The values of the equations (5)–(7) i.e. the new values of the rates during
the following week.
iii) Move simulation time to the start of the next week.
Next simulation should be presented in tabular form and plot production and demand
rate to examine the performance of the system.
All help will be much appreciated.
Best Regards,
I do not have any code to produce yet.  I want to have Maple animate a bouncing ball on some 3d surface.
and if the A are an inversable matrix
worksheet output doesnt display the eigenvalues of a 19X19 matrix. Just gives in the form Root of(...). when datatype is indicated as anything other than complex(sflot) it gives error "unable to store". solution is required in compact mathematical expression form (may involve square roots etc). Please help.
When I try "touch and drag" in Maple documents, the documentation for example, I end up selecting text instead of scrolling. Unfortunately the alternatives for scrolling are a) the scrollbar, b) page-up/down or c) moving the cursor. Each of those alternatives is about 2.5311 orders of magnitude more inconvenient than touch&drag.
Does anybody know if its possible to get Maple (18) to scroll instead of select text when I touch the screen?
Hi everyone.
I'm trying to visualize some some field lines for a 3D magnetic field I have simulated, and I have read that the Student[VectorCalculus] package is the best package for this type of visualization. I tried implementing it as described online and in the manual, and I got an error:
Error, (in plots/fieldplot3d) no non-zero vectors found
Does anyone have any ideas as to what could be causing this issue?
Attached is the Maple document I am using. The section entitled "Problem Area" is where the issue is.
turtle-rec-bend.mw
• Is there a simple way to find the domain for the real solutions of f(x)?
• And is there a way to let maple get the part of f(x) with the sqrt?
   (not by typing it by hand as I dit below)
• Is there a way to write the summary of the found domains in one line?
Thanks for your help.
# How to find the Domain for real solutions for x?
f(x):=(x-1+sqrt(x^2-3*x+2))/(x-1);
discont_for_x=discont(f(x),x);
# x<>+1 (because the de denom=0 is not allowed)
denom(f(x))=0;
x={solve(denom(f(x))=0,x)};
# x<=1 union  2<=x (because the part under the sqrt must be >=0 to give Real solutions)
sqrt(x^2-3*x+2);
0<=x^2-3*x+2;
x=solve(0<=x^2-3*x+2,x);
What is the reason/Why:
Error, (in dsolve/numeric/bvp) unable to achieve requested accuracy of 0.1e-5 with maximum 128 point mesh (was able to get 0.66e-1), consider increasing `maxmesh` or using larger `abserr`
Thanks for the help :)
I'm trying to plot the direction field of the second order differential equation x''=x'-cos(x) using dfieldplot:
> with(DEtools); with(plots);
> f1 := (x, y) options operator, arrow; diff(x(t), t)-cos(x(t)) end proc;
/ d \
(x, y) -> |--- x(t)| - cos(x(t))
\ dt /
> dfieldplot([diff(x(t), t) = y(t), diff(y(t), t) = f1(x(t), y(t))], [x(t), y(t)], t = -2 .. 2, x = -2 .. 2, y = -2 .. 2);
Error, (in DEtools/dfieldplot) cannot produce plot, non-autonomous DE(s) require initial conditions.
The error I'm getting says I need initial conditions, but I wasn't provided with any. Is there another way to plot this? Sorry if this is dumb question, but I've only ever plotted first order equations.
First 274 275 276 277 278 279 280 Last Page 276 of 371
